I just started pimping out my ASW20. I am putting in a LXNAV S100, FLARM and an ADS-B Trig transponder. Thant’s three puck antennas and I haven’t even figured out where to put the FLARM antennas yet! Does anyone have a good solution?
On Friday, January 10, 2020 at 6:22:22 PM UTC-8, Charles Longley wrote:
I just started pimping out my ASW20. I am putting in a LXNAV S100, FLARM and an ADS-B Trig transponder. Thant’s three puck antennas and I haven’t even figured out where to put the FLARM antennas yet! Does anyone have a good solution? I've been using a MECA divider for several years now. Besides the panel being less crowded, GPS satellites aquire much faster. Don't use DC blockers. Use a 12v GPS antenna to feed the divider. This way if your primary device fails, you don't lose all of them. Search for GPS divider in the subject, links were posted on a previous thread. Jim |
I just started pimping out my ASW20. I am putting in a LXNAV S100, FLARM and an ADS-B Trig transponder. Thant’s three puck antennas and I haven’t even figured out where to put the FLARM antennas yet! Does anyone have a good solution? Charles, Cables and combiners on the bottom of this page. http://www.craggyaero.com/antennas.htm Richard www.craggyaero.com |
I like your idea best Richard. I’ll give you a call next week.
On Friday, January 10, 2020 at 9:22:22 PM UTC-5, Charles Longley wrote:
I just started pimping out my ASW20. I am putting in a LXNAV S100, FLARM and an ADS-B Trig transponder. Thant’s three puck antennas and I haven’t even figured out where to put the FLARM antennas yet! Does anyone have a good solution? Too many puck GPS antennas too close together will lead to interference and poor function. I remember reading somewhere that these puck antennas must be 30 inches apart to help reduce the possibility of such interference. |
What brand/model 12v GPS antenna is being used, reasons?
R |
On Saturday, January 11, 2020 at 9:49:32 AM UTC-8, wrote:
What brand/model 12v GPS antenna is being used, reasons? R Linx Antenna Factor ANT-GPS-SH-SMA (with SMA connector) ANT-GPS-SH-MCX (with MCX connector) ANT-GPS-SH-MMX (with MMCX connector) Each GPS engine provides phantom power, and the voltage from each is added. If you use a standard puck the voltage from 2 or 3 engines will be too high. The Linx has higher gain with higher phantom voltage (up to 12v). System Gain: 28dB (typ. includes 4dB cable & filter loss) Noise Figu 1.8dB @ fo, 2dB max. Input Voltage: +2.5VDC to +12VDC Jim |
On Saturday, January 11, 2020 at 12:31:14 PM UTC-8, JS wrote:
On Saturday, January 11, 2020 at 9:49:32 AM UTC-8, wrote: What brand/model 12v GPS antenna is being used, reasons? R Linx Antenna Factor ANT-GPS-SH-SMA (with SMA connector) ANT-GPS-SH-MCX (with MCX connector) ANT-GPS-SH-MMX (with MMCX connector) Each GPS engine provides phantom power, and the voltage from each is added. If you use a standard puck the voltage from 2 or 3 engines will be too high. The Linx has higher gain with higher phantom voltage (up to 12v). System Gain: 28dB (typ. includes 4dB cable & filter loss) Noise Figu 1.8dB @ fo, 2dB max. Input Voltage: +2.5VDC to +12VDC Jim Dear customer, Linx Technologies is announcing the end-of-life of the ANT-GPS-SH-SMA, ANT-GPS-SH-MCX and ANT-GPS-SH-MMX Series of antennas, and the launch of the SH2 Series GPS antennas.Key components critical to the design of the SH Series antennas have been discontinued by the IC manufacturer. SH2 Series are DC 5V Richard |
wrote on 1/11/2020 9:49 AM:
What brand/model 12v GPS antenna is being used, reasons? The ones supplied with Powerflarm core, Cambridge 302, and ClearNav. Later, I removed the 302 and put in a Butterfly vario, using it's supplied GPS antenna. Everything seemed to work the same. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
| Antennas! Get yer antennas here! | Bob (not my real pseudonym) | Aviation Photos | 0 | March 3rd 11 05:38 AM |
| Antennas | [email protected] | Home Built | 1 | February 19th 09 08:32 PM |
| Aircraft antennas | ccwillwerth | Home Built | 23 | October 26th 06 11:30 PM |
| Antennas | Terry | Home Built | 3 | April 24th 05 07:42 PM |
| Antennas | Terry | Home Built | 3 | April 22nd 05 04:14 AM |
