https://en.wikipedia.org/wiki/Eurofighter_Typhoon
The Eurofighter Typhoon is a twin-engine, canard–delta wing, multirole fighter. The Typhoon was designed originally as an air superiority fighter and is manufactured by a consortium of Airbus, BAE Systems and Leonardo that conducts the majority of the project through a joint holding company, Eurofighter Jagdflugzeug GmbH formed in 1986. NATO Eurofighter and Tornado Management Agency manages the project and is the prime customer. The aircraft's development effectively began in 1983 with the Future European Fighter Aircraft programme, a multinational collaboration among the UK, Germany, France, Italy and Spain. Disagreements over design authority and operational requirements led France to leave the consortium to develop the Dassault Rafale independently. A technology demonstration aircraft, the British Aerospace EAP, first took flight on 6 August 1986; the first prototype of the finalised Eurofighter made its first flight on 27 March 1994. The aircraft's name, Typhoon, was adopted in September 1998; the first production contracts were also signed that year. Political issues in the partner nations significantly protracted the Typhoon's development; the sudden end of the Cold War reduced European demand for fighter aircraft, and debate existed over the aircraft's cost and work share. The Typhoon entered operational service in 2003; it has entered service with the air forces of Austria, Italy, Germany, the United Kingdom, Spain and Saudi Arabia. The air forces of Oman, Kuwait and Qatar are export customers, bringing the procurement total to 599 aircraft as of 2016. The Eurofighter Typhoon is a highly agile aircraft, designed to be a supremely effective dogfighter in combat. Later production aircraft have been increasingly better equipped to undertake air-to-surface strike missions and to be compatible with an increasing number of different armaments and equipment, including Storm Shadow and the RAF's Brimstone. The Typhoon had its combat debut during the 2011 military intervention in Libya with the UK's Royal Air Force and the Italian Air Force, performing aerial reconnaissance and ground-strike missions. The type has also taken primary responsibility for air-defence duties for the majority of customer nations. Role Multirole fighter National origin Multi-national Manufacturer Eurofighter Jagdflugzeug GmbH First flight 27 March 1994 Introduction 4 August 2003 Status In service Primary users Royal Air Force German Air Force Italian Air Force Spanish Air Force See Operators below for others Produced 1994–present Number built 558 Unit cost €90 million (system cost Tranche 3A) £125 million (including development + production costs) Developed from British Aerospace EAP Variants Eurofighter Typhoon variants The Typhoon's combat performance, compared to the F-22 Raptor and F-35 Lightning II fighters and the French Dassault Rafale, has been the subject of much discussion. In March 2005, United States Air Force Chief of Staff General John P. Jumper, then the only person to have flown both the Eurofighter Typhoon and the Raptor, talked to Air Force Print News about these two aircraft. He said, The Eurofighter is both agile and sophisticated, but is still difficult to compare to the F/A-22 Raptor. They are different kinds of airplanes to start with; it's like asking us to compare a NASCAR car with a Formula One car. They are both exciting in different ways, but they are designed for different levels of performance. …The Eurofighter is certainly, as far as smoothness of controls and the ability to pull (and sustain high G forces), very impressive. That is what it was designed to do, especially the version I flew, with the avionics, the color moving map displays, etc. – all absolutely top notch. The maneuverability of the airplane in close-in combat was also very impressive. The F/A-22 performs in much the same way as the Eurofighter. But it has additional capabilities that allow it to perform the [U.S.] Air Force's unique missions Specifications General characteristics Crew: 1 (operational aircraft) or 2 (training aircraft) Length: 15.96 m (52.4 ft) Wingspan: 10.95 m (35.9 ft) Height: 5.28 m (17.3 ft) Wing area: 51.2 m² (551 sq ft) Empty weight: 11,000 kg (24,000 lb) Loaded weight: 16,000 kg (35,270 lb) Max. takeoff weight: 23,500 kg (51,800 lb) Fuel capacity: 5,000 kg (11,020 lb) internal Powerplant: 2 × Eurojet EJ200 afterburning turbofan Dry thrust: 60 kN (13,500 lbf) each Thrust with afterburner: 90 kN (20,230 lbf) each Performance Maximum speed: At altitude: Mach 2 class (2,495 km/h or 1,550 mph at 10,975m altitude) At sea level: Mach 1.25 (1,530 km/h or 950 mph) Supercruise: Mach 1.5 Range: 2,900 km (1,800 mi) Combat radius: (with 3 × external 1,000 l tanks) Ground attack, lo-lo-lo: 601 km (325 nmi) Ground attack, hi-lo-hi: 1,389 km (750 nmi) Air defence with 3-hr combat air patrol: 185 km (100 nmi) Air defence with 10-min. loiter: 1,389 km (750 nmi) Ferry range: 3,790 km (2,350 mi; with 3 × drop tanks) Service ceiling: 19,812 m (65,000 ft) Rate of climb: 318 m/s (62,600 ft/min) Wing loading: 312 kg/m² (63.9 lb/ft²) Thrust/weight: 1.15 (interceptor configuration) g-load limits: +9 g to -3 g Brakes-off to Take-off acceleration: 8 s Brakes-off to supersonic acceleration: 30 s Brakes-off to Mach 1.6 at 11,000 m (36,000 ft): 150 s Armament Guns: 1 × 27 mm Mauser BK-27 revolver cannon with 150 rounds Hardpoints: Total of 13: 8 × under-wing; and 5 × under-fuselage pylon stations; holding in excess of 9,000 kg (19,800 lb) of payload Typical multi-role configuration for a Tranche 2-P1E would be 4 × AMRAAM, 2×ASRAAM/IRIS-T, 4 × EGBU-16/Paveway-IV, 2 × 1000-litre supersonic fuel tanks and a targeting pod. Missiles: Air-to-air missiles: AIM-120 AMRAAM (AIM-120C-5/7 planned for P2E) AIM-132 ASRAAM AIM-9 Sidewinder IRIS-T MBDA Meteor Air-to-surface missiles: AGM-65 Maverick AGM-88 HARM Brimstone Taurus KEPD 350 Storm Shadow/Scalp EG SPEAR 3 (planned) Marte ER anti-ship missile Joint Strike Missile (planned) Bombs: Paveway II/III/Enhanced Paveway series of laser-guided bombs (LGBs) 500-lb Paveway IV Small Diameter Bomb (planned for P2E) Joint Direct Attack Munition (JDAM), in the future HOPE/HOSBO, in the future Spice 250 Others: Damocles (targeting pod) LITENING III laser targeting pod Sniper Advanced Targeting Pod Up to 3 × drop tanks for ferry flight or extended range/loitering time Conformal fuel tanks on Tranche 3 or later Avionics Euroradar CAPTOR Radar Passive Infra-Red Airborne Tracking Equipment Praetorian DASS * |
Paintjobs 12 - Eurofighter Typhoon 1.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | November 13th 14 12:52 PM |
UK2 ZH588 Eurofighter Typhoon.jpg | Joseph Testagrose | Aviation Photos | 0 | July 5th 12 12:39 PM |
Eurofighter Typhoon | Glenn[_2_] | Aviation Photos | 0 | December 10th 09 06:48 AM |
Eurofighter EF-2000 Typhoon | Glenn[_2_] | Aviation Photos | 3 | October 9th 09 05:58 PM |
Eurofighter Typhoon Simulator | rottenberg | Simulators | 0 | November 2nd 04 09:02 PM |
