This BOLD thrill seeker sure has a lot of fun; I hope he lives to be
an OLD airman. ------------------------------------------------- I FLEW MY AIRPLANE TO 17000 FEET! Jul 16, 2019 Jonas Marcinko I took a trip to New Mexico and filmed along the way and on the way back I was able to reach 17000 Feet in my Capella aircraft. I was on supplemental oxygen during my time over 12500 ft. My Capella has a Rotax 912 engine. it is a tailwheel airplane. https://youtu.be/ObygtveJrhc ------------------------------------------------------- At 9:09 minutes into the video have a look at his altimeter. I don't see any evidence of O2 equipment. At this point in his video [9:51]: https://youtu.be/ObygtveJrhc?t=591 he would appear to be in violation of: https://www.ecfr.gov/cgi-bin/text-id...1.3.10&idno=14 Code of Federal Regulations §91.155 Basic VFR weather minimums. PART 91—GENERAL OPERATING AND FLIGHT RULES (a) Except as provided in paragraph (b) of this section and §91.157 [Special VFR], no person may operate an aircraft under VFR when the flight visibility is less, or at a distance from clouds that is less, than that prescribed for the corresponding altitude and class of airspace in the following table: Class G: More than 1,200 feet above the surface and at or above 10,000 feet MSL Flight visibility: 5 statute miles Distance from clouds: 1,000 feet below. 1,000 feet above. 1 statute mile horizontal. --------------------- JONAS LEE MARCINKO 382 E 475 N FIRTH ID 83236-1216 County: BINGHAM Country: USA Medical Information: Medical Class: Third Medical Date: 8/2017 BasicMed Course Date: None BasicMed CMEC Date: None Certificates PRIVATE PILOT Certificates Description Certificate: PRIVATE PILOT Date of Issue: 4/4/2015 Ratings: PRIVATE PILOT AIRPLANE SINGLE ENGINE LAND Limits: ------------------- https://registry.faa.gov/aircraftinq...umbertxt=7143A FAA REGISTRY N-Number Inquiry Results N7143A has Assigned/Multiple Records Data Updated each Federal Working Day at Midnight Aircraft Description Serial Number 027 Status Valid Manufacturer Name JONAS MARCINKO Certificate Issue Date 11/25/2014 Model XLS Expiration Date 11/30/2020 Type Aircraft Fixed Wing Single-Engine Type Engine 4 Cycle Pending Number Change None Dealer No Date Change Authorized None Mode S Code (base 8 / oct) 52306653 MFR Year 2014 Mode S Code (base 16 / hex) A98DAB Type Registration LLC Fractional Owner NO Registered Owner Name MARCINKO HOLDINGS LLC Street 121 WISCONSIN AVE STE 101 City WHITEFISH State MONTANA County FLATHEAD Zip Code 59937-2304 Country UNITED STATES Airworthiness Engine Manufacturer ROTAX Classification Experimental Engine Model 912UL SERIES Category Amateur Built A/W Date 12/21/2014 Exception Code No --------------------------- |
On Sat, 08 Feb 2020 10:49:43 -0800
Patsy Tighe wrote: This BOLD thrill seeker sure has a lot of fun; I hope he lives to be an OLD airman. ------------------------------------------------- I FLEW MY AIRPLANE TO 17000 FEET! Jul 16, 2019 Jonas Marcinko I took a trip to New Mexico and filmed along the way and on the way back I was able to reach 17000 Feet in my Capella aircraft. I was on supplemental oxygen during my time over 12500 ft. My Capella has a Rotax 912 engine. it is a tailwheel airplane. https://youtu.be/ObygtveJrhc ------------------------------------------------------- At 9:09 minutes into the video have a look at his altimeter. I don't see any evidence of O2 equipment. At this point in his video [9:51]: https://youtu.be/ObygtveJrhc?t=591 he would appear to be in violation of: https://www.ecfr.gov/cgi-bin/text-id...1.3.10&idno=14 Code of Federal Regulations §91.155 Basic VFR weather minimums. PART 91—GENERAL OPERATING AND FLIGHT RULES (a) Except as provided in paragraph (b) of this section and §91.157 [Special VFR], no person may operate an aircraft under VFR when the flight visibility is less, or at a distance from clouds that is less, than that prescribed for the corresponding altitude and class of airspace in the following table: Class G: More than 1,200 feet above the surface and at or above 10,000 feet MSL Flight visibility: 5 statute miles Distance from clouds: 1,000 feet below. 1,000 feet above. 1 statute mile horizontal. --------------------- JONAS LEE MARCINKO 382 E 475 N FIRTH ID 83236-1216 County: BINGHAM Country: USA Medical Information: Medical Class: Third Medical Date: 8/2017 BasicMed Course Date: None BasicMed CMEC Date: None Certificates PRIVATE PILOT Certificates Description Certificate: PRIVATE PILOT Date of Issue: 4/4/2015 Ratings: PRIVATE PILOT AIRPLANE SINGLE ENGINE LAND Limits: ------------------- https://registry.faa.gov/aircraftinq...umbertxt=7143A FAA REGISTRY N-Number Inquiry Results N7143A has Assigned/Multiple Records Data Updated each Federal Working Day at Midnight Aircraft Description Serial Number 027 Status Valid Manufacturer Name JONAS MARCINKO Certificate Issue Date 11/25/2014 Model XLS Expiration Date 11/30/2020 Type Aircraft Fixed Wing Single-Engine Type Engine 4 Cycle Pending Number Change None Dealer No Date Change Authorized None Mode S Code (base 8 / oct) 52306653 MFR Year 2014 Mode S Code (base 16 / hex) A98DAB Type Registration LLC Fractional Owner NO Registered Owner Name MARCINKO HOLDINGS LLC Street 121 WISCONSIN AVE STE 101 City WHITEFISH State MONTANA County FLATHEAD Zip Code 59937-2304 Country UNITED STATES Airworthiness Engine Manufacturer ROTAX Classification Experimental Engine Model 912UL SERIES Category Amateur Built A/W Date 12/21/2014 Exception Code No --------------------------- 17000 feet is virtually a medium mountain peak for unoxegenated climbers. A pilot is regulated to use O2 above a certain altitude but the US regs may exclude microlights |
| Thread Tools | |
| Display Modes | |
| Merry Christmas from the guy who writes the FARs | Dallas | Piloting | 4 | December 19th 07 07:33 PM |
| Historic FARs | Dan | Piloting | 5 | February 2nd 07 05:52 AM |
| Historical FARs | Matt Whiting | Piloting | 2 | December 23rd 06 05:44 PM |
| What FARs cover R/C drones? | Jim Logajan | Piloting | 39 | July 1st 06 03:51 AM |
| FARs on your PDA | Jim Kellett | Soaring | 0 | December 13th 04 10:42 PM |
