Hi folks,
I ran into a little problem today. Working on a 100hour just a month before the annual is due -- my mechanic and I lifted the back seat to look at the cabling underneath. Lo and behold -- we found a "tear" in an aluminum bulkhead under the back seat. The bulkhead is under the back of the rear seat and doesn't appear to be structural as it is thin aluminum. But there is a steel brace coming in from the flap area of the wing and rivited to the lower outside corner of the aluminum bulkhead. However on mine, just next to the steel brace on the baggage door side -- there is a inch long tear up from the bottom of the bulkhead and a small buckle in the aluminum brace above the tear. Its like there was a terrific upwards stress on the bottom corner of the bulkhead where the steel is rivited and it tore the aluminum bulkhead upwards. Has anyone run into this problem before? I'd love to hear what had to be done to repair/replace the damage. Maybe someone knows of a 337 that had been done to repair similar damage??? It would sure help my mechanic who is a little unsure of where to start in the repair process. Thanks guys... Chuck N7398W |
If you are a member of the Cherokee Pilots Association, asking this question
on their "Cherokee Chat" web page would net you quite a few good responses. See www.Piperowner.com . Sounds like you've got some pretty major damage there. Is any of it noted in the logbooks? (I'll bet I know the answer to *that* question...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
C wrote:
Working on a 100hour just a month before the annual is due -- my mechanic and I lifted the back seat to look at the cabling underneath. Lo and behold -- we found a "tear" in an aluminum bulkhead under the back seat. The bulkhead is under the back of the rear seat and doesn't appear to be structural as it is thin aluminum. But there is a steel brace coming in from the flap area of the wing and rivited to the lower outside corner of the aluminum bulkhead. I'd be carefull jumping to the conclusion that's it isn't structural. That steel plate is the rear wing attach fitting. And I believe the bulkhead that it's attached to is considered the "rear spar carry through" (like a "mini" spar). Cherokee's have a large center spar, but also have a front and rear attach point and carry through. The front carry through is behind where your heels sit when you're in the pilot's seat (under the plastic trim pieces). The rear one is where you describe. However on mine, just next to the steel brace on the baggage door side -- there is a inch long tear up from the bottom of the bulkhead and a small buckle in the aluminum brace above the tear. Its like there was a terrific upwards stress on the bottom corner of the bulkhead where the steel is rivited and it tore the aluminum bulkhead upwards. There was a person on the Cherokee Chat (see Jay Honeck's post) a few weeks ago that had very similar crack and he posted pictures. I hope this isn't the beginning of a trend, or we'll be seeing an AD soon. You're correct in assuming a "terrific upward stress", although I would have hoped that a hard landing or bad turbulence wouldn't have caused such damage. You'll want to make sure you have a very competant mechanic fix this. Wing departure, or severe twist, while in flight would really suck. You might want to show this to your local FSDO, too. I hate to encourage and AD, but this could be a problem we might not want to ignore. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
xyzzy wrote:
attachments don't work on the newsgroups. You'll need to put it on a website if you want us to be able to see it Attachments work, some ISPs don't allow or filter them, I received it just fine... You can view it he http://www.whodat.net/cherokee180/damage.jpg Shame mine doesn't filter excessive quotation... ![]() |
Some years ago I repaired a Pawnee that had a similar steel plate on
the front spar. Because of the steel on aluminum, there was extensive corrosion between and the aluminum rivets were soft enough you could pick off the heads of the #6 rivets with your finger nail. From the looks of the photo, there is lots of rust, meaning water. Aluminum + steel + water = battery = corrosion. If it were mine, I'd take it apart and look to see what is going on. If the aluminum is corroded under the steel, you could get cracks under normal loads. Don A&P - IA Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Sorry to break the news to you, but that definitely IS structural. And
this is not an easy fix. The fitting on the left is the rear spar attach fitting. What you are looking at is the aftermath of a fairly severe "excursion" of the rear spar on that wing, probably front to back. I'm not sure where you see repairs and extra rivets. Those on the attach fitting and the ones going through the floor are all supposed to be there. I do see the corrosion forming behind the fitting that is the subject of a Piper Service Bulletin. Good luck trying to hold someone accountable on a pre buy. I highly doubt you will get anything back. For all the A&P knows, this damage could have occurred after his inspection. Ever notice any new scrapes on the affected wing leading edge or it's control surfaces, especially towards the tip? This may have been a close encounter with a hangar door or fuel truck. It does not take a huge amount of lateral pressure at the wing tip to produce the type of damage in the photo. These wings are made tremendously strong to not bend UP and quite strong to not bend DOWN. But the only thing keeping them from moving front to back is the rear spar and its attach point. Yours clearly flexed in and out. Let us know what your repair quote is. Mike Hi Mike, I met with a DER yesterday who has designed a repair for the damage. Its not going to be as bad as first thought. And while the DER design (plus 8110 form for FAA) cost was $450, the repair costs probably won't push behond $1,000. Talking with the DER, we're pretty sure we figured out when this happened. The only damage history on the plane was an "off-runway" excursion back in '92. The logs show the nose gear collapsed, the engine/cowl stuck, and of course a sudden engine stop. The logs show the engine teardown/rebuild and replacing everything forward of the firewall, but that's it. We're pretty sure the sudden rearward force on the mains as it departed the runway flexed the rear of the wing upward and caused this damage. If you look closely at the first picture posted on the 10th, you can see two cherry-max rivets into the bottom flange from the outside (rivets so poorly installed that they wiggle). THAT is how I know this repair was previously known. I also recently found out that the person I hired for the prebuy (on a referral) was the same person who had been maintaining the plane for a number of years. So, the suggestion that an A&P/IA would miss such damage through multiple annuals and a pre-buy is just plan nonsense. If he is THAT incompetent -- he shouldn't have a license to screw up further work. Anyway - thanks for the information Mike. None of that mess was corrosion by the way -- its just years of dirt/dust mixed with spray on lubricant. The first picture shows it after I brushed it a bit and vacuumed. I'm off tomorrow for a bunch of rivet pulling, buying some aluminum, and riveting in repairs. I'll be sure to post a couple pictures when we finish the designed repairs. Chuck N7398W |
| National Cherokee Pilots Association Fly-In PIREP | Jay Honeck | Piloting | 2 | June 21st 04 05:02 PM |
| CHEROKEE NATIONAL FLY-IN & CONVENTION - THIS MONTH! | Don | Piloting | 0 | June 3rd 04 06:06 AM |
| Cherokee National Fly-In & Convention - THIS MONTH | Don | General Aviation | 0 | June 3rd 04 06:01 AM |
| Cherokee National Fly-In & Convention | Don | Owning | 0 | May 5th 04 09:13 PM |
| Cherokee National Fly-In & Convention | Don | General Aviation | 0 | May 5th 04 09:12 PM |
