Solo 2350D won't start
Old March 20th 20, 11:42 PM posted to rec.aviation.soaring
BillT
Default Solo 2350D won't start
Our Duo's turbo has suddenly stopped working. It spins up ok at 55Kt when decompressed & continues windmilling when the decompression is released. The engine starts after 2 - 3 seconds, runs for 2 seconds then cuts out. After 1 - 2 seconds it starts again & the sequence is repeated. It's as if the rpm cut out is operating (which happens if the revs exceed 6500) but I'm certain that's not happening & have been careful to ensure the speed doesn't exceed 60Kt. Any advice will be appreciated. Thanks, Bill
Old March 21st 20, 12:16 AM posted to rec.aviation.soaring
Check for blocked or collapsed fuel lines.
UH
Old March 21st 20, 01:56 AM posted to rec.aviation.soaring
Bruce Friesen
Check fuel pump for outlet pressure (not just confirming flow, actually measuring the pressure and compare to spec sheet).
Old March 21st 20, 02:29 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Does sound like a intermittent fuel delivery problem.
How do you start a turbo on the ground?
Thought they were only windwill starts?
Don't know never have had one.
Old March 21st 20, 02:50 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Fri, 20 Mar 2020 15:42:39 -0700 (PDT), BillT
About 10 years ago I had a similar issue with my Ventus cT (same
engine, but direct drive). Problem turned out to be the impulse fuel
pump diaphragm that had gotten stiff with age. A simple job to replace
(provided you can get the parts). 10 years ago parts were not an
issue, now, I am unsure. I so have photos of the replacement procedure
if interested.
Bob
Old March 21st 20, 10:26 AM posted to rec.aviation.soaring
Jonathon May
55Kt when
decompressed
engine
starts after 2 - 3
starts
if the
revs exceed 6500)
ensure the
replace
procedure
if interested.
Bob
I think the 5 year check has a replacement for the diaphragm ,so
they are an obvious known fault.
AS
Is the fuel tank vented properly?
Uli
'AS'
Old March 21st 20, 03:09 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
How do you start a Turbo engine on the ground to work on it?
Can you?
Can you Hand Prop it?
It would be nice if they had a fitting to attach a 1/2" drill motor to turn it over.
I, obviously, know very little about these engines, just curious.
Old March 21st 20, 03:36 PM posted to rec.aviation.soaring
john firth
I have made new diaphragms for a Mikuni pump from 5 mil mylar (artists supplies)
Use the cast plate as a template and melt the screw holes with a soldering iron.
JMF
Old March 21st 20, 03:39 PM posted to rec.aviation.soaring
John does the mylar resist the effects of the fuel or do you find you have replace that diafram frequently?
Dan
Start Anywhere [email protected] Soaring 35 December 24th 08 09:58 PM
FSX Start Up L D S Simulators 1 November 22nd 07 12:06 AM
SR-71 61-7974, engine start - "61-7974 engine start, Jan 16, 1984, Ramstein AB, Scott R Wilson.jpg" 176.9 KBytes [email protected] Aviation Photos 7 November 3rd 07 02:14 PM
SR-71 61-7974, engine start - "61-7974 engine start, Jan 16, 1984, Ramstein AB, Scott R Wilson.jpg" 176.9 KBytes [email protected] Piloting 4 November 3rd 07 02:14 PM
I want to start Carlos Estopier Owning 16 May 12th 04 08:09 PM
