I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel:
http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom |
On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote:
I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel: http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. |
On Thursday, April 30, 2020 at 7:20:25 PM UTC-7, Andrzej Kobus wrote:
On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote: I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel: http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing.. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has. |
On Friday, May 1, 2020 at 1:31:09 AM UTC-4, 2G wrote:
On Thursday, April 30, 2020 at 7:20:25 PM UTC-7, Andrzej Kobus wrote: On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote: I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel: http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has. Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer! |
On Friday, May 1, 2020 at 4:09:16 AM UTC-7, Andrzej Kobus wrote:
On Friday, May 1, 2020 at 1:31:09 AM UTC-4, 2G wrote: On Thursday, April 30, 2020 at 7:20:25 PM UTC-7, Andrzej Kobus wrote: On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote: I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel: http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has. Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type.. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer! While the clamping of the Mark's wing wheel is better than Cobra's, scrubbing is inevitable because of the geometry of towing. I actually tried to buy Mark's wing wheel and even mailed him a check after he complained about others cancelling orders, but he still didn't want to make it. The CA wing wheel works better, is adjustable, has a shock absorber, is well made and is cheaper. And it was in stock. Tom |
Not exactly true. Tom inquired about a wing wheel, wing cuffs and a tow bar.. I explained that tow bars were out of stock and wing wheels and wing cuffs are custom fabricated. Because of my involvement in another project, I informed him that delivery times were questionable, if at all possible. I don't recall receiving a check at all.
As far as "scrubbing" being "inevitable," also not true. Over 300 of my wing wheels are out there, and if properly positioned and aligned with the direction of travel, they track well. But you can't convince Tom, since he is always right. |
On Friday, May 1, 2020 at 12:08:20 PM UTC-4, 2G wrote:
On Friday, May 1, 2020 at 4:09:16 AM UTC-7, Andrzej Kobus wrote: On Friday, May 1, 2020 at 1:31:09 AM UTC-4, 2G wrote: On Thursday, April 30, 2020 at 7:20:25 PM UTC-7, Andrzej Kobus wrote: On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote: I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel: http://www.craggyaero.com/ground_handling.htm And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it. Tom The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has. Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer! While the clamping of the Mark's wing wheel is better than Cobra's, scrubbing is inevitable because of the geometry of towing. I actually tried to buy Mark's wing wheel and even mailed him a check after he complained about others cancelling orders, but he still didn't want to make it. The CA wing wheel works better, is adjustable, has a shock absorber, is well made and is cheaper. And it was in stock. Tom No offense Tom, but you are coming across as you know best. I have been using his wing wheel for four season on the 31 Mi with excellent results without any "scrubbing" as you put it. |
The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons. I second that opinion. The MM Fabrication wing wheel for my Libelle is built like a tank, and fits like a glove. I don't have a scrubbing problem either. My MM wing wheel and tow bar are some of the best money I have spent on gliding equipment. Doug |
A few years back, someone showed me his unique design for a w/w. He mounted a basket-ball sized, round utility ball (with a bladder) that freely rotated against an upside-down "cup" which housed a dozen or so ping-pong ball sized "bearings". The ball allowed easy movement in any direction. (Picture one of those roller-type deodorant applicators in motion). He made a brake for it from a metal band that was actuated by a thumbscrew. Clever
If anyone upgrades to a swiveling wing wheel, I'm in the market for your old one. Please send me a message if you have something that will work with my Pik-20E.
| Thread Tools | |
| Display Modes | |
| Craggy Aero Navigation unit 4 sale | [email protected] | Soaring | 0 | March 21st 14 09:18 AM |
| Brand New Craggy Aero Ultimate LE for sale | [email protected] | Soaring | 0 | December 27th 13 12:12 PM |
| Big thanks to Richard at Craggy Aero | Bruce Barnard[_2_] | Soaring | 4 | February 15th 12 04:55 PM |
| Craggy Aero Ultimate & SeeYou Mobile | Richard[_1_] | Soaring | 2 | October 29th 08 07:45 PM |
| Craggy Aero Introduces the Ultimate Flight System | Richard[_1_] | Soaring | 18 | August 14th 08 05:56 AM |
