There's a bug in the current CN2 software release that over time turns into a serious performance problem. The cause is simple: some of the diagnostic logging functions used in the software development process didn't get switched off for the public release. Over time, the diagnostic file gets big and the time required to append this file gets outrageous.
The work around is just as simple: run the updater as though you were adding waypoints or airspace (you don't need new files on the USB, just select e..g. "waypoints" and run the updater). This will remove the diagnostic files and restore performance. best regards, Evan Ludeman |
Thanks for that info Evan!
I noticed on my last flight that it took eternity for the CN2 to boot up. |
Thanks Evan.Â* I followed that advice last month at your suggestion.
Having spent a career as a systems engineer and my wife as a software and systems engineer, I just have to ask:Â* How about a new release with the diagnostic software turned off?Â* It's ridiculous to ask the customers to jump through hoops as a work around to poor configuration control. On 10/28/2019 6:08 AM, Tango Eight wrote: There's a bug in the current CN2 software release that over time turns into a serious performance problem. The cause is simple: some of the diagnostic logging functions used in the software development process didn't get switched off for the public release. Over time, the diagnostic file gets big and the time required to append this file gets outrageous. The work around is just as simple: run the updater as though you were adding waypoints or airspace (you don't need new files on the USB, just select e.g. "waypoints" and run the updater). This will remove the diagnostic files and restore performance. best regards, Evan Ludeman -- Dan, 5J |
I can't speak for Evan, but if I were in ClearNav's shoes, I'd worry about all of the non-technical users who tremble and groan each time they have to update to a new release. Asking them to perform an operation they're more comfortable with may be a nice interim solution until a new point release is justified for other reasons. Even if a new release is on the way, this gives users a quick solution until they can get help to do the update.
I'm not a ClearNav user (though I like my CNv vario) but each year we see posts from PowerFLARM owners who encounter problems updating their software--or who don't know how because they only do it once a year. To a systems engineer, this is trivial. Correction: it should be trivial. The most dangerous words in IT are "it SHOULD work" (followed closely by "that shouldn't happen," "never seen that before," and "works on my machine"). I've worked in IT for 20 years so I'm familiar with the gap in understanding between technical personnel and users. They just look at things differently and often with different skill sets and perspectives. If ClearNav users were all connected online and ClearNav could push a new release unilaterally, different story. If I were a ClearNav user, I'd be annoyed at the bug but happy there's a relatively easy workaround. Chip Bearden JB |
On Monday, October 28, 2019 at 5:08:34 AM UTC-7, Tango Eight wrote:
There's a bug in the current CN2 software release that over time turns into a serious performance problem. The cause is simple: some of the diagnostic logging functions used in the software development process didn't get switched off for the public release. Over time, the diagnostic file gets big and the time required to append this file gets outrageous. The work around is just as simple: run the updater as though you were adding waypoints or airspace (you don't need new files on the USB, just select e.g. "waypoints" and run the updater). This will remove the diagnostic files and restore performance. best regards, Evan Ludeman Didn't notice, updating airspace and waypoints regularly. Things change! Jim |
Glidersource ads- No response? | [email protected] | Soaring | 6 | July 24th 19 02:18 AM |
DG response re service fee | Mike Yankee | Soaring | 21 | January 11th 10 12:03 PM |
What is your response when... | Kyle Boatright | Piloting | 8 | January 6th 08 07:24 PM |
9-11 Response, was F-15 grounding | [email protected] | Piloting | 19 | January 4th 08 04:54 AM |
Response to CBS News | Bob | Piloting | 9 | January 17th 04 09:31 PM |
