prior arrangement for lights?
Old April 10th 05, 02:57 AM
Roy Smith
Default prior arrangement for lights?
Some approaches have a note, "Procedure NA at night except by prior
arrangement for runway lights". Let's say I make this prior arrangement
(presumably by talking to the airport manager and having him leave the
lights on for me), how do I deal with ATC?
When I ask for the approach, is the controller going to ask me if I have
made "prior arrangement" for the lights? Is my say-so good enough for him,
or does he need to get some official notice from the airport manager saying
it's OK to let him run the approach?
Old April 10th 05, 03:57 AM
Stan Gosnell
Roy Smith wrote in
arrangement (presumably by talking to the airport manager and having
him leave the lights on for me), how do I deal with ATC?
have made "prior arrangement" for the lights? Is my say-so good
enough for him, or does he need to get some official notice from the
airport manager saying it's OK to let him run the approach?
IME, ATC assumes that if you ask for something, it's legal for you to do
it. They don't have the time to investigate that kind of thing.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old April 10th 05, 05:07 AM
kage
ATC could care less if you have lights.
KG
"Roy Smith" wrote in message
him,
saying
Old April 10th 05, 11:12 PM
Chuck
Not always. I was supprised when I ask for a "Pop Up" from Toledo, OH
the other day. I ask for a GPS approach and he ask if the plane was
IFR GPS equiped and current. I guess because there are so many VFR
GPSs. I said yes and that was that.
Chuck
Old April 11th 05, 12:35 AM
Roy Smith
In article .com,
This caught my eye the other day:
!FDC 5/2548 FWN FI/T SUSSEX, SUSSEX, NJ.
VOR OR GPS-A AMDT 5B...
PROCEDURE NA EXCEPT FOR IFR GPS-EQUIPPED AIRCRAFT.
I struck me as strange that they felt the need to explicitly state "IFR
GPS" for an approach procedure. And, even then, it's badly worded, since
there are plenty of IFR GPS units which are not approved for approaches.
Old April 12th 05, 03:32 PM
Roy Smith wrote:
In article .com,
Part of the requirement is to be able to retrieve the approach from the
database. You can't do that with an IFR GPS unit that is not approved for
approaches. So, why would the FAA need to state the obvious?
As to their stating "IFR GPS-EQUIPPED AIRCRAFT" if they simply said
"GPS-EQUPPED AIRCRAFT" some airport jailhouse lawyer would point to it as
implicit authorization to fly the approach with a Garmin hand-held.
Old April 21st 05, 09:02 PM
Robert M. Gary
Roy Smith wrote in message ...
In article .com,
I think what they are saying is that the VOR is not usable for the
approach. You can't even shoot the VOR and use the VFR GPS as a
backup.
-Robert
Old April 10th 05, 11:14 AM
As has been said here many times, ATC is neither a regulatory nor legal
interpretation entity. If he even asks, which is problematical, you tell him
it's been taken care of.
The only time ATC gets involved with authorizations for an approach is to deny
its use at night when it is not authorized at night. Or, to deny its use when
the airport is officially known to his ATC facility to be closed. Or, to
temporarily deny its use when there is a traffic conflict. Or, to deny its use
when the basic facility for ground-based-navigation is NOTAMed OTS.
And, he is not supposed to clear you for an approach that requires equipment
that you apparently do not have, as indicated by your equipment suffix.
That's about it. In the final analysis the regulatory requirements,
authorizations and limitations of the Part 97 IAP are between you and the
regulators at the FAA. Neither controllers nor ATC facilities are regulators
or regulatory functions of the FAA.
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 05:56 AM
FAA to End part 91 Sightseeing flights? Vaughn Rotorcraft 7 November 2nd 03 01:20 AM
Ownership and passengers Roger Long Owning 30 October 11th 03 02:00 PM
