https://en.wikipedia.org/wiki/Ilyushin_Il-96
The Ilyushin Il-96 is a Russian quadjet long-haul wide-body airliner designed by Ilyushin in the former Soviet Union and manufactured by the Voronezh Aircraft Production Association in Russia. It is powered by four Aviadvigatel PS-90 two-shaft turbofan engines. The Ilyushin Il-96 is a shortened, long-range, and advanced technology development of the Soviet Union's first widebody airliner, the Ilyushin Il-86. It features supercritical wings fitted with winglets, a glass cockpit, and a fly-by-wire control system. It was first flown in 1988 and certified in 1992. The basic Il-96-300 is equipped with modern Russian avionics integrating six multi-function colour LCD displays, inertial and satellite navigation systems, and a Traffic Collision Avoidance System (including mode "S"). It allows the airplane to be operated with two crew members. The avionics correspond to modern requirements on international routes in Europe and North America (RNP-1) and allow navigation and landing under ICAO CAT III/A conditions. The Il-96 is offered in three main variants: the Il-96-300, Il-96M/T and Il-96-400. The Il-96-300 has a standard passenger capacity of 262 seats in a two-class configuration with 18 seats with a seat pitch of 54 inches (140 cm) and 244 seats with a pitch of 32 inches (81 cm), of which typical seating is 3-3-3 (layout), but low density seating is possible with 2-4-2 (layout). Galleys are positioned on the upper deck, and the lower deck can accommodate 18 LD-3 containers and crew rest areas. In June 2005, the Volga-Dnepr Group signed a 15-year financial agreement with Ilyushin Finance Corporation (IFC) to take delivery of two new-build Il-96-400T aircraft, to be operated by Volga-Dnepr's subsidiary AirBridge Cargo. The first was due to have been delivered in late 2006. Role Widebody jet airliner Manufacturer Voronezh Aircraft Production Association Design group Ilyushin First flight 28 September 1988; 30 years ago Introduction 29 December 1992 with Aeroflot Status In low-rate production, In service Primary user Cubana Produced 1992–present Number built 30 Unit cost US$ 40–50 million The Cuban Government newspaper Granma announced on 3 January 2006 the first official flight of the Cubana Il-96-300, from Havana to Buenos Aires, Argentina. On 11 August 2009 Russian Minister of Industry and Trade Viktor Khristenko announced that manufacturing of the Il-96-300 would cease. In particular, the Il-96-300 had been deemed inferior to counterparts from Boeing and Airbus, and the manufacturer could not arrange commercially viable mass production, making only one aircraft per year. The Il-96-400T cargo version was to remain in production. On 9 October 2015, it was announced that an updated version of the Il-96 may be produced. This decision was taken due to the current diplomatic situation between Russia and the West, and the dependency of the Russian Aerospace Industry on Airbus and Boeing. In September 2017, the Vice President of Russia's United Aircraft Corporation Aleksandr Tulyakov announced the start of development of the 250-280 seat, wide-body long-haul aircraft in partnership with Chinese builders. The aircraft is to be a development of the Russian-designed IL-96 and will be assembled in China. A new engineering center will be built in Russia to undertake technical and electronics production. Specifications Il-96-300 Length 55.3 m (181 ft 7 in) Span 60.11 m (197 ft 3 in) Wing area 350 m² (3767.9 ft²) Wing sweep 30° Flaps/Slats I – 2°/3° (275 KIAS), II 3°/25° (264 KIAS), III – 10°/25° (243 KIAS), IV – 25°/25° (210 KIAS) for Takeoff, V – 40°/25° (189 KIAS) for Landing Cabin width 5.70 m (18.70 ft) Fuselage Diameter 6.08 m (19.94 ft) Height 15.7 m (57 ft 7 in) Operating Empty Weight 120,400 kg (265,198 lb) Max. Zero Fuel Weight 180,000 kg (403,000 lb) 208,400 kg (459,030 lb) Max. Landing Weight 183,000 kg (403,083 lb) Max. Take-off Weight 250,000 kg (551,000 lb) Max. Payload 40,000 kg (88,105 lb) Takeoff Run at MTOW 2,340 m (7,677 ft) Landing Run 860 m (2,821 ft) Cruising speed 0.78 to 0.84 Mach or 850 to 870 km/h TAS (459 to 469 KTAS) Maximum speed (Vmo) 0.84 Mach or 900 km/h IAS (485 KIAS) Service ceiling 13,100 m (43,000 Ft) Cruise Altitude 9,000 to 12,000 m (29,527 to 39,370 Ft) Range with max. payload 11,500 km (6,209 nmi) 12,800 km (6,907 nmi) 5,000 km (2,699 nmi) 10,000 km (5,400 nmi) Range with max. fuel 13,500 km (7,289 nmi) 15,000 km (8,100 nmi) 12,000 km (6,479 nmi) 12,000 km (6,479 nmi) Max. Fuel capacity 152,620 l (40,322 US gal) Engines (x4) Aviadvigatel PS-90A Pratt & Whitney PW2037 Pratt & Whitney PW2337 or Aviadvigatel PS-90A1 Aviadvigatel PS-90A1 Thrust (x4) PS-90A: 156.9 kN (35,242 lb) N2:10,425 RPM 170.1 kN (38,250 lb) N2:12,360 RPM PW2337: 166.8 kN (37,500 lb) N2:12,360 RPM PS-90A1: 170.7 kN (38,326 lb) Engine Dry Weight (x4) 2,950 kg (6,497 lb) 3,314 kg (7,300 lb) PW2337: 3,314 kg (7,300 lb) 2,950 kg (6,497 lb) Cockpit crew Three Two Two (op. Three) * |
Ilyushin DB-3 pics 2 [3/7] - Ilyushin-DB-3-only-surviver-Central-Museum-Monino-Russia-03.jpg (1/1) | Miloch | Aviation Photos | 0 | October 1st 18 03:10 PM |
Ilyushin Il-18 / Il-20 / Il-22 pics [09/10] - Ilyushin Il-20M - Russia - Air Force (2).jpg (1/1) | Miloch | Aviation Photos | 0 | September 20th 18 03:18 PM |
Ilyushin Il-18 / Il-20 / Il-22 pics [08/10] - Ilyushin IL-18 cutaway drawing.jpg (1/1) | Miloch | Aviation Photos | 0 | September 20th 18 03:18 PM |
Ilyushin Il-28 pics 2 [2/3] - This is a Russian Ilyushin Il-28 'Beagle' bomber licence built in China as the Harbin (where the factory is) H-5..jpg (1/1) | Miloch | Aviation Photos | 0 | June 30th 18 02:51 PM |
Ilyushin Il-10 pics 2 [5/5] - Korean Ilyushin Il-10 Sturmovik.jpg (1/1) | Miloch | Aviation Photos | 0 | March 28th 17 03:22 PM |
