https://en.wikipedia.org/wiki/SAAB_21
The SAAB 21 was a Swedish fighter and attack aircraft designed and manufactured by Swedish aviation company SAAB. It used a relatively unorthodox and visually distinctive combination of a twin boom fuselage and a pusher configuration, giving the aircraft a fairly unique appearance. Work on the development of the 21 commenced at SAAB following a decision by the Swedish Air Force to embark on a large-scale expansion programme in preparation to fears that the nation might get dragged into the Second World War. The company designed a monoplane twin-boom aircraft, powered by a single Daimler-Benz DB 605B engine that was positioned within the rear of the fuselage, directly behind the pilot, that drove a rear-facing propeller, commonly known as a pusher configuration. This arrangement allowed armaments to be contained within the aircraft's nose section as well as providing the pilot with a high degree of external visibility. To safely enable the pilot to bail out without striking the propeller behind him, it was decided to adopt an ejection seat. On 30 July 1943, the 21 performed its maiden flight; on 1 December 1945, the first model of the fighter, the J 21A-1 was introduced to service. It was quickly followed by the improved J 21A-2, which featured a heavier armament arrangement, and the B 21A-3, which was a dedicated fighter-bomber mode of the type. In response to interest from the Swedish Air Force in adopting a jet-powered fighter, SAAB developed a conversion of the aircraft, using the British de Havilland Goblin as its powerplant. The jet-powered model of the aircraft was designated as the 21R. During the mid-1950s, less than ten years after its introduction, the 21 was withdrawn from service, having been replaced by a new generation of jet-powered fighters such as the de Havilland Vampire and the Saab 29 Tunnan. The Saab 21 was an unorthodox twin-boom pusher configuration fighter aircraft. It featured a low-mounted wing, a tricycle landing gear arrangement, and was furnished with heavy forward-firing armament. Several recent innovations were incorporated into its design, such as an ejector seat for the pilot; the pusher layout later allowed the type to be readily modified with a turbojet engine as well. The advantages of a pusher design are of an unobstructed forward view for the pilot, while the armament can also be concentrated in the nose; however, a major drawback is difficulty in escaping from the aircraft in an emergency, as the pilot could get drawn into the propeller blades. Saab resolved this issue via the installation of an early ejector seat, developed by Swedish defense firm Bofors, which was developed in conjunction with the fighter itself. The wing of the 21 was based on a SAAB-designed low drag airfoil; as the wings could not reasonably accommodate recesses for the main landing gear when retracted, alcoves were instead provided within the tail booms, directly aft of the rear wing spar. Other systems, such as the center-section fuel tanks, were incorporated into the wing, which complicated their design considerably. To minimise drag, the coolers and ducts for the engine were housed within the contours of the airfoil between the fuselage and tail booms. The armament initially consisted of two 13.2 mm automatkanon m/39A (akan m/39A) autocannons in the wings and two more 13.2 mm akan m/39A autocannons and a 20 mm akan m/41A in the nose. On the A-2 model the 20 mm akan m/41 was replaced with a belt fed Bofors designed 20 mm akan m/45. On the J 21A-3 (later designated A 21A) it was possible to load rockets and bombs of various sizes and types. Later in the Saab 21's service life the 13.2 mm akan m/39 autocannons were rebarreled to fire american 12.7x99 mm ammunition due to economics. This was not a bad change though as the 12.7 mm AP-rounds had better performance than the 13.2 mm AP rounds and the Saab 21 was basically only viable as an attacker after WWII due to the jet era. Role Fighter and attack aircraft Manufacturer SAAB Designer Frid Wänström First flight 30 July 1943 Introduction 1 December 1945 Retired 23 July 1954 Status Retired Primary user Swedish Air Force Produced 1945–49 Number built 298 Developed into Saab 21R Operational history On 1 December 1945, deliveries of the initial production model of the fighter, designated as the J 21A-1, commenced to the Swedish Air Force. Overall, 54 J 21A-1 fighters were constructed at SAAB's main plant in Trollhättan; deliveries of this model continued until 5 December 1946, by which point it had been superseded by improved models. The J 21A-1 model was quickly followed by another 124 and 119 examples of the improved J 21A-2, which featured a revised armament arrangement, and the B 21A-3, a dedicated fighter-bomber, respectively. The type was used by the Swedish Air Force alone. In total, 298 J 21As were constructed prior to the production line being closed down during 1948. During December 1945, F 8 Barkarby became the first fighter unit to receive the J 21. During the following year, other units of the Swedish Air Force, such as Göta Air Force Wing (F 9), also began to receive the type. However, within less than four years, some squadrons that had received the type were being re-equipped with a new generation of fighters harnessing jet propulsion for greater speed, such as the de Havilland Vampire. Despite the original intention for the type to be principally in air defence roles, in service, the J 21 was utilized mainly in the bomber role. According to Widfeldt, officials were often confused by its unconventional design and had doubts over the fighter's use and effectiveness. In response to feedback that sought alternative options, the Swedish Air Board approached SAAB with a request to conduct design studies into the proposed development of a front-engine replacement, which was referred to as the J 23. This aircraft shared the same DB 605B engine as the J 21, but had a more traditional appearance; Widfeldt observed that the J 23 concept was visually similar to the North American P-51 Mustang, he also noted that its projected performance was beneath that of the existing J 21, which had been a key factor in the decision to persist with efforts to improve the existing fighter instead. Over time, the Swedish Air Force had become increasingly interested in jet propulsion and, as early as 1945, SAAB had been examining prospective modifications of the airframe to accommodate a jet engine in place of its piston engine. While production line J 21A series aircraft were first selected for conversion, the initial piston-engine version continued in production in five series "batches" that were completed in 1948–49. As a result of the conversion programme, the iJ 21A was phased out after 1954. Specifications General characteristics Crew: one Length: 10.45 m (34 ft 3 in) Wingspan: 11.6 m (38 ft 0 in) Height: 3.97 (13 ft 0 in) Wing area: 22.2 m² (238.87 ft²) Empty weight: 3,250 kg (7,165 lb) Loaded weight: 4,150 kg (9,149 lb) Max. takeoff weight: 4,413 kg (9,730 lb) Powerplant: 1 × Daimler-Benz DB 605B, built by SFA. liquid-cooled, supercharged, 60° inverted V12 engine, 1,085 kW (1,455 hp / 1,475 PS) Performance Maximum speed: 650 km/h, 350 knots, 403 mph (fighter config), 560 kmh, 302 knots, 347 mph (attacker config) Cruise speed: 495 km/h (265 knots, 308 mph) Range: 750 km (466 mi) Service ceiling: 11,000 m (36,090 ft) Rate of climb: 15 m/s (2,950 ft/min) Armament J 21A-1 1× 20 mm akan m/41A with a 60 round drum magazine in the nose 2x 13.2 mm (0.53 in) akan m/39A with 350 rpg in the nose 2x 13.2 mm (0.53 in) akan m/39A with 325 rpg in the wings J 21A-2 & A-3 1× 20 mm akan m/45 with 140 rounds in the nose 2x 13.2 mm (0.53 in) akan m/39A with 350 rpg in the nose 2x 13.2 mm (0.53 in) akan m/39A with 325 rpg in the wings * |
Eh...repost of the Saab pics 2 [5/6] - The Saab B 18B at the Swedish Air Force Museum (2012).jpg (1/1) | Miloch | Aviation Photos | 0 | January 25th 19 03:13 PM |
Saab 18 pics 2 [4/5] - The Saab B 18B at the Swedish Air Force Museum (2012).jpg (1/1) | Miloch | Aviation Photos | 0 | January 25th 19 03:07 PM |
Saab 35 Draken pics 3 [2/5] - SAAB-210 performed around 1,000 test flights over four years.jpg (1/1) | Miloch | Aviation Photos | 0 | July 21st 18 02:18 PM |
Saab 29 Tunnan pics [1/9] - 118-J29F-roentgenskiss-SAAB.jpg (1/1) | Miloch | Aviation Photos | 0 | March 12th 18 03:01 PM |
Saab 17 pics 1 [04/12] - 157-B17-prototyp-17001-SAAB.jpg (1/1) | Miloch | Aviation Photos | 0 | May 7th 17 03:43 PM |
