IS 32 sailplane
Old April 13th 20, 06:01 PM posted to rec.aviation.soaring
Default IS 32 sailplane
Curious if any are operating in the US, or in need of new home
MM
Old April 13th 20, 07:28 PM posted to rec.aviation.soaring
John Foster
MM
There is only one registered in the FAA database--N555XX
Old April 14th 20, 02:00 PM posted to rec.aviation.soaring
MM
There had been one in Alberta Canada several years ago. Not sure of the current status.
Old April 14th 20, 02:26 PM posted to rec.aviation.soaring
Dan Daly[_2_]
MM
According to TC database, C of R cancelled May 7, 2012. Probably sold to the U.S.?
Old April 14th 20, 06:47 PM posted to rec.aviation.soaring
George Haeh
I believe the Alberta IS-32 groundlooped landing in a crop damaging an aileron in 2011. There's no factory support and no repair has been made.
Old April 14th 20, 08:23 PM posted to rec.aviation.soaring
Jock Proudfoot
MM
of the
current status.
sold to
the U.S.?
C-FAOA is still registered to the Cu Nim Gliding Club.
There is no record of it being exported out of Canada
Old April 15th 20, 12:00 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
What s the difference between a IS 32 and a Sherman Tank?
Not much
Both weight about the same!
Old April 15th 20, 01:07 AM posted to rec.aviation.soaring
? less gross weight than G-103 and Janus C
Old April 15th 20, 01:21 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
FWIW
Wikipedia sez 850 lbs empty weight
I did my initial training in a IS28
I sprained my back moving that thing around on the ground that took me 2 years to heal.
Nick
T
Old April 15th 20, 01:38 AM posted to rec.aviation.soaring
Yes it’s a beast. Very specific techniques and ground support equipment required to protect oneself and avoid blocking runways. I owned a 28 and landed out several times. One of my students required a hernia repair
Which 18m FES sailplane to buy? [email protected] Soaring 98 May 11th 20 05:33 PM
Would you rather fly a Sailplane? Karen Soaring 18 June 7th 12 03:28 AM
Best Looking Sailplane glider[_2_] Soaring 52 November 23rd 09 05:29 PM
Could this be used in a sailplane? Spam Soaring 6 July 5th 09 09:16 PM
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 09:11 PM
