Instrumentation question
Old March 30th 20, 03:44 PM posted to rec.aviation.soaring
Default Instrumentation question
Thinking about glider projects other than flying...
If I add 2 instruments to the tail:
1) a 3d accelerometer
2) strain gages on the shank of the te probe to measure horizontal and vertical deflection
Then will the difference between these two be an indication of the left-right and up-down wind vectors?
Old March 30th 20, 03:51 PM posted to rec.aviation.soaring
The first would quantify, to some degree, how the aircraft responds to gusts(assuming no control input). This would vary depending on the natural stability of the ship, and CG location.
The second would measure the response of the probe to the motion resulting from the first. Effectively it would provide the same information once the mechanical issues of stiffness vs deflection are removed.
I'm not sure what might be gained from this information.
FWIW
UH
Old March 30th 20, 04:11 PM posted to rec.aviation.soaring
My theory is that the strain gages would respond to two things
movements in the tail due to all the complicated things you mention
air mass movements
if the accelerometers only respond to the first and I subtract that, then I might get left with the airmass?
Old March 30th 20, 04:57 PM posted to rec.aviation.soaring
jfitch
air mass movements
I think you will find the signal to noise ratio extremely low, so I hope you have a PHD in filtering algorithms.
Old March 30th 20, 06:06 PM posted to rec.aviation.soaring
No, a bit more practical. My PHD came from an estate sale. It has 2 handles and makes nice holes in the ground.
Glider Instrumentation for Sale Dan Colton Soaring 0 January 9th 18 10:05 PM
Clearing out Moisture from Instrumentation Lines KevinFinke Soaring 6 June 25th 11 03:28 PM
Instrumentation ergonomics tango4 Soaring 13 September 8th 03 04:16 PM
B-24 Instrumentation RobbelothE Military Aviation 1 July 28th 03 06:18 AM
WW2 Aircraft Instrumentation Question RobbelothE Military Aviation 2 July 6th 03 07:34 AM
