Future has arrived
Old January 3rd 20, 03:37 PM posted to rec.aviation.soaring
kinsell
Default Future has arrived
https://www.youtube.com/watch?v=X_dnAD5TD-E
Makes you want to fit some floats on an Antares and give it a go!
Old January 4th 20, 02:58 AM posted to rec.aviation.soaring
Andrzej Kobus
He must be dreaming. Fuel cost is at most 25% of airline's cost.
Old January 4th 20, 04:17 AM posted to rec.aviation.soaring
Let's talk about how much fuel it takes to get an airliner from Point A to Point B. You want to climb above the weather (30,000 ft. or more), you want to haul enough passengers and their stuff to pay the cost of doing business, the airplane, the crew, the maintenance, the insurance, and all the rest of what makes a business run and an airplane fly.
What are you going to use to make this happen? Jet-A1 (or JP-4 or Kerosene, or diesel, or whatever other petrochemical compound) with a sufficient energy density to lift its own weight plus the mass of the airplane and payload and keep it aloft until Point B is reached (with a significant fuel reserve because **** happens).
You want electric airplanes that will do the same thing? Not likely. The energy density of the most powerful battery bank is still nowhere near sufficient enough to allow an airplane (even Light Sport Aircraft) to take off, climb to altitude, cruise for long distance and carry anything but batteries..
Yes, battery technology is improving, and quickly. But the actual laws of physics take over and determine the maximum output and duration of every chemical battery.
"$200,000 worth of Tesla batteries, which collectively weigh over 20,000 pounds, are needed to store the energy equivalent of one barrel of oil." (from the Manhattan Institute study on the economic cost of "Green Energy."
https://www.manhattan-institute.org/...ear-impossible
As soaring pilots, we recognize, appreciate, analyze and utilize "free" atmospheric energy. But we also recognize the limitations of our technology when the energy suddenly (or gradually) diminishes or disappears. Trying to legislate and force an unreliable and wildly expensive form of unreliable energy on an energy dependent populace for political gain will doom a large portion of the world to starve to death in the dark.
Old January 4th 20, 04:42 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
In the context of the Harbor Air efforts, most their flights are only 30 minutes,
so they don't need huge batteries. The AOPA article (or maybe it was an EAA
article) had details that indicated the one hour flight time target was feasible
and economic. They are doing this to improve their business operation, and not
because it was forced on them.
In the soaring context, electric self-launchers offer good or better launching
power, less maintenance, and easier operation for similar purchase cost. They
don't have the self-retrieve range of the gas powered gliders, but my 25 years of
self-launching experience showed I rarely use much of that available range.
wrote on 1/3/2020 8:17 PM:
**** happens).
chemical battery.
Old January 4th 20, 03:26 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
but batteries.
Energy."
https://www.manhattan-institute.org/...volution-near-
impossible
Interesting stuff.
The future of electric air transport may well turn out to be something
like an Airlander with an outer skin covered with lightweight solar cells:
https://www.hybridairvehicles.com/ou.../airlander-10/
The Airlander 10 is a direct derivative of the P-791 project:
http://www.youtube.com/watch?v=hVNV-FFUOnc
Martin | martin at
Gregorie | gregorie dot org
Old January 4th 20, 04:09 PM posted to rec.aviation.soaring
Yeah, I am really looking forward to a six day trip to New Zealand at 20,000 feet, through all of the lovely tropical storms over the Pacific. And helium is so plentiful, too!
Old January 4th 20, 05:12 PM posted to rec.aviation.soaring
Indeed, but probably not as high as 20,000 - I'd guess 8000 - 10,000 to
avoid presurised cabins, which are both heavy and need energy to compress
the incoming fresh air. OTOH, pax would most likely have bunks/bars/space
to move round rather than the less than wonderful seats I've travelled in
(apart from the A380, which has really nice seats even in cattle-class).
True enough, though IIRC these beasts can transfer their helium between
lift bags and storage tanks, i.e. no valving off helium when they land,
and they do use a reasonable amount of aerodynamic lift as well as
gasbags. There are other similar projects, e.g.
http://aeroscraft.com/
https://www.varialift.com/
that will also use some aerodynamic lift and will look and fly quite like
the Airlander.
But, my main point was that something like these aircraft, but using
electric motors instead of the IC engines in the current prototypes, need
a lot less power stored in heavy batteries than anything that depends
entirely on aerodynamic lift.
Airbus and Rolls Royce are retrofitting a BA 146 as a test-bed for using
electric ducted fans as potential replacements for high bypass jet
engines, BUT they will be powering the fan(s) from a 2MW gas turbine
generator in the rear fuselage. It would take a shed load of batteries to
replace that generator, so its not at all clear where the electric energy
needed to power an all-electric Airbus 320 or Boeing 787 would be stored
or how it would be generated in flight. Portable fusion generator
anybody?
Martin | martin at
Old January 4th 20, 11:08 PM posted to rec.aviation.soaring
kinsell
I'm just not seeing the rapid progress in battery technology. Hardly
any improvement in Li-ion performance in the last ten years.
What has improved has been the imagination shown in the press releases.
IBM is claiming they'll be able to extract three mystery chemicals from
seawater and build a battery that beats the li-ion chemistries.
In Colorado, Bye Aerospace keeps designing electric planes that aren't
quite viable with current batteries, but don't worry in a couple years
some revolutionary battery will come along to make it all work. They've
been milking that story for as long as I can remember. They're claiming
electric planes similar to C172's will offer a breathtaking 80%
reduction in operating costs. Almost sounds too good to be true.
Old January 5th 20, 03:09 AM posted to rec.aviation.soaring
If it came out of George Bye's mouth, it is definitely too good to be true.
The Oudies Have Arrived Paul Remde Soaring 14 April 19th 10 02:32 PM
Before Help Arrived Mitchell Holman Aviation Photos 15 January 18th 09 11:36 AM
The ethanol nightmare has arrived! Al[_2_] Piloting 210 April 24th 08 03:27 PM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Military Aviation 1 May 27th 04 09:42 PM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Naval Aviation 1 May 27th 04 09:42 PM
