![]() https://en.wikipedia.org/wiki/Bristol_Bolingbroke The Bristol Fairchild Bolingbroke was a maritime patrol aircraft and trainer used by the Royal Canadian Air Force during the Second World War. Built by Fairchild-Canada, it was a license-built version of the Bristol Blenheim Mk IV bomber. In 1935, the British Air Ministry issued Specification G.24/35 to procure a coastal reconnaissance/light bomber to replace the Avro Anson. Bristol proposed the Type 149, based on its Blenheim Mk I, with Bristol Aquila engines to give greater range. While the Air Ministry rejected this proposal, a Blenheim Mk I, retaining its Mercury VIII engines, was converted as a Type 149 (Blenheim Mk III) for the general reconnaissance role. The nose was lengthened to provide more room for the bombardier, with the upper left surface of the nose being scooped out to maintain pilot visibility during takeoff and landing. The longer range also fulfilled a Canadian requirement for a maritime patrol aircraft. Consequently, Fairchild Aircraft Ltd. (Canada) of Quebec started production of the Blenheim Mk IV as the Bolingbroke (the originally intended name for the Blenheim IV). This type was nicknamed the "Bolly". After a small run of aircraft constructed to British specifications, as the Bolingbroke Mk I, Fairchild switched production to the Bolingbroke Mk IV with Canadian and American instruments and equipment. These versions also included anti-icing boots and a dinghy. One of the early Mk IV variants was the Bolingbroke Mk IVW which was powered by two 825 hp (615 kW) Pratt & Whitney SB4G Twin Wasp Junior engines. Incapable of maintaining altitude on one engine, the normal bomb load was reduced to 500 pounds on these aircraft to compensate for the low engine power. The most-produced variant was the Bolingbroke Mk IVT trainer, of which 457 were completed. A total of 626 Bolingbrokes were produced. Role Maritime patrol aircraft/trainer Manufacturer Bristol Aeroplane Company Fairchild Aircraft Ltd. (Canada) First flight 14 September 1939 Introduction 15 November 1939 Primary user Royal Canadian Air Force Produced 1939–1943 Number built 626 Developed from Bristol Blenheim Most of the 151 Mk IVs built served in their intended role as patrol bombers on the Atlantic and Pacific coasts of Canada between 1940 and 1944. Two squadrons of these aircraft also served in Alaska during the Aleutians campaign. The Mk IVT trainers saw extensive use in the British Commonwealth Air Training Plan (BCATP). Specifications (Bolingbroke Mk IV) General characteristics Crew: three Length: 42 ft 9 in (13.03 m) Wingspan: 56 ft 4 in (17.17 m) Height: 9 ft 10 in (3.00 m) Wing area: 469 ft2 (43.6 m2) Empty weight: 9,835 lb (4,470 kg) Loaded weight: 13,750 lb (6,250 kg) Max. takeoff weight: 14,500 lb (6,591 kg) Powerplant: 2 × Bristol Mercury XV nine-cylinder air-cooled radial engine, 920 hp (685 kW) at 9,250 ft (2,820 m) each Performance Maximum speed: 250 knots (288 mph, 464 km/h) at 15,000 ft (4,570 m) Cruise speed: 174 knots (200 mph, 322 km/h) Range: 1,617 nm (1,860 mi, 2,995 km) at 170 mph (274 km/h) Service ceiling: 27,000 ft (8,230 m) Rate of climb: 1,480 ft/min (7.5 m/s) Wing loading: 29.3 lb/ft2 (143 kg/m2) Power/mass: 0.14 hp/lb (0.24 kW/kg) Armament Guns: 1× fixed forward firing .303 in Browning machine gun and one .303 in Browning machine gun in power operated dorsal turret, alternately in the IVT, two Browning machine guns in a Bristol Type B1 Mk IV turret Bombs: 2× 500 lb (230 kg) or 4 × 250 lb (114 kg) bombs * |
Bristol Bulldog pics 3 [10/11] - Swedish airforce aviators pose with one of their new Bristol Bulldogs.jpg (1/1) | Miloch | Aviation Photos | 0 | June 9th 18 02:49 PM |
Bristol Blenheim pics [5/8] - Bolingbroke IVT in the Commonwealth Air Training Plan Museum, Brandon, Manitoba.jpg (1/1) | Miloch | Aviation Photos | 0 | March 19th 18 12:51 PM |
Hamilton Air Show Batch 1 [21/30] - Bolingbroke.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | June 21st 13 09:04 PM |
Hamilton Air Show Batch 2] [18/43] - Bolingbroke DSC_5048.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | July 10th 12 12:39 AM |
Hamilton Air Show Batch 2] [17/43] - Bolingbroke DSC_5046.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | July 10th 12 12:39 AM |
