Jim,
I've read your columns regarding aircraft electronics for years and I just can't seem to get an answer for a problem I have. I'm trying to connect a Alpine AM/FM/CD player in my plane to the music input of my audio panel (a GMA340) The problem is that I can't hear the music because the volume is so low. I believe it has something to do with the input and output level of the two devices, but not being an electronics guru I don't know how I can make them work together. Do you have any suggestions? The output of the radio (pre-amplified) is 4V / 10K ohms max voltage and the audio panel music input is 510 ohm impedance and 500 mV RMS for full output typical, 1V AC RMS MAX (3V peak to peak). I'd be happy to supply more info is required. This is probably a simple question, but I'm stumped! Regards, Brian DeFord |
It is a relatively simple problem involving nothing more complex than a high
impedance output (intended to drive 10k) and a low impedance input (510 ohm) intended for line level inputs. If that output impedance is really meant to deliver 4 volts (probably peak to peak, although you didn't state) into 10k, then the voltage into a 510 ohm resistor will be something on the order of a quarter of a volt peak to peak, or 72 millivolts RMS. If your audio panel requires 500 mV to drive it to full volume, then I'd expect the output with 72 mV to be about 17 dB below full output ... or in lay terms, "damned low". There are several solutions, some better than others. 1. Call Garmin? (GMA-340) and ask them if you can clip a resistor that provides the 510 ohm load for the input. For example, on the RST-564 audio panel, we have a 560 ohm resistor on every audio input to ground to simulate a standard 600 ohm load. If you clip that resistor out, the input impedance jumps up to the value of the input summing resistor (10k) (www.rstengineering.com and download schematics for the RST-564 -- drawing 564-5803). Problem solved. The main problem is to get Garmin? to give you that data. 2. Failing that, you can kluge together a simple little single transistor emitter follower amplifier that will take the 10K output impedance and translate it directly to a 510 ohm input impedance. If somebody can tell me how to post a binary to this group (no, I'm LOUSY at ascii schematic artwork) or some other method of posting an image in the ra* groups, I'll be happy to do so. 3. You can use the speaker output of the Alpine (if it has one) to drive the audio panel directly ... unless it has what is called a "bridge amplifier" and then we have to do a little dicking around (ahem, pardon me, heuristic engineering) to get it to play properly. There are more, but these are the easiest... Jim "Brian DeFord" wrote in message news:XhR8e.35465$A31.28773@fed1read03... Jim, I've read your columns regarding aircraft electronics for years and I just can't seem to get an answer for a problem I have. I'm trying to connect a Alpine AM/FM/CD player in my plane to the music input of my audio panel (a GMA340) The problem is that I can't hear the music because the volume is so low. I believe it has something to do with the input and output level of the two devices, but not being an electronics guru I don't know how I can make them work together. Do you have any suggestions? The output of the radio (pre-amplified) is 4V / 10K ohms max voltage and the audio panel music input is 510 ohm impedance and 500 mV RMS for full output typical, 1V AC RMS MAX (3V peak to peak). |
I'd try an impedance matching transformer. Something like a Tamura
MET-17 (available from Digikey for about $20 each and other places). If they do what you want, put heat shrink tubing around them and call it a done deal. Does your stereo or intercomm have a way of controlling the pre-amp output volume of the music? You might be a little "hot" compared your comm radio. |
You are kidding, aren't you?
Jim wrote in message ups.com... I'd try an impedance matching transformer. Something like a Tamura MET-17 (available from Digikey for about $20 each and other places). If they do what you want, put heat shrink tubing around them and call it a done deal. Does your stereo or intercomm have a way of controlling the pre-amp output volume of the music? You might be a little "hot" compared your comm radio. |
I'm absolutely serious, what's the issue?
Well since we're critiqing solutions... 1) I didn't like this one because you're asking the guy to take apart his fancy audio panel (warrenty?). And there is a good chance that resistor, if it exists, is a tiny surface mount part about the size of a piece of pepper. Plus the solution only works for people who own the same make/model audio panel. 2) I didn't like the emitter-follower amp because then you have to pull (and breaker) power out to power the amps. His signal already has enough power, its just the wrong impedance. 3) You might get away with this, but then again, as you alluded to, that stereo may not like having its outputs connected to ground. Its kind of a kludge to drive that 500 ohm input with an 8 (or less) ohm output, there may be distortion because of the mismatch. RST Engineering wrote: You are kidding, aren't you? Jim wrote in message ups.com... I'd try an impedance matching transformer. Something like a Tamura MET-17 (available from Digikey for about $20 each and other places). If they do what you want, put heat shrink tubing around them and call it a done deal. Does your stereo or intercomm have a way of controlling the pre-amp output volume of the music? You might be a little "hot" compared your comm radio. |
![]() wrote in message oups.com... I'm absolutely serious, what's the issue? Well since we're critiqing solutions... Thankful we aren't crititquing spelling... 1) I didn't like this one because you're asking the guy to take apart his fancy audio panel (warrenty?). And there is a good chance that resistor, if it exists, is a tiny surface mount part about the size of a piece of pepper. Plus the solution only works for people who own the same make/model audio panel. I'm not asking the guy to do anything. I'm simply pointing out how the problem can be solved. You predicate surface mount, and even if it is, the part is about the size of a matchhead, not a piece of pepper. So what if the solution only is valid for that particular make/model of audio panel? The general solution is valid for ALL audio panels, not just this make/model. What don't you understand about generic solutions to problems? 2) I didn't like the emitter-follower amp because then you have to pull (and breaker) power out to power the amps. His signal already has enough power, its just the wrong impedance. Didn't spend too much time in engineering school, didja? Do me a favor. Do an Ohm's law calculation for the volts into 10K versus the volts into 500 ohms as a function of power. It isn't the wrong impedance, dunderhead, it is not enough power to drive the requisite load. Your stupid suggestion of a transformer indicates that you have not a clue about power transfer. 3) You might get away with this, but then again, as you alluded to, that stereo may not like having its outputs connected to ground. Its kind of a kludge to drive that 500 ohm input with an 8 (or less) ohm output, there may be distortion because of the mismatch. Oh, bull****. Don't post here with this sort of stuff unless you've done it before. Jim |
Oh here we go. Somebody dares to question the great Jim Weir and is going to catch a rash of it. His next post will tell us again how many years he's been doing electronics and how anybody not wanting to use their real name on usenet is a coward. Asking you for help on usenet is like calling into a radio talk show psychologist. While the psychologist is usually right, the caller soon becomes very sorry he asked. |
Well guys, I started off annoyed that folks were arguing in a harsh
manner. However, after reading all of the posts I realized, you can learn a lot from two engineers arguing. Keep up the good fight, just put more smileys in there! |
Aviation Conspiracy: FAA Calls Controller Whistleblowers "Rogue Employees!!! | Bill Mulcahy | General Aviation | 0 | March 31st 05 04:29 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Piloting | 0 | May 11th 04 10:43 PM |
Marine Radio using Aviation Antennae | Jim Weir | Home Built | 13 | August 12th 03 10:05 PM |
