Sailplane Refinishing Advice - 1973 Berkshire Concept 70
Old January 9th 20, 05:54 AM posted to rec.aviation.soaring
Shaun Wheeler
Default Sailplane Refinishing Advice - 1973 Berkshire Concept 70
Looking for advice on a refinish. I don't have Bob Ireland's excellent contacts in the sailplane business so I'm working at a disadvantage. He owns one of the few remaining (total of 7) flyable examples.
I've read about people bundling sailplanes up to get them repainted in South America but can't see any details on how they went about it or what the price was. I know this isn't like painting a metal powered aircraft so that rules out the closest aircraft paint shops to where I live.
So far my options seem to be drag it out West or back East (I live in Tennessee) to get it done. I do have a shop but I've never repainted anything fiberglass bigger than a motorcycle and that was almost 30 years ago.
If Bob would make me a deal on his I'd come buy it but I'd be willing to bet he's planning on flying it this next season
It's not that I can't manage to come up with 25 grand to paint it, I'm just a little hesitant when I see sailplanes that are current and inspected for less.
The factory moulds for these are long gone. I don't know of anybody who's made templates.
What's the best fix short of find another used sailplane to stick in the trailer?
Old January 9th 20, 02:44 PM posted to rec.aviation.soaring
Papa3[_2_]
Old January 10th 20, 12:41 AM posted to rec.aviation.soaring
Bob Kuykendall
I'd suggest seeking out Tony Condon or Steven Leonard and picking their brains. Between them they have a lot of practical experience doing worklike refinish projects with relatively simple tools and processes. Also, Bryan Evans can give you some good pointers, he probably built your ship in Zimmerman's shop.
Of course, it all depends on what the current condition is and what you're trying to achieve. But assuming that you have a lot of cracking and checking gelcoat, typical basic steps a
[Warning: I am not an expert. I have done this exactly once. It turned out OK.]
* Sanding all the bad gelcoat off, probably all the way down to (but not into!) the fiberglass (this part I've done on several gliders back when I was young)
* Inspecting the inevitable un-logged repairs to make sure they are not dangerous
* Spraying the glider with a primer/filler such as Duratec (we use their vinylester primer on the HP-24s; good stuff)
* Sanding the primer/filler smooth and wave-free up to 220 grit (you want it that rough so the finish paint has some texture to stick to)
* Getting your favorite car painter to spray it with a seal coat and three wet coats of Toyota White acrylic urethane. They'll tell you they can do it with a fog coat and two light coats, because they're spring-loaded to try to conserve expensive paint while keeping orange peel and finish work down to a minimum. But the difference is that a Camry or Lexus doesn't need laminar flow. Get those three wet coats and pay extra if you have to, tell them it's OK if there are a few runs.
* Wet sanding the urethane 800 grit almost to the bottom of the orange peel, then on up through the grades to 2500, using primarily diagonal strokes and progressively smaller sanding blocks. On the leading edge you'll carefully use a diagonal half-strop motion, always working with one grade finer grit than the rest of the wing. It's too easy to sand right through the finish paint on the leading edge.
* Buffing and polishing with a rotary polisher, taking care to angle it so you always sweep off of trailing edges, never onto them. You can tear up a control surface or surface cover really badly that way.
* Always judging your work under sunlight, never under fluorescent lights. Fluorescent photons are the cruelest, they show every tiny flaw.
--Bob K.
Old February 26th 21, 10:55 PM posted to rec.aviation.soaring
Jerry Boone
* Always judging your work under sunlight, never under fluorescent lights.. Fluorescent photons are the cruelest, they show every tiny flaw.
--Bob K.
Excellent recap, Bob. I enjoy refinishing gliders, and vehicles. I'm on my 4th glider now. It can be tiring. Gelcoat is the most demanding by far. I find it helpful to take a year or more off between these projects to "forget" the sweat equity it demands. I especially like your "un-logged repairs" comment, too true.
Jerry Boone
@Sunflower
Zuni 22DZ & 859GS, Duster 38JS
Old January 10th 20, 02:53 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
http://www.craggyaero.com/ventus.htm
Richard
www.craggyaero.com
Old January 10th 20, 03:37 AM posted to rec.aviation.soaring
Brian Evans is back east now in Tennessee near Chilhowee, so you might want to look him up. As Bob said, he probably had a hand in building your glider. Also Richard's video history of the refinish process is great. Good Luck.
Old January 11th 20, 10:58 PM posted to rec.aviation.soaring
son_of_flubber
I guess you want to do the refinish it as a sentimental labor of love, or preserve history, or just for the hell of it. If you don't feel that way, maybe you should sell it (now and as-is) to someone who does feel that way.
What are you hoping it will be worth resale after you spend $25K on it? Are there any buyers?
New Concept for Sailplane "racing" Steve Leonard[_2_] Soaring 16 December 13th 18 06:28 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
