Retracting & rotating main U/C
Old January 27th 20, 07:53 AM posted to rec.aviation.soaring
Default Retracting & rotating main U/C
Hi, is anyone able to point me in the direction of pictures or patent number that describe the retracting & rotating main wheel of the SZD Cobra or the Grob Twin II A? Regards Mark
Old January 28th 20, 05:10 AM posted to rec.aviation.soaring
Tango Whisky
Patents run for 20 years, so anything connected to Grob gliders will have expired long ago.
Old January 28th 20, 05:20 AM posted to rec.aviation.soaring
Dave Nadler
On Tuesday, January 28, 2020 at 12:10:26 AM UTC-5, Tango Whisky wrote:
...anything connected to Grob gliders will have expired long ago.
Except mostly for those G103s ;-)
Think they'll last as long as the 2-33s?
AS
...... unless they get renewed.
Uli
'AS'
Old January 28th 20, 01:58 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 28 janvier 2020 06:20:29 UTC+1, AS a écritÂ*:
Uli
'AS'
You can't renew a patent after 20 years. It becomes public domain, and that's it.
Old January 28th 20, 06:15 PM posted to rec.aviation.soaring
AS
Uli
'AS'
TW - that is generally correct and after 20 years, there is rarely any interest in continuing any protection. But sometimes, there is and a good patent attorney will figure out how to revitalize that protection by adding new aspects to the process or invention. It becomes basically a new patent that tries to cover as much of the old stuff which wasn't disclosed before plus the new stuff. That's why good patent attorneys make the big bucks they typically do. ;-)
Uli
'AS'
Old January 28th 20, 07:22 PM posted to rec.aviation.soaring
I use Google Patents for a lot of searches.
Try this link for the Grob patent; https://patents.google.com/patent/DE...ng+Grob&page=2
Good luck!
Old January 30th 20, 03:34 AM posted to rec.aviation.soaring
Garrett McEwen
That mechanism showed up for the Twin III, and is for the nosewheel steering. The OP is asking about that thing in the Twin Astir that makes the instructor's hips sore.
Old January 30th 20, 05:11 AM posted to rec.aviation.soaring
Haven
Grob devised a novel retraction system for the Twin Astir. The single wheel was designed to rotate 90° sideways before retracting "flat" under the rear seat, resulting in a rather unusual seating position. This was only incorporated in early examples, later on, the wheel was fixed.
Airbus Beluga pics 2 [4/8] - Side view, climbing with gear retracting.jpg (1/1) Miloch Aviation Photos 0 February 13th 18 03:26 PM
Self Retracting Aero Tow Rope? [email protected] Soaring 10 April 9th 14 11:59 AM
EAA 2009 08 White Knight 2 demo at Oshkosh, gear retracting.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 28th 09 11:16 PM
are "counter-rotating" and "contra-rotating" interchangeable terms? buttman Piloting 10 November 11th 06 03:47 PM
Ground cable reel, retracting jerry wass Aviation Marketplace 0 April 8th 06 03:53 AM
