I have applied some teflon spray with a brush into the canopy sliding window rails with good result. Now I'm wondering whether I could use it in the same way under the mylar tape on the wings to reduce friction and ease forces on the ailerons. Any thoughts if and how it reacts with gelcoat/glass fiber/carbon fiber structure? I am cautioned by the common knowledge about negative influence silicon may have on composites. Is there any similarity?
Thanks in advance for sharing your experience, if any. Tom BravoMike |
I put wax under the tapes with excellent results! It doesn’t take much.
On 10/07/2020 03:46, Tom BravoMike wrote:
I have applied some teflon spray with a brush into the canopy sliding window rails with good result. Now I'm wondering whether I could use it in the same way under the mylar tape on the wings to reduce friction and ease forces on the ailerons. Any thoughts if and how it reacts with gelcoat/glass fiber/carbon fiber structure? I am cautioned by the common knowledge about negative influence silicon may have on composites. Is there any similarity? Thanks in advance for sharing your experience, if any. Tom BravoMike Not quite the same but the instructions for fitting Mylar seals on gliders from multiple manufacturers include adding teflon backed fabric tape across the gaps. In fact it is the tape that provides the seal and not the Mylar. https://wingsandwheels.com/teflon-fa...-adhesive.html -- Nick Hill |
| Teflon tape attaching | JohnO[_2_] | Soaring | 3 | June 19th 18 10:40 PM |
| Teflon tape | [email protected] | Owning | 7 | March 9th 08 04:44 AM |
| Teflon gap seal tape... | Marc Ramsey | Soaring | 10 | April 3rd 05 05:35 PM |
| mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 03:52 PM |
| Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
