Composite & Carbon Fiber
Old September 21st 04, 12:14 AM
NW_PILOT
Default Composite & Carbon Fiber
Hello, everyone a friend of mine own's Fiberglass and Carbon Fiber molding
business (He makes hoods, doors, fenders & tubs for cars). I was wondering
if anyone has ever used a Cessna 150, 172 or 182 fuselage as a template for
the making of a Carbon Fiber fuselage?
I have few questions! Since it will not be a kit what kind of info would
have to be provided to the FAA to be able to get such a thing approved for a
homebuilt experimental aircraft project?
Thanks In Advance
Old September 21st 04, 01:50 AM
jls
"NW_PILOT" wrote in message
for
Well, yeah, you could use it as a plug but who would want to?
a
Thanks In Advance
Have at it. No approval necessary except when you apply for your homebuilt
c of a. It's not like you're getting it certified. Make sure you use a
good set of 150 (or 172) l. g. including nosewheel strut because that stuff
is damn strong.
Old September 21st 04, 02:58 AM
W P Dixon
Well I am sure someone will correct me if I am wrong, but if you plan on
using the base airframe of a certified plane already , instead of building
your framework from skratch, which is how I read your post.... You will need
to get approval from the FAA . As a general rule on a certified aircraft
only certified parts may be used. Now if you build the entire plane from the
ground up as an experimental like the man said "HAVE A BALL!"
" jls" wrote in message
molding
wondering
for
for
a
Thanks In Advance
homebuilt
stuff
is damn strong.
Old September 21st 04, 03:48 AM
Morgans
I don't normally top post, but there is such a mess, here....
Com'on guys! Think his through. Big problems.
# 1 problem. If you make a copy of a 150, don't you think Cessna is going
to have something to say to you, via a lawyer? I do. The 150 is their
design. You can't just copy it!
#2 problem. I quote: "if you plan on using the base airframe of a certified
plane already , instead of building your framework from skratch, which is
how I read your post.... "
What? This isn't a 52 Ford. You don't use the frame, and put a shell on
it. You can't take away the frame, and still use it. The body is the
frame. If you take it away, you ARE starting from "skratch".
Why would you want to copy a 150? Boxy, ugly, no provisions for mounting to
stuff, probably, no angels and tapers from popping it out of the mold. The
problems are too numerous to mention them all.
Jim in NC
"W P Dixon" wrote in message
need
molding
wondering
template
for
would
for
a
Thanks In Advance
homebuilt
a
stuff
is damn strong.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.766 / Virus Database: 513 - Release Date: 9/17/2004
Old September 21st 04, 04:09 AM
NW_PILOT
"Morgans" wrote in message
I did not say copy it I said use the fuselage as a template of course it
would be changed a bit from the original design for 1 it would be composit
not aluminum and the models I listed were an example. I see people are
making piper supercub's dose piper have a problem with it?
certified
to
The
I just used them airplane model #'s for an example this is all hypothetical
at the moment just an idea that my friend brought up to me thought I'd see
what you all thought. All I can say is this guy makes some nice custom car
body's/tubs and ahs a nice shop and offering to do it for cost of materials.
Jim in NC
building
need
molding
wondering
template
for
would
approved
for
a
Thanks In Advance
homebuilt
use
a
stuff
is damn strong.
Old September 21st 04, 04:25 AM
Morgans
Still their intellectual property.
of course it
Are they still making Piper Cubs, and trying to sell them?
certified
is
on
mounting
to
The
hypothetical
materials.
There would be so much re-engineering that would have to be done, it would
not be the same airplane, except the shape. By the time you did all that,
why not come up with your own shape that takes advantage of the curves that
aluminum can not do? The loads that an airplane has to take would make a
simple copy, like car body tubs unsafe to fly. I'll bet that it would weigh
more in fiberglass if you did strenghten it enough.
Jim in NC
Old September 21st 04, 04:19 AM
NW_PILOT
molding
wondering
for
for
a
Thanks In Advance
homebuilt
c of a.
What would paperwork would be required for homebuilt c of a, drawings?
Estimated or projected proformance data?
stuff
is damn strong.
Old September 21st 04, 05:17 AM
W P Dixon
Jim,
I believe I read the post wrong I was under the impression that he
intended to use an N# airplane basic airframe and just redo all the skins
and panels in carbonfiber. You may re skin a plane, remake all the metal
panels you want by processes to the manual of that plane and it will still
be the same N#'d airplane. But yes changing the airframe or starting all
over would make it experimental and Cessna might just "have a problem" with
a copy of their design. To get around that slight changes can be made and
you should be ok as far as a copyright. Seems he wants to make a carbon spin
off of the Cessna, and I agree with you I think it would outweigh the
original. i really would see no point in doing it. probably alot better
designs out there for that type aircraft.
molding
wondering
template
for
would
for
a
Thanks In Advance
homebuilt
c of a.
stuff
is damn strong.
Old September 21st 04, 05:59 PM
Bob Kuykendall
Some semi-random notes and observations on this topic from someone who
has messed about some with composite tooling:
* The C-150 is a pretty poor basis for such a project. If you do get
to the end of it, you'll have - a copy of a Cessna 150. If you're
going to go to the trouble, you might as well make something special
or at least different. If what you want is a 150, just take the cash
and go buy one. It will cost about half or a quarter of what it would
cost to replicate it in composites.
* Some pretty smart people designed the Cessna 150 for low-cost,
high-volume manufacturing in light sheet metal. If they had started
with the idea of a composite airplane, they would have been at liberty
(as you are now) to accommodate more compound curves and many other
improvements for lower drag and better performance of one kind or
another.
* Making a mold off of any riveted aluminum structure can be a
heinous, hateful experience. The seams and universal-head rivets won't
want to separate, and when they do you've got a mold with a bunch of
dimples and seams. So you end up spending hours and days refinishing
the molds.
* A while back, a couple guys made molds off of a BD-5 fuselage, and
then made carbon fiber shells from the molds. It was a neat project,
but I don't think any airplanes came from it, and last I heard of it I
think the whole project was for sale.
* The trouble it would take to smooth out a 150 fuselage enough to get
a nice mold off of it would probably be better invested in making a
new fuselage plug from scratch using plywood, lath, foam, and bondo.
* If you want to save some trouble, buy transparencies (windshield,
canopy, etc) for some other aircraft and incorporate them into your
plug. That way you know the plastic parts will be available and
relatively inexpensive, and it will save you the trouble of making
transparency tooling and having custom transparencies made.
* In the history of general aviation, there have been several
instances of someone using someone else's fuselage or wing or cowling
or whatever without permission as a direct pattern for their molds. I
don't know of any of them that became legal intellectual property
issues. However, it has almost always ended in tears for the
plagiarist. That history alone makes me believe no little bit in
karma.
* You have to show the FAA very little if anything in the way of
substantive data about the thing you've built. About all you have to
do is convince them that the major portion of the thing was made for
education and recreation, and that its operating limitations are
clearly marked. Ron W. can tell you a lot more about that than I can.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old September 21st 04, 06:21 PM
Roger Halstead
On Mon, 20 Sep 2004 16:14:20 -0700, "NW_PILOT"
Only enough to satisfy the 51%, or local examiner.
We had a Lake at HTL that used a Corvette engine. He had to change
enough of the structure that the FAA was happy. It sat up there for
years, but disappeared a couple years back. He did fly it, but I
don't think it met his expectations.
The point being, if you make enough changes it can become a home built
even though it started out as a certified airplane.
www.rogerhalstead.com
Thanks In Advance
carbon fiber dutchpilot Home Built 0 June 16th 04 12:20 PM
Foil Antenna on Carbon Fiber Dennis Mountains Home Built 7 April 24th 04 12:54 AM
Realistic Strengths of Homebuilt Carbon Fiber? BllFs6 Home Built 5 March 31st 04 05:23 PM
Carbon fiber vs. antennas Jim Weir Home Built 8 January 2nd 04 01:40 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
