Gear Warning Switches on a Mosquito
Old March 8th 05, 03:54 AM
scooter
Default Gear Warning Switches on a Mosquito
I'm going to install gear warning switches in my Mosquito. I'd
appreciate some advice on the location, type and mounting method of the
microswitches.
Thanks
Scott
Old March 8th 05, 01:55 PM
Bill Daniels
I've always preferred magnetic reed switches (~$2) since there is no contact
between the control system and the switch. The reed switch contacts are
hermetically sealed in 2" long 3/16th dia glass tubes so dirt can't
contaminate them. Additionally, they are unlikely to get out of adjustment.
I install the reed switch on the fuselage wall with either epoxy or outdoor
double sided foam tape. Then find the right place on a pushrod for the
little magnet that activates the switch then epoxy it in place.
Bill Daniels
"scooter" wrote in message
microswitches.
Thanks
Scott
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
