I was looking at some old IFR Refreshers tonight, and found the IFR Quiz
from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Is there something I'm missing here? |
Roy Smith wrote:
I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Roy, I gotta agree with you here. In practice, I would ignore LVT, and identify TANDS with BNA and DME. If I didn't have a DME, then I would use BNA and LVT radials. Of course, in *real* reality, I would use GPS in OBS mode, and plot the inbound leg of the hold. Happy Flying! Scott Skylane |
![]() I gotta agree with you here. In practice, I would ignore LVT, and identify TANDS with BNA and DME. If I didn't have a DME, then I would use BNA and LVT radials. Of course, in *real* reality, I would use GPS in OBS mode, and plot the inbound leg of the hold. The context of the question in IFRR presumes you are flying the missed approach using conventional ground-based nav. If you had a GPS, though, and had the ILS approach loaded from the database, after the MAP you would have to use the flight-plan (TF leg) mode of the GPS until TANDS, then the OBS mode at TANDS to hold. |
![]() "Roy Smith" wrote in message ... I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Is there something I'm missing here? No, IFRR made a boo-boo. |
Roy Smith wrote in
: I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Is there something I'm missing here? TANDS, according to the chart, is fixed by the BNA 016 radial and the LVT 270 radial, and you can also use just 24.7 DME on the BNA 016 radial. The written answer may be a little opaque, but it's more or less correct, in that you can use either/or. The R-106 will put you somewhere you shouldn't be, though. ;-) -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
![]() Stan Gosnell wrote: Roy Smith wrote in : I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Is there something I'm missing here? TANDS, according to the chart, is fixed by the BNA 016 radial and the LVT 270 radial, and you can also use just 24.7 DME on the BNA 016 radial. The written answer may be a little opaque, but it's more or less correct, in that you can use either/or. The R-106 will put you somewhere you shouldn't be, though. ;-) Especially when using the DNA 24.7 DME. ;-) |
![]() Roy Smith wrote: I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. Question #4 asks how to identify TANDS, and the answer they give is "BNA DME and Livingston's R-270". Isn't that kind of nuts? The DME arc is almost tangent to the LVT R-270, and would thus give an extremely sloppy fix. The only rational ways in my mind to identify TANDS would be to cross the BNA R-106 with the LVT R-270, or the BNA R-106, DNA 24.7 DME. Is there something I'm missing here? Seems to me you're missing something. ;-) The sloppy tanget to the BNA DME would exist only if you were flying along the LVT 270 radial. But, you're not. In the context of that approach chart you flew the missed approach northbound on the BNA 016 radial until either BNA 24.7 DME or until crossing the LVT 270 radial northbound tracking BNA 016 radial. Then, you enter the hold flying on-course southbound on the BNA 016 back to TANDS. So, what's sloppy about the BNA 24.7 DME fix when holding north of TANDS on the BNA 016 radial (i.e., as the hold is charted)? TANDS is authorized only for use along V-49, which is the BNA 016 radial at that location. It is not authorized for flight along the LVT 270 radial unless ATC were to give you an impromtu clearance to track the LVT 270 radial. It's a long ways from LVT to TANDS (67.4 miles) so that is a pretty sloppy fix, compared to the BNA R-016/24.7 DME. Also, according to the NACO L-21 Lo En Route Chart, the MRA is 3,000, which makes it a pretty marginal fix using the LVT 270 radial. They had to chart it that way, though, to keep the procedure from requiring DME. |
Roy Smith wrote: I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. [snip] The sloppy tanget to the BNA DME would exist only if you were flying along the LVT 270 radial. But, you're not. In the context of that approach chart you flew the missed approach northbound on the BNA 016 radial until either BNA 24.7 DME or until crossing the LVT 270 radial northbound tracking BNA 016 radial. Then, you enter the hold flying on-course southbound on the BNA 016 back to TANDS. Hi. simulator pilot that enjoys flying IFR procedures here. How is this hold entered? As I understand, BNA R-016 past BNA 24.7 DME (or LVT 270 radial), then a 180 degree turn southbound until reaching TANDS again, and then left standard turn to 016? Any restrictions for the southbound turn after passing TANDS the first time? TIA, Mike |
![]() wrote in message ups.com... wrote: Roy Smith wrote: I was looking at some old IFR Refreshers tonight, and found the IFR Quiz from September 2002. See http://204.108.4.16/d-tpp/0503/00282I2C.PDF. [snip] The sloppy tanget to the BNA DME would exist only if you were flying along the LVT 270 radial. But, you're not. In the context of that approach chart you flew the missed approach northbound on the BNA 016 radial until either BNA 24.7 DME or until crossing the LVT 270 radial northbound tracking BNA 016 radial. Then, you enter the hold flying on-course southbound on the BNA 016 back to TANDS. Hi. simulator pilot that enjoys flying IFR procedures here. How is this hold entered? As I understand, BNA R-016 past BNA 24.7 DME (or LVT 270 radial), then a 180 degree turn southbound until reaching TANDS again, and then left standard turn to 016? Any restrictions for the southbound turn after passing TANDS the first time? No, a teardrop entry. BNA R016 past BNA 24.7 DME, then right turn 30 degrees to 046. Fly one minute, turn left , twist OBS to 196, and continue your turn to intercept 196 inbound. Not sure how Stan came up with a parallel entry for this (maybe from your description he thought you were coming from the east or something). Cheers, John Clonts Temple, Texas N7NZ |
Please help me identify WW2 AF Squadron Logo. | Van Gardner | Military Aviation | 6 | June 29th 04 08:42 AM |
Announcing WINNER of "Can you help Identify this airport" contest! | Video Guy | Home Built | 8 | January 13th 04 04:50 AM |
Can you help identify this airport? | Video Guy | Home Built | 4 | January 12th 04 12:35 PM |
Can you help identify this airport? | Video Guy | Owning | 4 | January 12th 04 12:35 PM |
Can't identify aircraft | Patrick Underwood | Owning | 7 | September 23rd 03 03:55 PM |
