Just got a 302 and playing with it at home (another few weeks till soaring
weather). My intended glider setup is 302 and ipaq with WinPilot (302 is an upgrade of my old system of Borgelt B50, Volkslogger and WinPilot on ipaq). I've hooked up an ipaq and connected with 302 via Cambridge IQ255 utility. "configure instrument" screen of the utility has several options not explained in the manual: - arrival radius - I'm assuming is a turnpoint cylinder radius (0.5km) - approach radius - ?? would it be a radius around a turnpoint I'd like 302 to decrease the logging interval to 1s? - goal height -?? What indications does the 302 give when approach radius and arrival radius are crossed? (with no 303 NAV). One more - what is "ASI zero offset"? Manual says it should be less than 1000, but gives no explanation of what it is... Thanks. Andy |
Are you connecting your PC to the instrument with a USB/Serial adaptor? Some
people have been having problems doing this with the C302, yet it works fine with the GPS-Nav. Nick. "Andy Smielkiewicz" wrote in message ink.net... Just got a 302 and playing with it at home (another few weeks till soaring weather). My intended glider setup is 302 and ipaq with WinPilot (302 is an upgrade of my old system of Borgelt B50, Volkslogger and WinPilot on ipaq). I've hooked up an ipaq and connected with 302 via Cambridge IQ255 utility. "configure instrument" screen of the utility has several options not explained in the manual: - arrival radius - I'm assuming is a turnpoint cylinder radius (0.5km) - approach radius - ?? would it be a radius around a turnpoint I'd like 302 to decrease the logging interval to 1s? - goal height -?? What indications does the 302 give when approach radius and arrival radius are crossed? (with no 303 NAV). One more - what is "ASI zero offset"? Manual says it should be less than 1000, but gives no explanation of what it is... Thanks. Andy |
I can not connect to PC (no serial port on mine and I didn't buy a
usb/serial adaptor). I use the ipaq version of the utility. Andy "Nick Gilbert" wrote in message ... Are you connecting your PC to the instrument with a USB/Serial adaptor? Some people have been having problems doing this with the C302, yet it works fine with the GPS-Nav. Nick. "Andy Smielkiewicz" wrote in message ink.net... Just got a 302 and playing with it at home (another few weeks till soaring weather). My intended glider setup is 302 and ipaq with WinPilot (302 is an upgrade of my old system of Borgelt B50, Volkslogger and WinPilot on ipaq). I've hooked up an ipaq and connected with 302 via Cambridge IQ255 utility. "configure instrument" screen of the utility has several options not explained in the manual: - arrival radius - I'm assuming is a turnpoint cylinder radius (0.5km) - approach radius - ?? would it be a radius around a turnpoint I'd like 302 to decrease the logging interval to 1s? - goal height -?? What indications does the 302 give when approach radius and arrival radius are crossed? (with no 303 NAV). One more - what is "ASI zero offset"? Manual says it should be less than 1000, but gives no explanation of what it is... Thanks. Andy |
| Iran's nuclear program | Thelasian | Military Aviation | 107 | August 31st 04 07:35 AM |
| SJSU Aviation Program Closure | Troy Towner | Owning | 0 | June 17th 04 08:51 AM |
| Army ends 20-year helicopter program | Garrison Hilliard | Military Aviation | 12 | February 27th 04 08:48 PM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
