Got a little memory jog in the April 2006 Designee Update...other than
"Basic Instrument Flight Maneuvers," there is nothing in the 2004 (latest) PTS about timed turns OR compass turns. Nothing. Nada. So instrument pilot wannabes need not be concerned about demonstrating either one to the examiner. The examiner has some degree of latitude in deciding just what a "basic instrument flight maneuver" is...but no one is going to get a pink slip with "Timed turns to headings" on it. Bob Gardner |
"basic instrument flight maneuver" is...but no one is going to get a pink slip with "Timed turns to headings" on it. However, the full procedure partial panel non-precision approach is still in place, and in order to do that you will need to do compass turns or timed turns to headings. The change allows you to do what works best for you. Over time, I've discovered that what works best depends on the student and the equipment. Some students just don't get math. For them, the mental math required to figure out how many seconds the turn needs to be is too much to do while flying under the hood. For others, the jumping around, lead, and lag of the compass is too difficult to deal with - they prefer to time the turn, the check the compass only in level flight. I personally belong to the latter camp. I am a strong believer in only looking at the compass when I know it will be accurate, and using time for turns when the heading gyro is not available. I've taught some students that method, and they've done well with it. Others hated it, and wound up just looking at the compass anyway. If they slow the rate of turn to half-standard-rate when getting close to the heading, it works reasonably well. Fortunately I've never had a student who couldn't deal with either method. I'm not sure what I would do then. Michael |
Michael wrote:
Fortunately I've never had a student who couldn't deal with either method. I'm not sure what I would do then. I think the answer needs to be "not sign them off for the checkride". The ability to turn to and maintain a heading without a working DG is an essential skill. Somehow you need to be able to do it. Just turning until the little picture of the airplane is pointing in the same direction as the purple line might just be a reasonable plan with today's cockpits. Unfortunately, I'm not sure you would convince an examiner of that. Back when all our airplanes had ADF's in them, just setting the ADF to a distant AM radio station made a decent DG replacement. |
A new replacement for the ADF is the GPS, of course. Many, like the
GNS430, provide course information that's a very useful replacement for a bad gyro. I used it on my checkride and the examiner made me turn to a different page. But if all the electrons die, you have to know how to use a magnetic compass. |
On 4 Apr 2005 13:05:12 -0700, "paul kgyy" wrote:
I used it on my checkride and the examiner made me turn to a different page The examiner was not authorized to do this. Pilots need to hold examiners to the same standards that the examiners hold the pilots, i.e., the standards as described by the PTS. Pilots don't get to say "I think I'll do it this way, and screw what the standards say". Neither does the examiner. |
Its my understanding that a recent email to DPEs discussed exactly this
scenario and told DPEs that they could not allow pilots to use the GPS during partial panel. Someone out there may be able to verify this. I completed (successfully!) my instrument checkride last evening and was not allowed to use the GPS during this maneuver. I tried to load the approach and was told "no." Turned to the position page and the DPE turned it to the NAVCOM page (not much help). Had to rely on the compas and the timer. Bob wrote in message news ![]() On 4 Apr 2005 13:05:12 -0700, "paul kgyy" wrote: I used it on my checkride and the examiner made me turn to a different page The examiner was not authorized to do this. Pilots need to hold examiners to the same standards that the examiners hold the pilots, i.e., the standards as described by the PTS. Pilots don't get to say "I think I'll do it this way, and screw what the standards say". Neither does the examiner. |
Well, that's a defeatist attitude. I would like to think that I would come up with some method they could handle. Just turning until the little picture of the airplane is pointing in the same direction as the purple line might just be a reasonable plan with today's cockpits. In a glass cockpit Cirrus (at least the one I flew) it is the only plan. A PFD failure leaves you with ASI, electric AI, Altimeter - and two Garmin 430's without CDI's (the only CDI is built into the HSI presentation on the PFD). The only approach you can shoot after PFD failure is a GPS, and you can shoot it ONLY by turning until the little picture of the airplane is pointing in the same direction as the purple line. I suppose you could use a compass, but I'm not sure what the benefit would be. Unfortunately, I'm not sure you would convince an examiner of that. In the Cirrus I flew, there was no way to simulate PFD failure (vacuum? who dat?) which would not allow that approach to work. There would be no convincing involved, and with the deletion of compass turns from the PTS, the examiner no longer has the option of failing both GPS units (I guess we lost the PFD and both GPS units or the constellation?) and making the applicant do compass turns. Of course the recommended emergency procedure in the event of PFD failure is to engage the autopilot and not hand-fly at all, and you can argue that losing the autopilot AND the PFD on the same flight is unlikely. On the other hand, that makes the autopilot a no-go item for IMC, and I doubt any examiner would accept this. The interesting question is whether an examiner would insist on setting up a situation, however improbable, that would require the student to do partial panel flying without the GPS. I suppose he might, but it would surprise me if he did. Is it reasonable to expect an instrument rating applicant to be able to handle multiple point failures - and then allow him to carry passengers in low IMC in a single engine airplane? Much as I hate to say it, the truth is that partial panel as we know it is not so much a valuable skill in itself (except in the sense that learning to do ANYTHING that is demanding in an airplane is valuable as it makes you a better pilot) and more a reasoned response to flying with unreasonable technology. When both your sole attitude gyro and your sole heading gyro are plumbed to a single dry pump, you better be proficient at flying with both of them failed, since dry pumps are junk. It might interest you to know that the ATP checkride includes no partial panel work at all, since that sort of crap is not tolerated in transport category aircraft. Michael |
plan. A PFD failure leaves you with ASI, electric AI, Altimeter - and two Garmin 430's without CDI's (the only CDI is built into the HSI presentation on the PFD). Don't the 430's still have the CDI on the "Default NAV page"? Or did Garmin change the interface for the Cirrus? |
Michael,
I think you need to brush up on your Garmin GPS's. In the Cirrus, I believe, the Garmins drive the Avidyne display. One of the navigation pages on the Garmin displays a CDI that scales properly to approach sensitivity. That is much more accurate than following the magenta line for a backup approach. Ron "Michael" wrote in message Well, that's a defeatist attitude. I would like to think that I would come up with some method they could handle. Just turning until the little picture of the airplane is pointing in the same direction as the purple line might just be a reasonable plan with today's cockpits. In a glass cockpit Cirrus (at least the one I flew) it is the only plan. A PFD failure leaves you with ASI, electric AI, Altimeter - and two Garmin 430's without CDI's (the only CDI is built into the HSI presentation on the PFD). The only approach you can shoot after PFD failure is a GPS, and you can shoot it ONLY by turning until the little picture of the airplane is pointing in the same direction as the purple line. I suppose you could use a compass, but I'm not sure what the benefit would be. |
Experience with SIRS compass? | Ross Oliver | Owning | 2 | March 18th 05 06:21 PM |
Vertical Card Compass Mystery | Rosspilot | Owning | 3 | November 3rd 04 06:01 PM |
Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 12:08 PM |
Strange compass behavior | me | Owning | 10 | February 14th 04 04:24 AM |
Compass turning error | Marty Ross | Piloting | 3 | August 21st 03 02:53 PM |
