LXNAV PowerMouse - U.S. F.C.C. Approved
Old August 22nd 19, 11:31 PM posted to rec.aviation.soaring
Paul Remde
Default LXNAV PowerMouse - U.S. F.C.C. Approved
Hi,
The LXNAV PowerMouse has received U.S. F.C.C. approval for use in the USA!!!
Units will be available in September, 2019. Pre-Order Now!
- Much smaller than PowerFLARM Core
- Can Transmit on optional FLARM B port
- New PowerFLARM circuit board
Details: http://cumulus-soaring.com/lxnav.htm#LXNAV-PowerMouse
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old August 23rd 19, 12:59 PM posted to rec.aviation.soaring
Paul Remde
Hi,
LXNAV made an error when they told me yesterday that the PowerMouse can transmit on both the FLARM A and B ports. Today they told me that in the USA the PowerMouse will only transmit on the FLARM A port.
Best Regards,
Paul Remde
_____________________________________
On Thursday, August 22, 2019 at 5:31:25 PM UTC-5, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
Old August 23rd 19, 01:29 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Paul
What is a Power Mouse?
Is it another system of Flarm like a core?
What is the difference/ advantage of a Mouse?
Nick
Old August 23rd 19, 03:08 PM posted to rec.aviation.soaring
Paul Remde
Hi Nick,
I explain all that he
To copy and paste from that site:
Differences Between the PowerMouse and the PowerFLARM Co
- The PowerMouse is much smaller than the PowerFLARM Core.
- The PowerMouse has the latest PowerFLARM hardware
- The PowerMouse IGC Enable is an extra cost option. It is included as standard with the PowerFLARM Core.
Note: The PowerMouse's optionalIGC Enable includes a logger altimeter calibration data sheet. The PowerFLARM Core does not, but I offer it as a $75 option.
You can also view my FLARM Comparison table he
http://cumulus-soaring.com/flarm.htm...ARM_Comparison
Best Regards,
Paul Remde
On Friday, August 23, 2019 at 7:29:44 AM UTC-5, Nick Kennedy wrote:
Paul
Nick
Old August 23rd 19, 03:27 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
On Friday, August 23, 2019 at 5:29:44 AM UTC-7, Nick Kennedy wrote:
Paul
Nick
Nick,
The PowerMouse FCC also transmits and receives on the second optional RFB port. The PowerFlarm does not.
http://www.craggyaero.com/lxnav_flarm.htm
Richard
www.craggyaero.com
Old August 23rd 19, 08:45 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I wish it did, but it doesn't. As stated above I received an email from LXNAV today (August 23, 2019) correcting the previous incorrect information. The PowerMouse will not transmit on the B port, unfortunately.
Best Regards,
Paul Remde
_________________________________________
Paul
Nick
Nick,
Richard
www.craggyaero.com
Old August 23rd 19, 10:28 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Friday, August 23, 2019 at 12:45:03 PM UTC-7, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
Paul
Nick
Nick,
Richard
www.craggyaero.com
Hey Paul - you might also give an update on how it handles ADS-R and TIS-B targets. I've heard various things about ADS-R. I got a definitive 'No' from Uros on the TIS-B question.
It's tricky to do because they're in Europe so testing for US-specific features is...challenging.
Andy Blackburn
Old August 24th 19, 12:06 AM posted to rec.aviation.soaring
Hi,
Best Regards,
Paul Remde
Paul
Nick
Nick,
Richard
www.craggyaero.com
Andy Blackburn
Andy,
You should see ADS-R on PowerFlarm and PowerMouse if you are near a rebroadcast station.
Automatic Dependent Surveillance ‐ Rebroadcast (ADS-R)
ADS-R is a client-based service that relays ADS-B information transmitted by an aircraft broadcasting on one link to aircraft equipped with ADS-B In on the other link. For example, the information for an aircraft equipped with a 1090MHz ADS-B Out system will be re-broadcasted to an aircraft equipped with ADS-B In on the UAT (i.e. 978MHz) frequency, and vice versa.
You may see TIS-B aircraft if a client aircraft is near you.
It appears to get TIS-B you also need ADS-B Out in your aircraft.
A definition TIS-B is in order.
Aircraft equipped with avionics meeting or exceeding TSO-C199 performance requirements are "TIS-B client aircraft." Non-ADS-B aircraft or aircraft broadcasting ADS-B but not meeting TSO-C199 requirements are "TIS-B targets." Client aircraft receive TIS-B targets that are within a 15 NM radius and +/- 3500 ft altitude of the client aircraft.
NOTE: Installing ADS-B In avionics without ADS-B Out avionics that meet or exceed the performance requirements of TSO-C199 only allows aircraft to receive TIS-B data intended for nearby Client aircraft that have qualified ADS-B Out avionics. This type of "piggybacking" will result in an incomplete representation of traffic around the aircraft. See "TIS-B Service Changes" below to understand the details of what ADS-B Out performance requirements must be met to receive full TIS-B services.
Richard
www.craggyaero.com
Old August 24th 19, 05:19 AM posted to rec.aviation.soaring
Dave Watrous
Flarm's PowerFlarm Core product page still has the following text on it:
ADS-R, TIS-B, FIS-B and UAT are currently not supported.
My understanding is that you will only get non-directional Mode C/S transponders alerts for aircraft with a transponder that does not have 1090ES ADS-B out.
It would be nice to get an update as to if and when ADS-R will be supported on the PowerFlarm Core.
Dave W
PowerMouse vs Power Flarm - Updates by March? hardware/software -ADS-R, TIS-B WaltWX[_2_] Soaring 14 March 27th 19 06:33 AM
IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder Ian Strachan[_3_] Soaring 0 February 19th 18 11:48 AM
L-13 STC approved by EASA Frank Whiteley Soaring 0 June 14th 11 10:17 PM
Approved Flight Sim [email protected] Instrument Flight Rules 2 December 10th 06 02:20 PM
IGC - approved levels for some.... Stan Kochanowski Soaring 1 March 18th 05 01:47 PM
