Speed of Heat
Old March 15th 05, 06:23 AM
vlado
Default Speed of Heat
Is there a rule of thumb for 'speed of heat'? Meaning the speed in
knots where ice will not form on the leading edges of a wing. For
example, the Saberliner had no de-ice or anti-ice system, just speeding
up would remove or prevent ice build up.
Thanks.
Old March 15th 05, 04:30 PM
Mike Rapoport
I don't know the formula but Saberliners are too slow to offer reliable
deicing from speed alone although, like anything else, they change temp with
velocity. I recall reading that you need 400kt indicated for complete
protection.
Mike
MU-2
"vlado" wrote in message
Thanks.
Old March 15th 05, 06:09 PM
Robert M. Gary
In the Citation the temp difference is about 4 degrees. I think it goes
up exponentially as you approach the speed of sound. You have to get
pretty close to the speed of sounds before you get much difference (I
think).
-Robert
Old March 15th 05, 06:57 PM
Don Hammer
I don't have a CR-2 with me, but it seems like the ram rise at M.82 is
about 7 deg C.
Icing conditions don't occur at flight levels for cruise anyway, so a
jet aircraft will only ice during climb, decent, or holding. If the
old gray matter serves me, I think Rockwell proved the aircraft could
fly acceptably with any ice load it was expected to encounter. The
type certificate for the military versions show them as VFR only when
operating in the civil system. I doubt seriously it could pass the
testing now required for certification. I seem to remember some de-ice
mods to later versions, but I'm not sure. They did de-ice the engines
and the windscreens are heated. Most of these aircraft are in the
scrap yard by now I would imagine.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old March 15th 05, 09:20 PM
Kurt R. Todoroff
about 7 deg C.
The Mach heating temperature rise ratio (T_t / T_s) at M0.82 is .13348
referenced to absolute temperature regardless of altitude and other
atmospheric conditions. For example, if the static air temperature
(T_s) is -40F, then the total temperature (T_t) is +16F. The Mach
heating formula is:
TAU = T_t / T_s = 1 + ((gamma-1)/2)M^2
For a typical atmospheric gamma value of 1.4, the equation reduces to:
T_t / T_s = 1 + .2M^2
Converting -40F to absolute:
-40 + 459 = 419R
Insert temperature and Mach into the formula:
T_t / T_s = 1 + .2 * .82^2 = 1.13448
And:
T_t = T_s * 1.13448 = 419 * 1.13448 = 475R = 16F
So, if the outside air temperature is -40F ambient (zero velocity), then
at M0.82 the total temperature would be +16F.
This is not correct. Icing conditions can and do occur at any altitude
in which visible moisture is present.
If the
Kurt Todoroff
Markets, not mandates and mob rule.
Consent, not compulsion.
Old March 16th 05, 07:10 AM
BTIZ
All of the others talk of temperature rise do to compressibility based on
mach number, but no one really addressed the speed accounting for friction
of air molecules on the sheet metal which warms the aircraft. War story
time, low level over the plains of eastern Montana, near Conrad and Havre
Bomb Plots (Radar Bomb Scoring sites) and the outside air temp was
about -15F, however, we were moving along at about .88mach at 500ft AGL, and
the skin temperature was about 100F, not a worry about accumulating icing.
Some one else referred to "Speed of heat" as being Mach 1, because most
aircraft need after-burner or "heat" (reheat) as the Brits would say.. to
make Mach1. BTDT
BT
Thanks.
Old March 16th 05, 09:20 PM
Kurt R. Todoroff
In article R5QZd.71896$Tt.15712@fed1read05,
make Mach1. BTDT
BT
Hi BT,
What were you flying? Most of my time is in the F-111D and the EF-111A.
I've also flown the F-15, C-130, C-141, KC-10, E-3. Did your aircraft
have a skin temperature indicator or a total temperature indicator?
Aircraft component heating is due to Mach compressibility, not skin
friction. I'm confident that your 100F value reflected total
temperature which is based on Mach compressibility.
The "speed of heat" received it's colloquial name because the speed of
sound is based only on the static temperature of the fluid medium, not
on pressure or density as is often mistakenly believed.
Kurt Todoroff
Old March 17th 05, 01:22 AM
BTIZ
Kurt, you may be correct, as it was about 12 yrs ago, been retired a few
years now.. I believe it was total temp... B-1B
BT
Hi BT,
Kurt Todoroff
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 01:47 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 09:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 09:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 03:24 AM
