Lost comm procedures
Old March 3rd 05, 06:07 AM
Ron Garret
Default Lost comm procedures
A couple of related questions. You'll want to get your southern
California approach plates out to follow this.
1. The preferred tower-enroute IFR routing from VNY to SNA ends at SLI,
but SLI is not an IAF for any approach into SNA. What should you do if
you lose comm before ATC starts to vector you for an approach?
The second question begins with a background anecdote:
A few weeks ago I flew VNY-CMA. I filed /G, so I assumed (silly me)
that I'd get a GPS approach. The clearance was Canoga 8 departure, VNY,
direct. When ATC told me to fly direct COOGA I realized something was
amiss, as I suddenly had no clue where COOGA was. It wasn't until after
I landed that I figured out I was supposed to be flying the VOR
approach, and that I could have figured that out ahead of time because
VNY is an IAF for the VOR but not the GPS approach (which, oddly, is not
an overlay of the VOR approach, but is offset by six degrees).
Which brings me to my second question:
2. The Canoga 8 departure doesn't go to VNY. The lost comm procedure
says to intercept the LAX 323 radial, then "as assigned." But if I take
that literally, I'd be flying back to VNY along some more or less random
heading (depending on where I intercepted the LAX-323) but almost
certainly pointing in almost the exact wrong direction. Why isn't the
clearance "Canoga 8, COOGA, direct"? And what should I really do if I
lose comm after departure on this clearance?
Thanks,
rg
Old March 3rd 05, 10:15 AM
SLI is a feeder fix for the ILS 19R; i.e., there is a published route and
altitude to MAAGG, then to the IAF.
Old March 3rd 05, 02:46 PM
Roy Smith
It makes it easier on people if you could provide a URL to the plate(s) you
have in mind.
Pick an approach that makes sense for the weather conditions, pick an IAF
for that approach that makes sense for your current location and navigation
equipment, fly direct to the IAF, fly the approach, land, taxi off the
runway, wait for the "follow-me" truck to show up and lead you to the ramp.
You've got some fair terrain in the immediate vicinity of the airport, so
paying attention to altitude is critical. Remember what the rule says, the
HIGHEST of the MEA, cleared, or expected altitude. If you had picked the
ILS-19R, it would be obvious; 4000 to MAAGG and SNAKE, then as shown in the
profile view.
It gets a little more interesting if the wind is blowing the other way and
you decide to use the GPS-1L. My initial thought was that since there's no
charted segment from SLI to MINOE, you would fly the MSA. The problem is,
the MSA is 6800 in all quadrants. I don't know why they didn't provide
more than one MSA segment; the MSA southwest of the airport could obviously
be a lot lower. By the book, you would fly 6800 from SLI to MINOE, descend
to 3000 in the hold, and proceed inbound from there. If you were already
at 6800 or higher at SLI, I might be inclined to stay there and do all
that, but I'm guessing you were probably already assigned something lower
en-route to SLI. In that case, I'd use a little common sense and stay at
my last assigned altitude out to MINOE. If you were already at, say, 3000
coming into SLI, I can't see the point in a climb back to 6800 for the trip
out over the water.
So ask the guy. "Unfamiliar with COOGA, say reason for reroute". Better
to sound a little dumb now than to just plod on fat, dumb, and happy hoping
things will start to make sense later. He probably would have given you a
heading and distance to COOGA and told you to expect the VOR-whatever. You
could have then requested the GPS approach and assuming traffic permitted,
you would have then be re-cleared for that.
It sounds like you should intercept the LAX-323, fly that northwest to
IPIHO, then eastbound direct VNY, then continue with your clearance. This
is a lot of button pushing to do by the book. By the time you got the box
set up to track the LAX-323 outbound, you'd probably be past IPIHO, not to
mention that it might blow away the rest of your carefully programmed
flight plan. What I would have done instead was go into moving map mode,
turn on displaying intersections, and flown it by eye.
Old March 3rd 05, 06:48 PM
Ron Garret
have in mind.
Well, in this case there were half a dozen plates in play. Is there an
easy way to pull up all the plates for a particular airport on line? I
only know how to get them one at a time.
I did ask where COOGA was (actually I asked how it was spelled), but
neither I nor the controller picked on the fact that we had a major
disconnect going on. (The controller did express surprise that I wasn't
familiar with COOGA, but didn't make the connection and say, "COOGA is
the IAF for the approach you're supposed to be flying. Are you sure you
know what you're doing?") I didn't ask for the reason for the reroute
because I didn't realize it was a reroute.
(BTW, all this was in VFR conditions. If I had been in the clouds I
would have been much more proactive about asking for help, but since I
always had the option of canceling IFR if things really went south I
wanted to see if I could figure it out on my own.)
Yes, that's what it sounds like, but that can't be right. Continuing
with the clearance at that point would require making a 180 degree turn
(more or less) with no charted procedure for doing so (probably because
there are mountains on both sides). And why to IPIHO? The lost comm
procedure doesn't mention IPIHO. They just say to intercept LAX323 and
then as assigned. So if you really took that literally you'd be
approaching VNY from some random heading depending on where you
intercepted LAX323. The whole thing doesn't make sense.
This
I'm not so concerned with the mechanics of flying the approach in this
case as I am just figuring out what the rules say I'm supposed to do.
It really seems to me like this clearance had a bug in it, and it should
have been Canoga 8, COOGA, direct, not Canoga 8, VNY, direct.
rg
Old March 4th 05, 01:19 PM
Roy Smith
Ron Garret wrote:
Is there an easy way to pull up all the plates for a particular airport
on line?
I like www.airnav.com. I'm sure there are others.
Controllers are good at answering the questions you ask. You asked,
"How do you spell that", and he gave the right answer, "Charlie Oscar
Oscar Golf Alpha". You didn't ask anything more, so he assumed you
were happy. There's no reason for him to assume that "How do you
spell that" should also imply, "and just why the heck do you want me
to go there?"
The controller did express surprise that I wasn't familiar with COOGA
How did he "express surprise"? Did he say, "I'm surprised you aren't
familiar with COOGA"?
I can only assume that the procedure designers took this into
account. Looking at the ILS-16R plate, I'd guess the highest point
within several miles of VNY is the 1520 which looks about 4 miles north of
VNY. You didn't mention what initial altitude you were given, but I'm sure
it was at least 2000. I also don't know what you're flying, but assuming
120 KTAS, turn diameter at standard rate is about 1.3 nm. If the turn
really was almost 180 degrees, there's nothing to keep you from making it a
right turn, away from the terrain.
And why to IPIHO? The lost comm procedure doesn't mention IPIHO. They
just say to intercept LAX323 and then as assigned.
I see what you're getting at. There is a certain amount of ambiguity here.
I don't see anything in the procedure which says IPIHO. It does say to
intercept the LAS-323, and your first en-route fix is VNY, so I just
figured following a heavy black line made sense.
Well, from the ground, that's really no better than what you got, since
none of the CNOG8 transitions get you to COOGA.
Old March 4th 05, 04:59 PM
Ron Garret
Roy Smith wrote:
on line?
I can only find one plate per URL here, just like all the other sources
of approach plates that I'm aware of. Am I missing something?
to go there?"
No, it implied that I wasn't familiar with COOGA, which in turn implied
that I wasn't familiar with the approach that he thought I was supposed
to be flying.
I don't remember the exact phraseology, but it was something like, "If
you're going to be flying around here you'd better get to know COOGA
intersection."
4000. Maybe that's why the departure is designed the way it is. They
want you give you essentially a clockwise 360 to get up to cruising
altitude before heading West.
An SR22.
, but assuming
Do the TERPsters really expect someone to figure that out on the fly?
Turning left to SUANA (which is an IAF for the GPS approach) makes sense
too. But I'm not talking about what makes sense, I'm talking about the
rules.
None of them get you to VNY either.
rg
Old March 4th 05, 06:29 PM
Dave Butler
I hope I don't seem too critical here, but you seem so resistant about this...
and yes, I think you are missing that you are the one asking for help, and it
would be helpful to those who are trying to help you if you did more legwork,
and demanded less legwork of the people you are soliciting help from. It doesn't
seem so hard to me to include multiple links along with your question. You are
one person doing that preliminary research, saving several good-hearted people
from having to do it. I don't buy "It's too hard because I can't find a single
URL, so you do it".
snip
to be flying.
This theme has bothered me throughout the thread. Were you not told which
approach to expect? You shouldn't have to infer a choice of approaches based on
a fix that you are cleared to.
snip
Dave
Agent86's List of Misconceptions about of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 12 April 20th 04 02:21 AM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
Agent86's List of Misconceptions about FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 9 April 18th 04 06:13 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
