https://en.wikipedia.org/wiki/Focke-Wulf_Fw_189
The Focke-Wulf Fw 189 Uhu ("Eagle Owl") is a German twin-engine, twin-boom, three-seat tactical reconnaissance and army cooperation aircraft. It first flew in 1938 (Fw 189 V1), entered service in 1940 and was produced until mid-1944. In addition, Focke-Wulf used this airframe in response to a tender request by the RLM for a dedicated ground-attack airplane, and later submitted an armored version for trials. However, the Henschel Hs 129 was selected instead. In 1937, the German Ministry of Aviation issued a specification for a short-range, three-seat reconnaissance aircraft with a good allround view to support the German army in the field, replacing the Henschel Hs 126, which had just entered service. A power of about 850–900 hp (630–670 kW) was specified. The specification was issued to Arado and Focke-Wulf. Arado's design, the Ar 198, which was initially the preferred option, was a relatively conventional single-engined high-wing monoplane with a glazed gondola under the fuselage. Focke-Wulf's chief designer Kurt Tank's design, the Fw 189, was a twin-boom design, powered by two Argus As 410 engines instead of with an expected single engine. As a "twin-boom" design like the earlier Dutch Fokker G.I from 1938, the Fw 189 used a central crew gondola for its crew accommodation, which for the Fw 189 would be designed with a heavily glazed and framed "stepless" cockpit forward section, which used no separate windscreen panels for the pilot (as with many German medium bombers from 1938 onwards). Blohm & Voss, however, proposed as a private venture something even more radical: chief designer Dr. Richard Vogt's unique asymmetric BV 141. Orders were placed for three prototypes, each of the Arado and Focke-Wulf designs, in April 1937. The Fw 189 was produced in large numbers, at the Focke-Wulf factory in Bremen, at the Bordeaux-Merignac aircraft factory (Avions Marcel Bloch's factory, which became Dassault Aviation after the war) in occupied France, then in the Aero Vodochody aircraft factory in Prague, occupied Czechoslovakia. Total production was 864 aircraft of all variants. Role Tactical reconnaissance and army cooperation aircraft, light bomber Manufacturer Focke-Wulf Designer Kurt Tank First flight July 1938 Introduction August 1941 Retired 1945 Primary users Luftwaffe Hungarian Air Force Slovak Air Force Produced 1940–44 Number built 864 Called the Fliegende Auge ("Flying Eye") of the German Army, the Fw 189 was used extensively on the Eastern Front with great success. It was nicknamed "Rama" ("frame" in the Russian, Ukrainian and Polish languages) by Soviet forces, referring to its distinctive tailboom and stabilizer shapes, giving it the characteristic quadrangular appearance. Despite its low speed and fragile looks, the Fw 189's manoeuvrability made it a difficult target for attacking Soviet fighters. When attacked, the Fw 189 was often able to out-turn attacking fighters by simply flying in a tight circle into which enemy fighters could not follow. Specifications (Fw 189 A-1) General characteristics Crew: three Length: 12 m (39 ft 4 in) Wingspan: 18.4 m (60 ft 4 in) Height: 3.7 m (12 ft 0 in) Wing area: 38 m² (409 ft²) Empty weight: 2,680 kg (5,920 lb) Loaded weight: 3,950 kg (8,708 lb) Powerplant: 2 × Argus As 410, 342 kW (465 PS - 459 hp) each Performance Maximum speed: 357 km/h at 2,600 m (222 mph at 8,530 ft) Range: 670 km (416 mi) Service ceiling: 8,400 m (27,550 ft) Rate of climb: 8.3 m/s (1,640 ft/min) Wing loading: 103.9 kg/m² (21.3 lb/ft²) Power/mass: 86.6 W/kg (0.053 hp/lb) Armament Guns: 2 × 7.92 mm (.312 in) MG 17 machine guns mounted in the wing roots, firing forward 1 × 7.92 mm (.312 in) MG 15 machine gun in dorsal flexible mount position firing to rear 1 × 7.92 mm (.312 in) MG 15 in rear cone firing to rear (optional) Bombs: 4 × 50 kg (110 lb) bombs * |
Focke-Wulf Fw 190 pics [3/6] - A German Focke-Wulf Fw 190 A-3 of 11. JG 2 after landing in the UK by mistake in June 1942..jpg (1/1) | Miloch | Aviation Photos | 0 | January 14th 19 03:32 PM |
Focke-Wulf Fw 190 pics [1/6] - A captured Focke Wulf Fw 190A-3 at the Royal Aircraft Establishment..jpg (1/1) | Miloch | Aviation Photos | 0 | January 14th 19 03:32 PM |
Focke-Wulf Fw 187 pics 2 [6/6] - focke-wulf-fw-187-falke-1940-CPJF98.jpg (1/1) | Miloch | Aviation Photos | 0 | November 8th 18 03:03 PM |
Focke-Wulf Fw 187 pics 2 [5/6] - focke-wulf-fw-187-falke-1940-CPJF9B.jpg (1/1) | Miloch | Aviation Photos | 0 | November 8th 18 03:03 PM |
Focke-Wulf Fw 187 pics 2 [4/6] - focke-wulf-fighter-aircraft.jpg (1/1) | Miloch | Aviation Photos | 0 | November 8th 18 03:03 PM |
