more at
https://gizmodo.com/a-tiny-drone-car...-th-1835201423 ---- https://vimeo.com/331880754 It’s one thing to pilot a drone along a picturesque coastline, capturing breathtaking footage you could never get on the ground. But it takes an entirely different level of skill to pilot a drone through intricate dinosaur skeletons inside a museum. So how do you squeeze a flying camera through such narrow obstacles? In addition to steady hands on the controls, you need some heavily customized hardware. There’s no shortage of tiny drones on the market at this point, but it’s hard to find one that’s maneuverable, responsive, and one that includes a high-quality camera on board. So Robert McIntosh designed and built his own which uses four closely packed propellers that each barely measure a few inches in size. In addition to a low-quality streaming camera that allows the craft to be piloted from a first-person perspective using a pair of video goggles, the drone also carries a GoPro 6 for capturing 4K footage of every flight. To save weight, the drone’s onboard GoPro camera was stripped to its bare essentials. A stock GoPro 6 weighs in at 115 grams, while a stripped GoPro 6 attached to this drone weigh just 120.3 grams. Dealing with weight is the biggest challenge for a tiny drone like this. The lighter you can make it, the easier it is to fly. So to incorporate a 4K camera, the GoPro 6 was stripped of its protective housing, right down to its basic electronics and power components. For comparison; a stock GoPro 6 weighs in at 115 grams, but the entire micro drone McIntosh built, including the barebones GoPro, weighs just a little more at 120.3 grams. The craft also ends up with a much smaller footprint, which is important when you’re trying to fly it right through the dinosaur skulls in the Natural History Museum of Utah’s collection. The hardware is only half of the equation when it comes to capturing a video as impressive as this. Simple tricks like reversing the footage of the flight helps make it even more compelling as the viewer can’t see where the drone is headed, but even the best drone pilots in the world can’t keep their crafts perfectly steady. To achieve the smooth results seen in this museum fly through, a stabilization software called ReelSteady GO was used during post-production. Stabilizing footage usually requires a piece of software to first analyze and track the movements of a clip; detecting jitters, bumps, and vibrations which are then canceled-out by applying the same movements in reverse. The results can be good, but ReelSteady GO streamlines the process by instead relying on the motion data that a GoPro camera’s gyroscope captures during each recording. It not only provides more accurate data about how the camera is getting bumped around, it also eliminates the time-consuming process of having to first analyze unsteady footage. For comparison, here’s the raw footage of that museum flight, minus any stabilization: --- https://vimeo.com/331880514 * |
Air Force Wanted To Turn Skunk Works' Mach 3 Capable Recon Drone Into A Nuclear Bomber - An M-21 carrying a D-21 during a flight test..jpg ... | Miloch | Aviation Photos | 0 | March 29th 19 03:18 AM |
Messerschmitt Me 163 Komet pics [6/6] - Me 163B, Werknummer 191914, at the Canada Aviation and Space Museum. The tiny propeller drives a ram air turbine that provided electrical power..jpg (1/1) | Miloch | Aviation Photos | 0 | February 8th 19 04:16 PM |
These tiny drones can lift 40 times their own weight - tiny drone.jpg | Miloch | Aviation Photos | 0 | October 27th 18 06:39 PM |
Pima museum [23/45] - AQM-34C Drone DSC_3215.jpg (1/1) | Indrek | Aviation Photos | 0 | December 23rd 10 12:50 AM |
