https://en.wikipedia.org/wiki/Boeing_KC-46_Pegasus
The Boeing KC-46 Pegasus is a military aerial refueling and strategic military transport aircraft developed by Boeing from its 767 jet airliner. In February 2011, the tanker was selected by the United States Air Force (USAF) as the winner in the KC-X tanker competition to replace older Boeing KC-135 Stratotankers. The first aircraft was to be delivered to the Air Force in August 2017, but was delayed until 10 January 2019. The Pegasus is a variant of the Boeing 767 and is a widebody, low-wing cantilever monoplane with a conventional tail unit featuring a single fin and rudder. It has a retractable tricycle landing gear and a hydraulic flight control system. The Pegasus is powered by two Pratt & Whitney PW4062 engines, one mounted under each wing. The flightdeck has room for a crew of four with a forward crew compartment with seats for 15 crews members and in the rear fuselage either palletized passenger seating for 58, or 18 pallets in cargo configuration. The rear compartment can also be used in an aero-medical configuration for 54 patients (24 on litters). At the rear of the aircraft is a fly-by-wire refueling boom supplemented by Wing Air Refueling Pods at each wingtip and a Centreline Drogue System under the rear fuselage. Role Air-to-air tanker, strategic airlift Manufacturer Boeing Defense, Space & Security First flight 25 September 2015 Introduction 2019 Status In testing Primary user United States Air Force Produced 2013–present Unit cost US$147.4 million (ave. cost, FY16) US$241.1M (with R&D) Developed from Boeing KC-767 On 29 October 2015, the USAF announced that Seymour Johnson Air Force Base, North Carolina, was chosen as the preferred alternative for the first Reserve-led KC-46A Pegasus main operating base. The KC-46As will begin arriving at Seymour Johnson in fiscal year 2019. Tinker Air Force Base, Oklahoma; Westover Air Reserve Base, Massachusetts; and Grissom Air Reserve Base, Indiana, were named as the reasonable alternatives. The Air Force plans to begin the Environmental Impact Analysis Process (EIAP). Once the requirements of the EIAP are complete, the Air Force will make its final basing decision. On 10 January 2019, the USAF took delivery of the first KC-46, albeit with two issues outstanding and money withheld. The two outstanding issues were inadequate boom pressure when refueling the A-10 Warthog and glare induced distortion under certain conditions in the remote vision system (RVS). The Air Force has acknowledged that they failed to give Boeing adequate specifications for the A-10. At milestone C, Boeing gave the Air Force a boom design that used the international standard of 1400 lbs of thrust resistance, which they accepted, but A-10 is only able to generate 650 lbs. On 25 January, the 22d Air Refueling Wing at McConnell AFB received their first two KC-46As (15-46009 and 17-46031). A further two (17-46030 and 16-46022) were delivered 6 days later. On 3 February, the 97th Air Mobility Wing at Altus AFB received their first KC-46. Specifications General characteristics Crew: 3 (2 pilots, 1 boom operator) basic crew; 15 permanent seats for additional/optional air crew members, including aeromedical evacuation crew members Capacity: seating for up to 114 people, 18 463L pallets, or 58 patients (24 litters, 34 ambulatory) Payload: 65,000 lb (29,500 kg) Length: 165 ft 6 in (50.5 m) Wingspan: 157 ft 8 in (48.1 m) Height: 52 ft 1 in (15.9 m) Empty weight: 181,610 lb (82,377 kg) Max. takeoff weight: 415,000 lb (188,240 kg) Fuel Capacity: 212,299 lb (96,297 kg) Maximum Transfer Fuel Load: 207,672 lb (94,198 kg) Powerplant: 2 × Pratt & Whitney PW4062 turbofan, 63,300 lbf (282 kN) each Performance Maximum speed: Mach 0.86 (570 mph, 914 km/h) Cruise speed: Mach 0.80 (530 mph, 851 km/h) Range: 6,385 nmi (11,830 km) ; global with in flight refueling Service ceiling: 40,100 ft (12,200 m) * |
| Thread Tools | |
| Display Modes | |
| Boeing Dreamlifter pics [4/9] - Boeing 747 LCF, N780BA with its swing-tail cargo bay access open at Paine Field, location of the Boeing Everett Factory in 2015.jpg (1/1) | Miloch | Aviation Photos | 0 | December 26th 18 05:13 PM |
| KC-46 C-17 KC-46A-Pegasus.jpg 199 (1/1) | J3[_2_] | Aviation Photos | 0 | December 21st 18 06:19 PM |
| 10 Pegasus Airlines Boeing 737-8FH TC-AAK | Andrew B | Aviation Photos | 0 | October 1st 08 09:35 PM |
| FS: Pegasus | [email protected] | Soaring | 1 | October 4th 05 11:05 PM |
| Pegasus AD | [email protected] | Soaring | 9 | August 29th 05 01:03 AM |
