Mecaplex canopy window lube
Old February 17th 20, 07:23 PM posted to rec.aviation.soaring
John Foster
Default Mecaplex canopy window lube
What is the best way to lube the sliding window in a Mecaplex canopy? Mine is a bit stiff, and I don't want to break it by using too much force. It will slide, but stiffly.
Old February 17th 20, 07:32 PM posted to rec.aviation.soaring
Look for binds. You may need to smooth some edges with fine sandpaper. You should not need to lube.
Good luck
UH
Old February 17th 20, 11:12 PM posted to rec.aviation.soaring
"Fine paper",....think 1500 grit to 3000 grit.....wet is better....
Yes, "wet paper towel" or similar can work.....start cheap/easy, work up....
Old February 17th 20, 07:35 PM posted to rec.aviation.soaring
Dave Nadler
Clean the tracks with wet soft cotton cloth (not paper towel).
Work the window back and forth, clean again, and get all the grit out.
What UH says (very fine paper!)
Old February 17th 20, 10:25 PM posted to rec.aviation.soaring
Eric Munk
canopy?
much
force.
out.
Pledge or bees wax helps too
Old February 17th 20, 10:51 PM posted to rec.aviation.soaring
Charlie Papa[_2_]
canopy?
much
force.
out.
Or try some talcum powder...
Old February 18th 20, 12:48 AM posted to rec.aviation.soaring
I dip a Q-tip in canopy cleaner fluid and run it all around the tracks, then open and close the window several times.
Repeat as necessary. If it used to be free, then is got crud on the sides of the window and in the tracks. I also give the pop-out window bolt a quarter turn, if it’s popping out all by itself!
JJ
Old February 18th 20, 01:38 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
It's not difficult to remove the two tracks and siding window, and then clean the tracks, swab some vaseline in the tracks and reassemble.
KS
Old February 18th 20, 02:13 AM posted to rec.aviation.soaring
Dave Nadler
Take special care not to over-tighten screws and crack plexi.
Vaseline will trap grit; not recommended.
No lube should be necessary, but wax will trap less grit if you must.
See ya in Little Rock and Seminole!
Best Regards, Dave
Old February 18th 20, 02:38 AM posted to rec.aviation.soaring
cdeerinck
I think your best bet is to remove the rails, clean everything, then reassemble.
Used Mecaplex sliding Window Wanted Jeff Casto Soaring 2 August 18th 12 10:34 PM
Wanted Mecaplex Sliding Canopy Window Terry Edmonds Soaring 3 August 5th 12 07:09 PM
Fuel Lube Preferences? Orval Fairbairn[_2_] Owning 2 January 16th 09 04:29 AM
looking for canopy window Brad[_2_] Soaring 6 November 16th 08 01:48 PM
Noisy Mecaplex Window [email protected] Soaring 8 March 1st 07 01:08 AM
