Jumpy needle
Old April 4th 05, 08:45 AM
Ludovic Launer
Default Jumpy needle
Hi
I have a Winter vario, which is works OK, but I find the indication a little
jumpy...
The system is not leaking, but I'd just like to have slightly less "gust"
jumps and a smoother move of the needle.
In my ASW20 there used to be a restriction in the tubing and apparently it
did the job pretty well with the same type of vario.
Indeed, restriction in the tubing seems to be the way to go:
http://www.sagevariometers.com/sagehint.htm
But then my quesion is:
Where can I find a restriction (preferably France, or Europe) ?
Making one would be an alternative, but very tedious I guess (what's the
correct length ? diameter of the capillary, ...)
Has anyone successfully applied this solution and got a better/smoother
reading ?
Thanks for the info,
Ludovic
Old April 5th 05, 12:23 AM
Bob Salvo
Hi Ludovic,
Take a short length of #22 insulated electrical wire and remove 50 mm of
insulation. Place this piece of insulation inside of a straight-through
section used to splice your tygon tubing. Use RTV to seal around the
outside of the insulation. This is now your capillary, which you should
place in the TE line that connects to the static side of vario.
Bob
"Ludovic Launer" wrote in message
Hi
little
jumpy...
reading ?
Ludovic
Old April 5th 05, 12:57 AM
Alan Meyer
Hi
jumpy...
Ludovic,
It would be very interesting to see if your thermalling
improves, gets worse, or is unchanged after removing
the quick response from the vario.
I have no trouble thermalling with my smooth acting
mechanical vario, but I think my "jumpy" electric vario
shows me more about the shape of the thermal I'm
in than my mechanical vario.
Alan
Old April 5th 05, 07:26 AM
Ludovic Launer
Hi,
Pilot "satisfaction" will be greater, thus making him happier + mode
confident in his instruments - improvement !
You're right, and that's what I'm aiming at: a fast response electric vario
(which is OK as it is now), and a smoother mechanical vario.
Ludovic
Soldiers Fear the Needle - The Pentagon still fights for its anthrax vaccine Roman Bystrianyk Naval Aviation 0 March 23rd 05 11:58 PM
Whereupon We Gave the Needle a Sharp Whack with a Brass Hammer jls Home Built 0 October 6th 04 07:47 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet ThJester99 Home Built 4 August 6th 03 07:26 PM
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet Larry Smith Home Built 0 August 4th 03 01:31 PM
