Looking for used Oudie IGC
Old March 26th 20, 03:35 PM posted to rec.aviation.soaring
Patrick Grady
Default Looking for used Oudie IGC
Hi all,
I'm on a student budget, and I'm looking for a bargain on any Oudie IGCs out there that aren't being flown. Maybe you upgraded or haven't flown in a while. Regardless, please send me an email if you have one that you're willing to part with!
Cheers!
Patrick Grady
email:
Old March 26th 20, 04:33 PM posted to rec.aviation.soaring
Wyll Surf Air
If you are one a budget why not Use Top Hat or XCSoar?
Old March 26th 20, 04:53 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
Presumably, as he specifically asked for the IGC variant, he wants
something
that is approved for Badges etc.
Old March 26th 20, 05:19 PM posted to rec.aviation.soaring
Patrick Grady
Yep, I'm looking for a logger in addition to the flight computer.
I'm currently using XCSoar, and I really like the interface, but it seems to not be too reliable. Limited phone battery life, and it seems to like to crash every few hours. If I'm partway through a task, its really annoying to lose everything.
Many people at my club use the Oudie IGC, and the integration and ability to switch gliders easily looks really attractive.
Old March 26th 20, 05:31 PM posted to rec.aviation.soaring
The oudie igc’s are pricey. I upgraded to one. I think paul at Cumulous still has a trade in deal so if u can pick up a regular oudie for reasonable price here, you may be able to trade up into a igc and save a few dollars.
Old March 26th 20, 05:40 PM posted to rec.aviation.soaring
SoaringXCellence
Also, if the only function you want is ICG recording, not for approved badges or contest, you can download the SeeYou recorder, no charge.
If you're having some problems with XCSoar, you might also check on their forum for a solution. I've been using it for 13 years and not seen the type of problems you're describing. I've run it on tablets, and Android phones. Another solution to the battery life is an external battery. I also had good luck with that before.
Old March 26th 20, 05:48 PM posted to rec.aviation.soaring
BTW, I believe the Oudie 2 is still approved for all badges and state record flights. For national and international records I’m not sure about.
Old March 26th 20, 06:05 PM posted to rec.aviation.soaring
SoaringXCellence
Patrick,
Send me a private message and I'll talk with you about an Oudie (used) that I think is available for around $200.
Mike
Old March 26th 20, 09:02 PM posted to rec.aviation.soaring
MNLou
Dan
Unfortunately, no. An Oudie 2 file is good for regional contests but is not IGC approved so not good for badge flights. An Oudie IGC is.
Lou
Old March 26th 20, 06:14 PM posted to rec.aviation.soaring
John Foster
What about something like this?
https://wingsandwheels.com/avionics-...flywithce.html
Oudie help Dennis Cavagnaro Soaring 13 February 1st 20 02:15 PM
OUDIE 1 OR OUDIE 2? James Hamilton[_2_] Soaring 5 August 12th 19 12:52 AM
OUDIE [email protected] Soaring 9 April 24th 18 04:01 PM
Oudie 2 [email protected] Soaring 1 January 10th 18 07:29 PM
Oudie Peter von Tresckow Soaring 2 December 18th 11 01:31 PM
