https://en.wikipedia.org/wiki/Fiat_G.50
The Fiat G.50 Freccia ("Arrow") was a World War II Italian fighter aircraft developed and manufactured by aviation company Fiat. Upon entering service, the type became Italy’s first single-seat, all-metal monoplane that had an enclosed cockpit and retractable undercarriage. On 26 February 1937, the G.50 conducted its maiden flight. During early 1938, the Freccias served in the Regia Aeronautica (the Italian Air Force) and with its expeditionary arm, the Aviazione Legionaria, in Spain, where they proved to be relatively fast and very manoeuvrable in comparison to its adversaries in the theatre. Early in the Second World War, it was determined that the G.50 possessed inadequate armament, comprising a pair of Breda-SAFAT 12.7-mm machine guns. The fighter was extensively used on various fronts by Italy, including in Northern Europe, North Africa, the Balkans, and the Italian mainland. The G.50 commonly came up against the British Hawker Hurricane, which was fast enough to frequently outrun and out-range the Italian opponent. Later models of the fighter had improvements, including a substantial increase in range. The G.50 was exported to several overseas customers, small numbers being flown by the Croatian Air Force while 35 G.50 fighters were shipped to Finland, where they served with distinction during both the Winter War of 1940 and the Continuation War of 1941–1944 against the Soviet Union. In Finnish service, the type reportedly achieved an unprecedented kill/loss ratio of 33/1. The Fiat G.50 was a low-wing single-engine monoplane fighter interceptor aircraft. It featured all-metal construction, comprising a semi-monocoque fuselage with an exterior skin composed of light alloys. The structure of the fuselage was formed from four main longerons and 17 formers, closing into a load-bearing bulkhead forming the rear of the fuselage. The wings were divided into three separate sections, composed of a steel tube centre-section structure that was paired with duralumin outer wings and an alloy skin. The ailerons, which were both statically and aerodynamically balanced, had a metal structure covered by fabric. Hydraulically-actuated four-piece slotted-flaps were fitted to the aircraft's wings to improve its take-off and landing performance; these would automatically retract upon attaining a certain airspeed. The G.50 was equipped with retractable landing gear, consisting of inwardly-retracting mainwheels and a fixed, castoring tailwheel. It was the first front-line Italian fighter to be fitted with a retractable undercarriage, an enclosed cockpit, and a constant speed propeller; these improvements have been credited with enabling the G.50 to achieve a maximum speed that was 33 kilometres per hour (21 mph) faster than its contemporary, the Fiat CR.42 biplane. According to aviation author Gianni Cattaneo, the G.50 was a "robust and viceless aircraft which marked the introduction of new concepts and techniques, of design and manufacture". Powered by a single Fiat A.74 R.C.38 14-cylinder air-cooled supercharged radial engine, rated at 870 hp (650 kW) for take-off and 960 hp (720 kW) at 3,800 m (12,500 ft), enclosed in a NACA cowling and mounted upon a chrome-molybdenum steel tubular structure attacheded with flexible mounts. Access for maintenance of the engine was provided via large cowling doors and panels on the fuselage aft of the firewall gave access for fuel tanks and armament. The engine incorporated a reduction gear which drove the Hamiliton-Fiat 3-bladed all-metal constant speed propeller. Role Fighter aircraft Manufacturer Fiat Designer Giuseppe Gabrielli First flight 26 February 1937 Introduction 1938 Retired 1946 Finnish Air Force Status Retired Primary users Regia Aeronautica Finnish Air Force Ejército del Aire Luftwaffe Produced 1935–1943 Number built 683 + 5 prototypes Variants Fiat G.55 During 1938, the first operational Fiat G.50 fighters were delivered to the Regia Aeronautica. During the Spanish Civil War, about a dozen G.50s were dispatched to Spain to reinforce the Aviazione Legionaria, Italy's contribution to the conflict. The first of these were delivered to the theatre during January 1939. The value of its presence in the Spanish theatre is questionable as none of the fighters sent saw actual combat. At the civil war's end, the G.50s in the region were handed over to Spanish pilots and subsequently saw action in Morocco. Cattaneo summarised of the experience: "Little seems to have been learnt as nothing was done to increase the armament". Upon the G.50's entry to service, it was widely regarded as being an extremely manoeuvrable aircraft and was often considered to be one of Italy's best fighters. However, by the time of the outbreak of the Second World War, rapid advancements in the field of aviation had contributed to be type being considered to be both underpowered and underarmed in comparison to competing frontline fighters then in use by the main powers. In spite of this, in the buildup to the Second World War, further units of the Regia Aeronautica were equipped with newly delivered G.50s; these were heavily used in various exercises and war-games from November 1939 onwards as it became increasingly clear that Italy would likely soon be at war with the Western democracies. Upon Italy's entry into the Second World War in June 1940, the Regia Aeronautica possessed a total of 118 G.50s that were available for operations; of these, 97 aircraft were available to perform front line duties while others were either in maintenance or awaiting delivery. The majority of these were assigned to 51° Stormo, (group) which was based at Ciampino Airport (just outside Rome) and at Pontedera, with 22° Gruppo (wing) of 52° Stormo. On 10 June 1940, when Italy issued its declaration of war against both France and Great Britain, the G.50s of 22° Gruppo went into action, followed by the 48 aircraft of 20° Gruppo. Operations during the first few days were sporadic and varied, often serving as escorts for Savoia-Marchetti SM.79 bombers on attack missions against harbours and airfields on the island of Corsica. These operations were quickly brought to an end when France signed the Armistice of 22 June 1940, officially capitulating to the Axis powers. Specifications (G.50) General characteristics Crew: 1 Length: 8.01 m (26 ft 3 in) Wingspan: 10.99 m (36 ft 1 in) Height: 3.28 m (10 ft 9 in) Wing area: 18.25 m2 (196.4 sq ft) Empty weight: 1,963 kg (4,328 lb) Max takeoff weight: 2,402 kg (5,296 lb) Powerplant: × Fiat A.74 R.C.38 14-cylinder air-cooled radial piston engine, 649 kW (870 hp) for take off 720 kW (966 hp) at 3,800 m (12,467 ft)Propellers: 3-bladed Hamilton Standard-Fiat constant-speed propeller Performance Maximum speed: 470 km/h (290 mph, 250 kn) at 5,000 m (16,404 ft) Range: 445 km (277 mi, 240 nmi) Service ceiling: 10,700 m (35,100 ft) Time to altitude: 5,000 m (16,404 ft) in 6 minutes 3 seconds Armament Guns: 2 × 12.7 mm (0.50 in) Breda-SAFAT machine guns * |
| Fiat BR.20 pics 4 [3/7] - Fiat-BR20-shot-down-Woodbridge-Engalnd-Batt-of-Brit.jpg (1/1) | Miloch | Aviation Photos | 0 | July 5th 19 03:44 PM |
| Fiat BR.20 pics [1/8] - A formation of Fiat B.R.20s, June 1937. Note the camouflage blending in with the ground below.jpg (1/1) | Miloch | Aviation Photos | 0 | July 5th 19 03:39 PM |
| Fiat G.50 pics 1 [04/11] - Artwork-technical-drawing-of-a-Fiat-G50-Freccia-versions-HPM-1993-11-P9.jpg (1/1) | Miloch | Aviation Photos | 0 | October 7th 17 03:32 PM |
| Fiat G.50 pics 1 [03/11] - Artwork-technical-drawing-of-a-Fiat-G50-Freccia-Revi-29-P19.jpg (1/1) | Miloch | Aviation Photos | 0 | October 7th 17 03:32 PM |
| Fiat G.50 pics 1 [02/11] - Artwork-technical-drawing-of-a-Fiat-G50bis_AS-Freccia-HPM-1993-11-P10.jpg (1/1) | Miloch | Aviation Photos | 0 | October 7th 17 03:32 PM |
