Filling small holes in panel?
Old December 8th 19, 12:12 AM posted to rec.aviation.soaring
soaringjac
Default Filling small holes in panel?
Any recommendations on what to use to fill small holes in an aluminum panel?
Old December 8th 19, 12:24 AM posted to rec.aviation.soaring
soaringjac
Will bondo work?
Old December 8th 19, 01:21 AM posted to rec.aviation.soaring
TIG welder?
Old December 8th 19, 01:39 AM posted to rec.aviation.soaring
Tim Taylor
On Saturday, December 7, 2019 at 4:24:07 PM UTC-7, soaringjac wrote:
Will bondo work?
Bondo might work, but is brittle. You might want to look at an epoxy based filler that would be more flexible in the long run. AEROPOXY LIGHT from Spruce would likely be a better choice. For a few small holes you could try something like JB Weld. If you have some cotton flock, I would mix some with JB Weld and use that. It would provide an epoxy base with the structural strength of fiber to minimize cracking.
Old December 8th 19, 01:45 AM posted to rec.aviation.soaring
Tim Taylor
Will bondo work?
Just saw that JB Weld makes a putty: SteelStikā„¢ Epoxy Putty - 2 oz
Looks like it would work as well.
Old December 8th 19, 02:17 AM posted to rec.aviation.soaring
soaringjac
Will bondo work?
Cool thanks Tim! I might give that SteelStik a try
Old December 8th 19, 02:34 AM posted to rec.aviation.soaring
How about your Silver and Gold badges!?
Old December 8th 19, 03:52 AM posted to rec.aviation.soaring
Robert Palfreeman
How small?
Old December 8th 19, 05:38 AM posted to rec.aviation.soaring
soaringjac
How small?
about 3/8th
soaringjac
Well I used the SteelStik and that seems to have worked great so far! I guess we will see how it holds over time
How to determine if your ASG29 has the large or small panel? Sean Fidler Soaring 37 November 19th 14 07:50 PM
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 03:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 10:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 02:19 AM
Filling Holes AKperson Owning 1 July 20th 05 04:54 PM
