FAA regulations - W&B
Old March 8th 05, 06:46 PM
Arne
Default FAA regulations - W&B
In USA, if you are flying under Part 91 of the Federal Aviation Regulations
(FARs).
Are you required to perform weight and balance checks before every flight?
And if so, are you required to document it? Can the FAA show up on the ramp
asking you to show the weight and balance calculation?
Old March 8th 05, 06:56 PM
George Patterson
No. If I'm flying alone in an aircraft that has a useful load of over 800
pounds, it would be pretty silly to calculate W&B.
No. Even when I do a W&B calculation, it's on my computer at home and I don't
print them out. The FAA might ask you to perform one during a ramp check, but
you know how to do that, right?
George Patterson
I prefer Heaven for climate but Hell for company.
Old March 8th 05, 07:29 PM
Peter Duniho
"George Patterson" wrote in message
flight?
Sort of. The "weight" part is obviously satisfied, but the "balance" part
is not.
Of course, in most cases, a pilot will have done enough sample W&B
calculations to know when they need to consider the "balance" part for solo
or lightly loaded operations. This is probably true in your case as well.
But that doesn't mean you didn't do the "balance" part...it just means you
did it once (or a few times) and have applied the results to many subsequent
flights.
Even for the "weight" part, the few seconds it takes you to consider that
you're alone and well under the useful load of the aircraft would certainly
qualify as "perfoming a weight check". Just because you didn't write it
down or do formal calculations, that doesn't mean you didn't verify that you
were within the weight and balance envelope of the aircraft for that flight.
IMHO, the correct answer is "yes, you are required to perform weight and
balance checks before every flight". What those checks entail varies
according to the flight and prior experience with the aircraft. But a pilot
who can say, without making a (another) weight and balance calculation,
whether the aircraft is within limits or not has made a de facto check of
the weight and balance for that flight, whether or not they have made a
formal calculation using the exact fuel, oocupant, and cargo load for that
flight. (And conversely, a pilot who cannot make such a statement has not
fulfilled the preflight duties required of that pilot).
Bottom line: if you *know* that the aircraft is within the required limits,
then you've made the preflight weight and balance checks. And you ARE
required to *know* that the aircraft is within the required limits.
Pete
Old March 8th 05, 09:26 PM
George Patterson
This is not necessary with a Maule. You can load anything in the front seats up
to the point of MGW and stay within the envelope. This is also true of a Cessna
150. This is, in fact true of nearly every light aircraft.
I suppose you could argue that "enough sample W&B calculations" is 1 in those
cases, but I can't recall every doing any when I owned those planes. It was
pretty obvious from the fact that the front seats are right under the center of
lift.
George Patterson
Old March 8th 05, 09:42 PM
Peter Duniho
seats up
Cessna
Your statement was about aircraft generally with a useful load over 800
pounds, not about your Maule specifically. Additionally, I *will* argue
that the number of required previous calculations may only be one, but the
calculation is required.
Your statement that "this is, in fact true of nearly every light aircraft"
is false, unless you'd care to qualify "nearly" as differently than I
understand it (that is, only one or two aircraft would not be included).
Certainly there are plenty of light aircraft out there for which balance in
a lightly loaded airplane is still an issue. I'm sure I can find at least a
dozen if I tried, and I know of at least three off the top of my head, which
is a lot for someone like me who doesn't have anywhere close to an
encyclopedic knowledge of airplanes.
Pete
Old March 15th 05, 01:32 AM
Margy Natalie
In the Navion with the geared engine if I was flying solo I had to put fuel in the
baggage compartment tank to stay within W&B. Ron was ok by himself, I'm just too
light : - ). We will see what the W&B looks like with the new engine.
Margy
lift.
George Patterson
Old March 15th 05, 01:50 AM
Montblack
("Margy Natalie" wrote)\
fuel in the
just too
What's the update on your Navion?
Montblack
Old March 8th 05, 08:16 PM
John Galban
Really? I've never heard of this happening. Wouldn't they have to
carry a scale around with them? I, for one, weigh all my gear at home
(and perform the calculations at home). I carry the required W&B
documentation on board the airplane, but not a list of all the weights
of every item. The most I could give an inspector would be a figure
for the weight (fuel full and empty) and the arm.
Old March 8th 05, 09:25 PM
Brian
Actually I have heard of this happening, where an FAA inspector saw 5
guys with parachute rigs get into a 182 in preparation for a Skydive.
After the jump the inspector requested that the pilot show that he
airplane was being flown within the W&B limits. The pilot happily
complied and showed the inspector that the airplane was being flown
within limits. End of Story.
Brian
Old March 9th 05, 12:43 AM
Dave Stadt
"Brian" wrote in message
Brian
Not exactly reliable information. There are thousands of similar "I heard"
stories in aviation. A surprisingly large number of them are not true. Do
you have a reliable cite?
Same BA 747 loses engine again, Violated U.S. regulations Big John Piloting 3 March 8th 05 10:38 PM
Ultra light Glider regulations Denis G Soaring 5 May 24th 04 06:19 PM
ANN: WingX Version 1.2 - Federal Aviation Regulations on your PDA! Hilton Software LLC Piloting 7 October 17th 03 04:51 PM
New UK Regulations Soaring 5 October 2nd 03 12:13 AM
FAR:Safety Pilot & High Performance/Complex? John T Piloting 53 August 18th 03 04:04 PM
