Avionic trouble
Old September 10th 04, 08:22 PM
Henning DE
Default Avionic trouble
Hello !
I have some trouble with a King KX 175B Nav/Comm Radio:
I have connected a 14 V Unit to 28 V Power.
(The aircraft has two voltage buses)
Interesting, it does recieve very good and the lamps wont burn out, but once
you set it to transmit, thats it.
It will transmit once and then never again.
It still does recieve.
Did somebody out here made the same mistake ?
How can I fix it ? Is there a fuse inside ?
Any help is greatly appriciated.
Henning DE
Old September 10th 04, 11:23 PM
Rob Turk
"Henning DE" wrote in message
Hello !
once you set it to transmit, thats it.
Henning DE
If the unit still receives then it's unlikely that it just an internal fuse
gone. Most analog technology can withstand some amazing abuse, so I'm not
surprised your receiver still works. An exception are the RF power
transistors in your final amplifier. Those usually are quite fragile. I
wouldn't be surprised if they are fried.
You can replace them yourself, but I wouldn't recommend it if you don't know
what you're doing. Some types RF transistors contain highly poisonous stuff
(Berilium) which can be exposed when improperly handled. Also, tuning the
final amplifier after repair requires equipment that most of us don't have
at home. Get the radio to a certified repair shop for best (and safest)
result.
Rob
is anyone else having trouble getting messages downloaded? Gilan Home Built 1 August 22nd 03 02:49 AM
