Question for Jim Weir
Old September 16th 04, 05:17 PM
Ed Sullivan
Default Question for Jim Weir
A member of my chapter has asked me as tech councilor what
would be needed to assure that the installation of a Garmin 430 in his
RV-8 would be legal in the eyes of the FAA for flying approaches. This
falls a bit out of my area of expertise. Can you help or direct me to
help.
Ed Sullivan
Old September 17th 04, 09:51 PM
john smith
He is going to have to get the aircraft IFR certified either by the FAA
or a DER. There was a fellow in southeast Ohio that had a Pitts S-2B IFR
certified by a company in New England. This was 15-20 years ago.
help.
Ed Sullivan
Old September 17th 04, 10:25 PM
Rich S.
"john smith" wrote in message
He is going to have to get the aircraft IFR certified either by the FAA or
I don't think so. If you look at the op lims for the airplane, it should say
something like "Unless appropriately equipped for night and/or instrument
flight in accordance with FAR 91.205, this aircraft is to be operated under
VFR, day only".
FAR 91.205 is available for viewing at Landings.com. The link is quite long,
but is:
http://www.landings.com/evird.acgi$pass*66674742!mtd*41!var*20!cgi*/cgi-bin/get_file!buf*66!src*_landings/pages/regulations.html!ref*FAR/part_91/toc.html
As far as I can see, there is nothing in 205 which refers to certification
by the FAA or a DER. Of course, there may be other FAA regulations of which
I am unaware.
Rich S.
Old September 17th 04, 11:32 PM
Marc J. Zeitlin
Rich S." wrote:
"john smith" wrote ;
FAA or
a DER.......
should say
instrument
under
VFR, day only"....
Rich is absolutely correct - the op limits specify what's necessary, and
all the op limits I've seen (and the ones for my plane) explicitly say
that one can operate at night or IFR as long as one has the appropriate
equipment, as stated above. If the plane already has an airworthiness
certificate, all that's necessary is to instally the equipment and fly
it.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2004
Old September 18th 04, 04:51 AM
Dave Hyde
john smith wrote...
or a DER.
Interesting. My RV-4 operating limitations, written by a DAR
and approved by the FAA, say only that my airplane
is prohibited from flight under IFR unless suitably
equipped. When it's suitably equipped it's not prohibited.
All it takes is a radio swap, a pitot-static check, and a
transponder check. My PS and transponder check are current,
my avionics are not.
Dave 'goo' Hyde
Old September 18th 04, 05:26 PM
Jim Weir
With the lone exception of John Smith, who has not a clue what he is talking
about, all the rest of the folks who answered gave you exactly what I would have
said.
Thanks, gang, for the help.
Ed Sullivan
- A member of my chapter has asked me as tech councilor what
-would be needed to assure that the installation of a Garmin 430 in his
-RV-8 would be legal in the eyes of the FAA for flying approaches. This
-falls a bit out of my area of expertise. Can you help or direct me to
-help.
-Ed Sullivan
http://www.rst-engr.com
Old September 18th 04, 11:27 PM
john smith
That's what the guy told me when I asked about it!
Were the rules different 20 years ago?
said.
Old September 20th 04, 11:25 PM
Ron Natalie
"john smith" wrote in message ...
No, your answer was as wrong 20 years ago as it is today.
Most likely you missed the fact that your hearsay Pitts owner has an aircraft
with a conventional airworthiness certificate rather than an experimental one.
Old September 21st 04, 11:35 AM
Barnyard BOb -
Why automatically assume this Pitts is NOT factory
built with a conventional airworthiness certificate?
Barnyard BOb --
Old September 21st 04, 11:45 AM
Barnyard BOb -
Ooops.
Please disregard.
Barnyard BOb -- too early to be online
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Headset connections (attn: Jim Weir) Bruce Home Built 5 April 20th 04 03:56 PM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Inverter question for Jim Weir B2431 Home Built 35 February 27th 04 09:28 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
