For those that know the finer points..
Question. I understand to get maximum extra triangle points at the end of your flight you want to cross your release point, or Close Your Triangle. On my Oudie I have my OLC scored flight displayed with a yellow line, so I can see it in all the other clutter and information displayed. This summer while flying out of Salida I released and then flew to the clouds about 12 miles south to get to base, then I turned north for my first leg. My Yellow OLC scoring track line started where I turned north. When I finished my day I flew through the start of this line. Is this where I should have "Closed My Triangle" Or should I have Closed My Triangle where I released from Tow? Where I released from tow that day would have been hard to pinpoint exactly. So what is it? Start of scored flight or tow release point? And how close to I need to be to the correct point vertically and horizontally? Thanks in advance. |
On Sunday, November 10, 2019 at 3:05:46 PM UTC-7, Nick Kennedy wrote:
For those that know the finer points.. Question. I understand to get maximum extra triangle points at the end of your flight you want to cross your release point, or Close Your Triangle. On my Oudie I have my OLC scored flight displayed with a yellow line, so I can see it in all the other clutter and information displayed. This summer while flying out of Salida I released and then flew to the clouds about 12 miles south to get to base, then I turned north for my first leg. My Yellow OLC scoring track line started where I turned north. When I finished my day I flew through the start of this line. Is this where I should have "Closed My Triangle" Or should I have Closed My Triangle where I released from Tow? Where I released from tow that day would have been hard to pinpoint exactly. So what is it? Start of scored flight or tow release point? And how close to I need to be to the correct point vertically and horizontally? Thanks in advance. 4.3.2 FAI OLC Course (based on the FAI) If possible, three turn points are chosen on the recorded, closed flight path such that they define an FAI triangle with the greatest possible circumference, whereby - the shortest leg must be at least 28% of the FAI distance - if the FAI distance is 500 km or more, the shortest leg must be at least 25% and the longest leg at most 45% of the FAI distance. The departure point can be between two turn points of the triangle. The flight path is considered to be closed if the finish point is within 1 km of the start point, and the departure altitude is not more that 1000 m above the finish altitude. (Tip: If an FAI triangle is planned, a departure point should be defined before the flight, which can then be approached on the return flight.) Link to the rules...https://www.onlinecontest.org/olc-3....overview/b2_en Best. Tom #711. |
Nick-
I always try to close the triangle at my release point. The OLC scoring algorithm then has the most data points to calculate maximum triangle size. Your southward trip to the clouds would be included in the flight, so the extra leg PROBABLY would not have made any difference. I have tried to "out think" the OLC calculation by using SeeYou to pick other points that might exceed the OLC measurement, but I have NEVER been successful at coming up with a longer distance or larger triangle. As Tom noted above, the finish point must be within 1 km horizontally and no lower than 1 km below the start altitude. Unless you are regularly towing to the Moon, it is hard to finish 1000 m below release altitude. I try to make a mental note when I release and end my flight very near to that point. So far, it has worked for me. |
Nick, Your oudie will be able to record bread crumb track marks. Using these the point where you get off tow and make first turn in lift is very clearly defined. When you get back from the triangle just fly to the bread crumbs marking your first thermal. As the rules say, within 1 km up and sideways and you are done.
Not closing the triangle sucks. Do not ask how I know this. H On Sunday, November 10, 2019 at 5:05:46 PM UTC-5, Nick Kennedy wrote: For those that know the finer points.. Question. I understand to get maximum extra triangle points at the end of your flight you want to cross your release point, or Close Your Triangle. On my Oudie I have my OLC scored flight displayed with a yellow line, so I can see it in all the other clutter and information displayed. This summer while flying out of Salida I released and then flew to the clouds about 12 miles south to get to base, then I turned north for my first leg. My Yellow OLC scoring track line started where I turned north. When I finished my day I flew through the start of this line. Is this where I should have "Closed My Triangle" Or should I have Closed My Triangle where I released from Tow? Where I released from tow that day would have been hard to pinpoint exactly. So what is it? Start of scored flight or tow release point? And how close to I need to be to the correct point vertically and horizontally? Thanks in advance. |
Hey Boys
Thanks for all the good beta on my question! I appreciate it very much T |
Nick,
Couple more tips: 1- OLC miss recognize start point at about 30% of the time. I’ve seen many olc flights getting scored from takeoff. This can happen from multiple reasons, including going through sink in tow, or tow plane make a circle tight enough that OLC believe you released, or whenever OLC is not able to recognize your release it will pick your takeoff. So first and foremost always check that your start is indeed your release, and if not, change the soaring start time to release time. I wouldn’t be surprised if SeeYou mobile make the same errors, so you can’t completely trust the start point. 2- if you took a tow and then released and glided for some distance to the clouds, you should be able to recognize your release by the breadcrumb color. I believe all flight computers have the option to color your breadcrumbs based on climb rate. Lift is typically red and sink is blue so you can tell where you released. Ramy |
US race scoring question | [email protected] | Soaring | 0 | April 7th 19 02:31 PM |
Contest scoring question | Gary Adams | Soaring | 6 | July 6th 16 09:57 AM |
OLC Scoring Question | charlie foxtrot | Soaring | 6 | January 4th 06 11:25 PM |
OLC scoring - USA | Ian Cant | Soaring | 0 | November 28th 05 03:09 AM |
TAT scoring question | Mark Zivley | Soaring | 34 | September 6th 04 04:55 AM |
