I tried starting my engine today after a top overhaul, the right P-Lead got
really hot and smoke came off it when I hit the starter button. where should I start looking for a short? could it be shorting back thru the starter motor? |
Check your ground connections. You should have a ground strap between the
engine and a ground point on the airframe (or maybe back to the battery). If someone forgot to hook that up, you might get the symptons you describe. KB "Justin H" wrote in message ... I tried starting my engine today after a top overhaul, the right P-Lead got really hot and smoke came off it when I hit the starter button. where should I start looking for a short? could it be shorting back thru the starter motor? |
Justin H wrote...
I tried starting my engine today after a top overhaul, the right P-Lead got really hot and smoke came off it when I hit the starter button. Is your engine grounded to the airframe? If you saw smoke the damage is probably already done, but while you're replacing the wires you smoke-checked check your engine ground - probably a braided strap somewhere between the engine case and the airframe. Dave 'Kapton video' Hyde |
Dave Hyde wrote:
: Justin H wrote... : I tried starting my engine today after a top overhaul, : the right P-Lead got really hot and smoke came off it : when I hit the starter button. : Is your engine grounded to the airframe? If you saw smoke : the damage is probably already done, but while you're : replacing the wires you smoke-checked check your engine : ground - probably a braided strap somewhere between the : engine case and the airframe. Many engines only have an impulse coupling on the left mag, so the right mag is supposed to be grounded when starting to prevent kickback/backfire. If you don't have a good engine ground (i.e. top overhaul guy forgot to reconnect it), it'll try to suck starter ground current through the right p-lead just as you described. It probably fried your ignition switch, p-lead wire, points, and possibly the whole mag (case, coil, etc). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Thanks! All of you were correct. It appears to have never had a grounding
strap. It does now! and the starter works alot better too! thanks again |
The bigger question is how much damage ($$$) did it do and who's responsible
for it? I'm sure that a $20 ignition switch used in an airplane costs $500, no? -Cory Justin H wrote: : Thanks! All of you were correct. It appears to have never had a grounding : strap. It does now! and the starter works alot better too! : thanks again -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| rectifier | Mark Smith | Home Built | 0 | August 14th 04 04:21 PM |
