compound curves in plywood
Old April 8th 05, 07:52 PM
BA-100
Default compound curves in plywood
I'm considering building a replica of a 30's glider that was originally
built in two halves, like a plastic model, but with pressed plywood halves.
Duplicating this has been outside the reach of a homebuilder without some
sort of press, and any made since have either been made out of fiberglass
or segments of scarfed plywood as were the prototypes. Here's a pic of one
here. The fuselage on the production originals was, as I say, made of
molded plywood in two halves and assembled over formers and stringers.
some of you might be familiar with the Bowlus Baby albatross.
http://www.fiddlersgreen.net/AC/airc.../info/info.htm
My question is, would it be possible to laminate your own shell using
vacuum bagging? Seems to me even the wettest veneers would split if you
tried to force them into or around a male or female mold. to date, the only
sort of manipulation I've done with ply is to wrap 1/16 leading edge pieces
over a hot pipe. I just don't see how Hawley Bowlus got the compound
curves..
Any insights?
Old April 8th 05, 08:23 PM
Bob Kuykendall
your own shell using vacuum bagging? Seems to me
even the wettest veneers would split if you tried
Well, it's pretty easy to try it and see. Get some strips of thin
veneers (I'm thinking 1/64" to 1/32" or so) and try it out. For a test
part you can use any compound curved surface of about the curvature of
your porposed surface. I'd be inclined to try it out using VW beetle
(the old ones) fenders or roof sections from a junkyard. That'll give
you both internal and external test curve surfaces. If you can make
that work, it should give you enough experience and confidence to
proceed.
There are still folks around who know exactly how Bowlus made his
fuselage pods, it shouldn't be too hard to explore that. I believe that
Jeff Byard even has photos of the Bowlus tooling. There are also a
multitude of photos of the Lockheed Vega tools that used (I belive)
concrete molds and pressurized rubber bladders.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old April 8th 05, 09:24 PM
BA-100
"Bob Kuykendall"
egroups.com:
proceed.
Sounds like a plan! I've located a place that sells bags for vacuum forming
that would certainly be big enough and I think Icould get an old compressor
to do the honors if I mess it around enough.
Yes, that's right, that's exactly how Bowlus did it. I did a lot of
research on it years ago when i started the project the first time around,
(even talked to the funder of a lot of Hawley Bowlus' creations, Steven
DuPont) but making a molded pod was pretty much out of the question at the
time. the preferable option was to do like they did with the protottypes
and pretty much every other glider of the period and make a series of
scarfed rings (why did i think this would be less work?) but when I found
out about vacuum bagging, I saw it as a possible way around this. A male
mold would be the easiest to build of course. I figure a series of ply
formers, filled in with foam and sanded to shape, then maybe a layer of
resin and voila, a half a fuselage. Has the aded advantage of being easily
replicated left and right.
If that didn't work, I suppose I could use that as a plug to make a female
mold out of concrete. (yipes, what would I do with it afterewards? ) and
use vacuum bagging on that.
Might actually give it a try...
Old April 8th 05, 08:31 PM
W P Dixon
Luthiers commonly steam wood and form it over jigs, clamps hold it in place
until it drys out. May be the same kind of construction used to build this
sailplane. Just a thought and maybe something to check out.
Patrick
student SPL
aircraft structural mech
Old April 8th 05, 09:28 PM
BA-100
"W P Dixon"
place until it drys out. May be the same kind of construction used to
build this sailplane. Just a thought and maybe something to check out.
Yes, I've done this in fact. Have a guitar and a violin under my belt, but
no compound curves. Most flattop guitars have a small radius which is
compound, but nothing like what I'm talking about (a complete teardrop)
This sort of technology realy died out when fibreglass hit the scene,
though i'm sure there are some masters still around.Most likely source of
info are boatbuilders, of course, but their curves wouldn't even appraoch
the radius I'm talking about.....
Old April 8th 05, 11:14 PM
Morgans
"BA-100" wrote in message ...
"W P Dixon"
The key to bending wood with steam is how hot it is. Superheated steam is
best, which takes a re-heater after the water is boiled. Make sure the
plywood is made with water proof glue, which is anything of A grade or
better, or marked withEXT after the grade. It might be B grade, but I don't
remember, right off.
For testing, that type of plywood is fine, but for building a plane, use at
least marine grade, and best is aircraft grade.
Jim in NC
Old April 9th 05, 12:04 AM
Montblack
("Morgans" wrote)
at least marine grade, and best is aircraft grade.
"...and best is aircraft grade"
I know about marine grade plywood, but aircraft grade?
Speaking of marine grade plywood (I paid $77 w/tax for a sheet of 3/4" last
year) is there such a thing as marine grade + green treated that they sell?
That's what I wanted, couldn't find any. Something about varnish + green
preservative doesn't do well together I was told. (???)
It was for a carpeted-over floor in a 16 ft boat. We ended up spar
varnishing our sheet a number of times.
Montblack
Old April 9th 05, 01:37 AM
Morgans
"Montblack" wrote in message
last
sell?
Montblack
Yea, I know what you mean.
A friend wanted to do the same thing. We found a place that treats wood,
and got him to throw in some sheets of marine grade into his treating
thingy, the next time he was running a load. We then (after waiting for it
to dry out some) put it down and put a layer of fiberglass cloth and epoxy
over it all, before laying the carpet. It looks like new, about 5 years
later.
Jim in NC
Old April 11th 05, 01:32 PM
nafod40
I just finished up a stitch-n-glue (4 mm plywood with single layer
fiberglass inside and out) kayak yesterday, and took it out for it's
maiden run at the local lake. It's 17' long, single seater sea kayak.
Weighs about 35 LBs, but can take an ocean entry driving out through
heavy surf, so it's not a frail structure.
While paddling around, I got to thinking about this thread, and
imagining wings either side of me, tail feathers behind...
A bright finished plywood glider would be a true thing of beauty.
Old April 8th 05, 09:30 PM
I would guess that the construction techniques used
were similar to those used in boatbuilding.
http://www.albacore.org/USA/members/...g_albacore.asp
http://www.boats.com/content/default...contentid=1184
May help.
There is a remarkable wooden flying boat hull in the RAF Museum
at Hendon that was built in the early 1920s. It has a 'moulded'
hull which appears to have been constructed using boatbuilding
techniques of the time.
http://www.rafmuseum.org.uk/supermarine-southampton.htm
With its varnished finish it is simply stunning to
look at.
Nut/thread securing compound nauga Home Built 7 April 22nd 04 07:56 AM
Randolph Wing Walk Compound Larryskydives Owning 7 March 7th 04 09:44 PM
Plywood Kathi Jo Home Built 3 January 12th 04 10:48 PM
Somebody Terrified of Compound Curves ---- Or Just Lazy Larry Smith Home Built 8 October 31st 03 02:40 PM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 08:02 PM
