![]() https://en.wikipedia.org/wiki/Beriev_Be-10 The Beriev Be-10, also known as Izdelye M, (NATO reporting name: Mallow) was a twin engined, turbojet powered, flying-boat, patrol bomber built by the Soviet Union from 1955. The Be-10 is sometimes referred to as the M-10, though this designation is believed to apply only to the modified Be-10 that established 12 FAI world records in 1961, Bort no. 40 Yellow, still holding class records for speed and altitude. The Be-10 was designed in response to Council of Ministers of the Soviet Union directive No.2622-1105ss which called for a turbojet powered flying boat for open-sea reconnaissance, bombing, torpedo attack and mine-laying. Stipulated performance was to include a maximum speed of 950 to 1,000 km/h (590 to 621 mph) and the ability to operate in wave heights of 1.5 m (5 ft) at wind speeds up to 20 m/s (45 mph) with submission for state acceptance trials in November 1955. The Be-10 is an all-metal high-wing monoplane with the engines located beneath the wing roots and with splayed-out tailpipes. To minimize the risk of water ingestion, the engine air intakes are located on the forward fuselage section with spray fences on either side of the bow protecting the engines from water ingestion. The streamlined hull was fitted with a shallow single-step, sea rudder under the rear fuselage, 50° swept wings with marked anhedral and balance floats attached by short pylons at the wing-tips. Conventional swept-back stressed skin construction tail surfaces were a 35° sweptback fin and 40° swept tail-planes just above the rear fuselage. Control surfaces were Ailerons on each wing, a rudder on the fin and elevators on the tail-planes. The fuselage was a two step design with a high length to beam ratio to improve rough water handling, v-section planing bottom, two steps and was divided into nine water-tight compartments the forward and rear compartments being pressurised. Engine nacelles for the Lyul'ka AL-7F engines were attached to the fuselage sides under the wing centre-section. The original design showed some weaknesses in the seaworthiness and had to be modified; after modification the Be-10 was seaworthy up to a wave height of 1.2 meters (4 feet) and able to fly with wind speeds up to (57.6 km/hr; 36 mph) from water or land. Role Patrol bomber Manufacturer Beriev OKB (OKB-49) First flight 20 June 1956 Status Retired Primary user Soviet Naval Aviation Produced 1958–1961 Number built 28 Operational use of the Be-10 began when the 2nd Squadron of the 977th Independent Naval Long-range Reconnaissance Air Regiment (977th OMDRAP) started replacing its Beriev Be-6 flying boats with Be-10 aircraft. This squadron and the 1st Squadron of the 977th OMDRAP became the only operators of the Be-10, operating from a naval base at Lake Donuzlav on the Crimean peninsula The first public appearance of the Be-10 was when four aircraft flew over the 1961 Aviation Day air display at Tushino, giving the impression that the Be-10 was already in service. However, the Be-10 proved to be difficult to fly and there were several accidents. The Be-10 suffered from metal fatigue due to the stress on the airframe from the high-speed takeoffs and landings, together with corrosion. The Be-10 was removed from service in 1968, and was replaced by the turboprop-powered Be-12, which was easier to operate and had better endurance. Specifications (Be-10) General characteristics Crew: 3 Length: 31.45 m (103 ft 2 in) Wingspan: 28.6 m (93 ft 10 in) Height: 10.7 m (35 ft 1 in) Wing area: 130 m2 (1,400 sq ft) Empty weight: 27,356 kg (60,310 lb) Gross weight: 45,000 kg (99,208 lb) Max takeoff weight: 48,500 kg (106,924 lb) Fuel capacity: 18,750 kg (41,337 lb) Draught 1.75 m (5.74 ft) Powerplant: 2 × Lyul'ka AL-7PB Axial flow turbojet, 71.2 kN (16,000 lbf) thrust each Performance Maximum speed: 910 km/h (565 mph; 491 kn) at 5,000 m (16,400 ft) Range: 2,895 km (1,799 mi; 1,563 nmi) Service ceiling: 12,500 m (41,000 ft) Rate of climb: 10.288 m/s (2,025.2 ft/min) Time to altitude: 5,000 m (16,400 ft) in 8.1 minutes Armament Guns: 4 × 23 mm (0.90 in) Afanasev Makarov AM-23 cannon. 2 forward firing, and 2 in a radar-controlled tail turret Missiles: Up to 3 RAT-52 torpedoes. Bombs: 12 × FAB-250 250 kg bombs or 1 FAB-3000 3,000 kg bomb.Anti-shipping mines. * |
Beriev Be-6 pics [9/9] - Beriev Be-6 at China Aviation Museum, Beijing.jpg (1/1) | Miloch | Aviation Photos | 0 | June 19th 19 02:53 PM |
Beriev Be-200 pics 2nd try... [2/6] - Beriev Be-200 filling water tanks in the Mediterranean Sea while in operation in Mount Carmel forest fire in Israel.jpg (1/1) | Miloch | Aviation Photos | 0 | December 20th 18 03:59 PM |
Beriev Be-200 pics 2 [2/6] - Beriev Be-200 filling water tanks in the Mediterranean Sea while in operation in Mount Carmel forest fire in Israel.jpg (1/1) | Miloch | Aviation Photos | 0 | December 20th 18 03:34 PM |
Beriev Be-200 pics 2 [7/8] - RF-32767-Russia-Ministry-of-Emergency-Situations-EMERCOM-Beriev-Be-200_PlanespottersNet_317685.jpg (1/1) | Miloch | Aviation Photos | 0 | December 31st 17 04:24 PM |
Beriev A-50 pics 2 [7/7] - kw-3552-indian-air-force-beriev-a50-ei_PlanespottersNet_103147.jpg (1/1) | Miloch | Aviation Photos | 0 | May 10th 17 03:18 PM |
