Marine Radio using Aviation Antennae
Old July 1st 03, 07:28 PM
Jim Weir
Default Marine Radio using Aviation Antennae
Will it work? Probably.
Will it work well? That depends on what "well" means.
Will it work at peak efficiency. No.
In all probability, your reception will probably be acceptable. The transmitter
protection circuitry may (high probability) prevent you from getting any decent
transmitter range.
"Doug"
-I want to get a handheld marine radio for my amphib Husky. I wouild like to
-plug it in to my aviation outside antennae that I have installed for my
-aviation handheld. Will this work? Marine frequencies are
- a.. TX 156.025-157.425 MHz
- b.. RX 156.025-163.275 MHz
-(from the Icom web site).
http://www.rst-engr.com
Old July 2nd 03, 12:01 AM
Doug,
Most aircraft antenna's are 1/4 wave length (about 22 inches.) A quarter
wavelength on marine frequencies is approximately 17 and a half inches.
This is out of the range of most handheld matching circuits. My conclusion
is that the answer to your question is no.
http://www.soaridaho.com/Schreder
"Doug" wrote in message
to
Old July 2nd 03, 01:41 AM
Buff5200
You could try the Ham radio market. What you are looking for is an
Antenna Tuner
for the 70cm band. What you want is an antenna tuner that can capactively
"shorten" the 22" aircraft antenna and cause it to match the frequencies
that would
normally use a 17" antenna. You might want to look at www.aesham.com.
Wayne Paul wrote:
Doug,
to
Old July 2nd 03, 02:20 AM
Tim Ward
"Buff5200" wrote in message
Antenna Tuner
that would
No. The 70 cm amateur band is around 440 MHz -- way above 160 MHz.
The marine frequencies would be closest to 2 meters, and not all that close.
I think a dedicated antenna is going to be simpler, cheaper, and work
better.
Jim, I believe at one time you posted a pointer to an advisory circular of
best practices for installing non-aviation band radios in aircraft. Maybe
you could dig that out again.
Tim Ward
Old July 3rd 03, 04:37 AM
Buff5200
better.
Sorry, my misprint, I meant a dual band 2M/70cm tuner.
Absolutely, a dedicated antenna is the best move. Unless you are trying
to mount an extra antenna
on a certified aircraft. Lots of paperwork and $$$. I was speaking to
the concept of using a HT marine
radio on an antenna "normally" used for aviation band, and already
installed in the airframe.
Old July 3rd 03, 05:32 AM
Tim Ward
close.
better.
I understood you to mean an antenna tuner.
That's why I mentioned Jim Weir's previous posting of a pointer to an AC
about mounting non-aviation radios in airplanes. I think last time it was
in connection with amateur radio in an airplane, but the principals would be
the same.
Tim Ward
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
