![]() https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-23 The Mikoyan-Gurevich MiG-23 (Russian: ?????? ? ??????? ???-23; NATO reporting name: Flogger) is a variable-geometry fighter aircraft, designed by the Mikoyan-Gurevich design bureau in the Soviet Union. It is a third-generation jet fighter, the world's most-produced variable-geometry aircraft, along with similar Soviet fighters such as the Su-15 "Flagon". It was the first Soviet fighter to field a look-down/shoot-down radar and one of the first to be armed with beyond visual range missiles. Production started in 1969 and reached large numbers with over 5,000 aircraft built. Today the MiG-23 remains in limited service with some export customers. The basic design was also used as the basis for the Mikoyan MiG-27, a dedicated ground-attack variant. Among many minor changes, the MiG-27 replaced the MiG-23's nose-mounted radar system with an optical panel holding a laser designator and a TV camera. The MiG-23's predecessor, the MiG-21, was fast and agile, but limited in its operational capabilities by its primitive radar, short range, and limited weapons load (restricted in some aircraft to a pair of short-range R-3/K-13 (AA-2 "Atoll") air-to-air missiles). Work began on a replacement for the MiG-21 in the early 1960s. The new aircraft was required to have better performance and range than the MiG-21, while carrying more capable avionics and weapons including beyond-visual-range (BVR) missiles. A major design consideration was take-off and landing performance. Existing Soviet fast jets required very long runways which, combined with their limited range, restricted their tactical usefulness. The VVS demanded the new aircraft have a much shorter take-off run. Low-level speed and handling was also to be improved over the MiG-21. Manoeuvrability was not an urgent requirement. This led Mikoyan to consider two options: lift jets, to provide an additional lift component, and variable-geometry wings, which had been developed by TsAGI for both "clean-sheet" aircraft designs and adaptations of existing designs. The General Dynamics F-111 and McDonnell Douglas F-4 Phantom II were the main Western influences on the MiG-23. The Soviets, however, wanted a much lighter, single-engined fighter to maximize agility. Both the F-111 and the MiG-23 were designed as fighters, but the heavy weight and inherent stability of the F-111 turned it into a long-range interdictor and kept it out of the fighter role. The MiG-23's designers kept the MiG-23 light and agile enough to dogfight with enemy fighters. Role Fighter aircraft (M series) Fighter-bomber (B series) National origin Soviet Union Manufacturer Mikoyan-Gurevich / Mikoyan First flight 10 June 1967 Introduction 1970 Status In limited service Primary users Soviet Air Force (historical) Syrian Air Force Indian Air force (historical) Bulgarian Air Force (historical) See Operators below Produced 1967–1985 Number built 5,047 Unit cost $3.6–6.6 million (1980) Variants Mikoyan MiG-27 The aircraft was not used in large numbers by the non-Soviet air forces of the Warsaw Pact as originally envisioned. When the MiG-23s were initially deployed, they were considered the elites of the Eastern Bloc air forces. However, very quickly the disadvantages became evident and the MiG-23 did not replace the MiG-21 as initially intended. The aircraft had some deficiencies that limited its operational serviceability and its hourly operating cost was thus higher than the MiG-21s. The Eastern Bloc air forces used their MiG-23s to replace MiG-17s and MiG-19s still in service. The MiG-23 was the Soviet Air Force's "Top Gun"-equivalent aggressor aircraft from the late 1970s to the late 1980s. It proved a difficult opponent for early MiG-29 variants flown by inexperienced pilots. Exercises showed when well-flown, a MiG-23MLD could achieve favorable kill ratios against the MiG-29 in mock combat by using hit-and-run tactics and not engaging the MiG-29s in dogfights. Usually the aggressor MiG-23MLDs had a shark mouth painted on the nose just aft of the radome, and many were piloted by Soviet–Afghan War veterans. In the late 1980s, these aggressor MiG-23s were replaced by MiG-29s, also featuring shark mouths. Soviet–Afghan War Soviet MiG-23s were used over Afghanistan. Some of them were claimed to have been shot down. Soviet and Afghan MiG-23s and Pakistani F-16s clashed a few times during the Soviet–Afghan War from 1987. Two MiG-23 were claimed shot down in air to air fight by Pakistani F-16s when crossing the border (they both were not confirmed) while one F-16 was shot down on 29 April 1987. Pakistani and Western sources consider it a friendly fire incident but the Soviet-backed Afghan government of the time claimed that Soviet aircraft downed the Pakistani F-16 – a claim that The New York Times and the Washington Post also reported. According to a Russian version of the event, the F-16 was shot down when Pakistani F-16s encountered Soviet MiG-23MLDs. Soviet MiG-23MLD pilots, while on a bombing raid along the Pakistani-Afghan border, reported being attacked by F-16s and then seeing one F-16 explode. It could have been downed by gunfire from a MiG whose pilot did not report the kill, because Soviet pilots were not allowed to attack Pakistani aircraft without permission. Specifications (MiG-23MLD) General characteristics Crew: 1 sat on a Mikoyan KM-1M ejection seat Length: 16.7 m (54 ft 9 in) Wingspan: 13.965 m (45 ft 10 in) fully spread 7.779 m (25.52 ft) fully-sweptHeight: 4.82 m (15 ft 10 in) Wing area: 37.35 m2 (402.0 sq ft) fully-spread 34.16 m2 (367.7 sq ft) fully-sweptAirfoil: root: TsAGI SR-12S (6.5%) ; tip: TsAGI SR-12S (5.5%) Gross weight: 14,840 kg (32,717 lb) Max takeoff weight: 17,800 kg (39,242 lb) Fuel capacity: 4,260 l (1,130 US gal; 940 imp gal) internal with provision for up to 3x 800 l (210 US gal; 180 imp gal) drop-tanks Powerplant: 1 × Khatchaturov R-35-200 afterburning turbojet, 83.6 kN (18,800 lbf) thrust with variable-geometry nozzles dry, 127.49 kN (28,660 lbf) with afterburner Performance Maximum speed: 2,499 km/h (1,553 mph, 1,349 kn) / M2.35 at altitude 1,350 km/h (840 mph; 730 kn) / M1.1 at sea levelRange: 1,900 km (1,200 mi, 1,000 nmi) clean Combat range: 1,500 km (930 mi, 810 nmi) with standard armament, no drop-tanks 2,550 km (1,580 mi; 1,380 nmi) with standard armament and 3x 800 l (210 US gal; 180 imp gal) drop-tanksFerry range: 2,820 km (1,750 mi, 1,520 nmi) with 3x 800 l (210 US gal; 180 imp gal) drop-tanks Service ceiling: 18,300 m (60,000 ft) g limits: +8.5 Rate of climb: 230 m/s (45,000 ft/min) at sea level Take-off distance: 500 m (1,600 ft) Landing distance: 750 m (2,460 ft) Armament Guns: 1 × 23 mm Gryazev-Shipunov GSh-23L autocannon with 260 rounds Hardpoints: 2 × fuselage, 2 × wing glove and 2 × wing pylons with a capacity of up to 3,000 kg (6,600 lb) of stores,with provisions to carry combinations of: Rockets: S-5 Missiles: ***Air-to-air missiles: 2 × R-60 R-73 2 × R-23 R-77 2 × R-27R Air-to-surface missiles: Kh-23 Grom Bombs: Up to 500 kg (1,100 lb) bombs per hardpoint According to the MiG-23ML manual, the MiG-23ML has a maximum sustained turn rate of 14.1 deg/sec and a maximum instantaneous turn rate of 16.7 deg/sec. The MiG-23ML accelerates from 600 km/h (373 mph) to 900 km/h (559 mph) in 12 seconds at the altitude of 1000 meters. The MiG-23 accelerates at the altitude of 1 km from 630 km/h (391 mph) to 1300 km/h (808 mph) in 30 seconds and at the altitude of 10–12 km will accelerate from Mach 1 to Mach 2 in 160 seconds * |
Mikoyan-Gurevich MiG-15 pics 3 [3/5] - Mikoyan-Gurevich MiG-17 NOT 15 for comparison.jpg (1/1) | Miloch | Aviation Photos | 0 | June 4th 19 03:02 PM |
Mikoyan-Gurevich MiG-15 pics 3 [2/5] - Mikoyan-Gurevich MiG-15UTI - cockpit Bulgaria - Air Force.jpg (2/2) | Miloch | Aviation Photos | 0 | June 4th 19 03:02 PM |
Mikoyan-Gurevich MiG-15 pics 3 [1/5] - Mikoyan-Gurevich MiG-15bis - cockpit China - Air Force.jpg (1/1) | Miloch | Aviation Photos | 0 | June 4th 19 03:02 PM |
Mikoyan-Gurevich MiG-15 pics [1/8] - detail mikoyan-gurevich-mig-cockpit-voor.jpg (1/1) | Miloch | Aviation Photos | 0 | June 4th 19 02:57 PM |
Mikoyan-Gurevich MiG-25 pics 2 [5/6] - N9307 - Private Mikoyan-Gurevich MiG-21MF at Detroit.jpg (1/1) | Miloch | Aviation Photos | 0 | January 15th 19 01:16 PM |
