After a rough landing, I minimally bent my experimental's tailwheel spring
and need to have it straightened. It is a piece of round solid ferrous steel, 39" long, 1.25" in greatest diameter as it enters the fuselage midway along its length and tapers to about 0.75" at each end. Alloy composition and type of heat treatment are unknown. At max gross, the static load on the tailwheel is ~205 lb. Is it possible to have it straightened? If so, what type of shop should I look for to do this kind of work. Does it need to be heat treated after straightening and if so, to what PSI. Any help is appreciated. I live in Phoenix but am glad to ship it somewhere to have the work done right. Thanks in advance. Dave Uhrbrock |
Here is what I would do + an explanation of my reasoning: 39" long and a static load of 205 lb gives a bending moment of 39*205 = 7995 in lb. Assume a ground reaction factor of say 3 which is not unreasonable based on experience - this can only be a guesstimate because you didn't provide enough info to calculate it properly. Thus the bending moment at limit load is 7995 x 3 = 23985 in lb. In order to calculate the actual ground reaction factor the deflection of the spring has to be calculated, the decent velocity of the airplane during landing estimated (function of wing loading) and an analysis performed based on energy of the impact cf strain energy stored in the spring. Beyond this dicussion. The max moment will occur where the spring enters the fuselage where the diameter (D) =1.25" (note I am assuming that this is the critical location but on some tapered rod springs the maximum may be at some other location on the spring - it needs a lot more work to establish if that is the case). The second moment of area (moment of inertia) of the spring at this location is I = (pi * D^4) / 64 = 0.1198 in^4 Thus the stress is s = My/I = 23985 * 0.625 / 0.1198 = 125130 psi where y = 1.25 / 2 = 0.625" Applying a safety factor of 1.5 which corresponds to the reserve energy requirements of FAR 23.723/726 the ultimate stress is 187695 psi. Assuming that the spring is 4130 / 4140 etc then it is clearly going to need heat treatment. This approximately equates to Rockwell C 41 (191 ksi). I would probably heat treat the spring to more like Rockwell C 47-48 to provide some additional margin (these are typical heat treatment levels for a landing gear spring). You will need to anneal the spring prior to straighening. Then re heat treat following straightening. I would just take the spring to a shop who does heat treatment work for aircraft - heat treatment is relatively cheap to have done so their is no sense in trying to save money by taking it to an auto spring shop etc. See MIL-H-6875 for specific process specifications for the heat treatment. Get that from http://stinet.dtic.mil/str/index.html Only catch is that you are going to have to figure out what alloy the metal is before you try to anneal and heat treat. Can the kit supplier or builder help with this ?? Otherwise there are some ways to figure this out but I won't elaborate on that yet. Hope that helps ..... "David H. Uhrbrock" wrote in message news:SWP1d.5756$Xc.546@lakeread01... After a rough landing, I minimally bent my experimental's tailwheel spring and need to have it straightened. It is a piece of round solid ferrous steel, 39" long, 1.25" in greatest diameter as it enters the fuselage midway along its length and tapers to about 0.75" at each end. Alloy composition and type of heat treatment are unknown. At max gross, the static load on the tailwheel is ~205 lb. Is it possible to have it straightened? If so, what type of shop should I look for to do this kind of work. Does it need to be heat treated after straightening and if so, to what PSI. Any help is appreciated. I live in Phoenix but am glad to ship it somewhere to have the work done right. Thanks in advance. Dave Uhrbrock |
On Wed, 15 Sep 2004 20:14:44 +1000, "smjmitchell"
wrote: Here is what I would do + an explanation of my reasoning: 39" long and a static load of 205 lb gives a bending moment of 39*205 = 7995 in lb. Assume a ground reaction factor of say 3 which is not unreasonable based on experience - this can only be a guesstimate because you didn't provide enough info to calculate it properly. Thus the bending moment at limit load is 7995 x 3 = 23985 in lb. In order to calculate the actual ground reaction factor the deflection of the spring has to be calculated, the decent velocity of the airplane during landing estimated (function of wing loading) and an analysis performed based on energy of the impact cf strain energy stored in the spring. Beyond this dicussion. The max moment will occur where the spring enters the fuselage where the diameter (D) =1.25" (note I am assuming that this is the critical location but on some tapered rod springs the maximum may be at some other location on the spring - it needs a lot more work to establish if that is the case). The second moment of area (moment of inertia) of the spring at this location is I = (pi * D^4) / 64 = 0.1198 in^4 Thus the stress is s = My/I = 23985 * 0.625 / 0.1198 = 125130 psi where y = 1.25 / 2 = 0.625" Applying a safety factor of 1.5 which corresponds to the reserve energy requirements of FAR 23.723/726 the ultimate stress is 187695 psi. Assuming that the spring is 4130 / 4140 etc then it is clearly going to need heat treatment. This approximately equates to Rockwell C 41 (191 ksi). I would probably heat treat the spring to more like Rockwell C 47-48 to provide some additional margin (these are typical heat treatment levels for a landing gear spring). You will need to anneal the spring prior to straighening. Then re heat treat following straightening. I would just take the spring to a shop who does heat treatment work for aircraft - heat treatment is relatively cheap to have done so their is no sense in trying to save money by taking it to an auto spring shop etc. See MIL-H-6875 for specific process specifications for the heat treatment. Get that from http://stinet.dtic.mil/str/index.html Only catch is that you are going to have to figure out what alloy the metal is before you try to anneal and heat treat. Can the kit supplier or builder help with this ?? Otherwise there are some ways to figure this out but I won't elaborate on that yet. Hope that helps ..... try straightening it cold. if that doesnt work(and I've seen my undercart legs bent through 45 degrees without hint of straightening the kink) then do it hot. to straighten the spring you just need an oxyacetylene torch. hold the fuselage end of the leg in a vice well padded with bits of sheet metal to prevent marking of the spring. (take it off the aircraft if that isnt obvious) heat the area of the bend plus about an inch or two each side, getting the place where you want to bend it nice and cherry red hot. bend it to the position needed. in the red heat stage it will be reasonably pliable. I bent mine just using a leather gloved hand to pull it straight. DO NOT QUENCH IT !!! you risk cracking it. now take it down to the tempering shop and tell them that you want it tempered to 200,000psi ultimate tensile strength. my 4140 tailsprings are tempered according to steve wittman's figures for 6150 and havent given any problem in service. I straightened 9 bends in one 6150 main leg and 6 in the other using the technique given above and had the local truck spring place temper it. beadblasted they have now been in service for two years. you can err with the hardening temperature by going over temp a little but the tempering temperature is critical for the final strength. btw when the hardening is being done the quench must be done by dropping the spring vertically into the quenching oil. you mustnt hold it horizontal and drop it into the oil. if you do the side hitting the oil will shrink. in my mates case the double taper tailwind tailspring ended up straight on the side that hit the oil first. he managed to cold straighten it. the tempering consists of heating it to a particular temp. holding it at that until saturated with heat evenly then letting it air cool on a rack. once you heat the spring the spring temper is lost in the heated area. re tempering it from scratch erases all previous tempering. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
