I have not used my Microsoft Flight Simulator 2004 in about six months. I
tried to use it this week and I encountered a problem. I can not get the brakes to release. Pressing the period on the key board or pressing the trigger button on the Joy stick does not work. It does not matter if I go to a saved flight or if I create a new one, it is the same thing, the brakes are on and will not release. Changing aircraft has no effect. I tried uninstalling the program and then reinstalling it. After reinstalling the program I was really surprised that I still have the brake on problem. My computer far exceeds the requirements for FL 2004 even with the program at the highest settings. My Joy stick is a, Logitech Extreme 3D Pro. The program worked perfectly for months. So I am truly puzzled at why this problem has come up and persist even after removing FL 2004 from my computer and reinstalling it. If you have any ideas I would appreciate your help. Thanks. ![]() |
What does Settings -- Control Assignments show?
This information is kept in the FS9.cfg file which is not erased if you uninstall. You could simply backup/rename this file start FS9 and it will build a new one. -- ....Carl Frisk Anger is a brief madness. - Horace, 20 B.C. http://www.carlfrisk.com "James" wrote in message ... I have not used my Microsoft Flight Simulator 2004 in about six months. I tried to use it this week and I encountered a problem. I can not get the brakes to release. Pressing the period on the key board or pressing the trigger button on the Joy stick does not work. It does not matter if I go to a saved flight or if I create a new one, it is the same thing, the brakes are on and will not release. Changing aircraft has no effect. I tried uninstalling the program and then reinstalling it. After reinstalling the program I was really surprised that I still have the brake on problem. My computer far exceeds the requirements for FL 2004 even with the program at the highest settings. My Joy stick is a, Logitech Extreme 3D Pro. The program worked perfectly for months. So I am truly puzzled at why this problem has come up and persist even after removing FL 2004 from my computer and reinstalling it. If you have any ideas I would appreciate your help. Thanks. ![]() |
![]() "Carl Frisk" wrote in message news:shL0e.25455$mq2.17946@trnddc08... What does Settings -- Control Assignments show? This information is kept in the FS9.cfg file which is not erased if you uninstall. You could simply backup/rename this file start FS9 and it will build a new one. -- ...Carl Frisk Anger is a brief madness. - Horace, 20 B.C. http://www.carlfrisk.com I finally got the brakes to work right. Thanks a lot I really appreciate your help. I found the file FS9.cfg and deleted it. Then I uninstalled FS-2004. I reloaded the program once again and now everything seems to work fine. James |
You probably didn't need to uninstall. FS9 will simply rebuild a new FS9.cfg whenever you start it up again.
-- ....Carl Frisk Anger is a brief madness. - Horace, 20 B.C. http://www.carlfrisk.com "James" wrote in message ... "Carl Frisk" wrote in message news:shL0e.25455$mq2.17946@trnddc08... What does Settings -- Control Assignments show? This information is kept in the FS9.cfg file which is not erased if you uninstall. You could simply backup/rename this file start FS9 and it will build a new one. -- ...Carl Frisk Anger is a brief madness. - Horace, 20 B.C. http://www.carlfrisk.com I finally got the brakes to work right. Thanks a lot I really appreciate your help. I found the file FS9.cfg and deleted it. Then I uninstalled FS-2004. I reloaded the program once again and now everything seems to work fine. James |
27 Apr 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | April 27th 04 11:54 PM |
Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 2nd 04 11:15 PM |
Machinista 2004 - call for entries | Robb Mitchell Machinista.org | Home Built | 0 | February 24th 04 02:19 PM |
30 Jan 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | January 31st 04 03:55 AM |
09 Jan 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | January 9th 04 10:05 PM |
