Vibration Testing
Old September 29th 04, 07:15 PM
Jim Weir
Default Vibration Testing
I've come across a marvelously cheap vibration sensor that I want to convert
into an engine vibration instrument for a Kitplanes article. The electronics
for me is relatively trivial...the mechanics of vibration are a little harder to
fathom.
From a mechanical engineering point of view on a horizontally opposed engine,
there are (as with most things) three axes of freedom -- fore and aft, side to
side, and up and down (longitudinal, lateral, vertical).
The sensor I have reads two axes, and my hit is that fore-aft is the least
interesting vibration mode of the engine. The question is whether to have a
two-channel meter (which complexes up both the design AND the panel space), a
single meter switchable between lateral and vertical) or a single meter with the
two axes summed together.
Comments and thoughts from the technonerds amongst us appreciated.
(It has nothing, repeat NOTHING to do with the fact that such a meter might have
detected a crack in that cylinder WAY BEFORE it departed the engine on the way
home from Oshkosh {;-) )
http://www.rst-engr.com
Old September 29th 04, 07:23 PM
john smith
Thirty years ago I worked for a company by the name of IRD Mechanalysis.
Their business was vibration detection, monitoring and analysis for
preventive maintenance of heavy machinery.
At that time they were a subsidiary of H H Robinson Company, a
construction company based in Pittsburgh PA.
We built our own crystal-transducers to work with the monitoring equipment.
I never worked in the analysis end of the business, so I cannot tell you
where the frequencies indicating "good" and "bad" lie. Each device is
different. A problem with each component was indicated by a different
frequency.
The only aviation use I am aware of was to dynamically balance props.
fathom.
Old September 30th 04, 03:54 AM
David Lesher
john smith writes:
I remember them. We used it on pumps. Here "pump" mean 17-stage
centrifugal with a 800 HP motor that runs on 3-phase 4160vac.
As I recall, it took a fair amount of training to interpret
the results.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old September 29th 04, 07:31 PM
Ron Natalie
"Jim Weir" wrote in message ...
I suppose it depends what you're going to do with the data.
If it's just an idiot sensor that something is going wrong with the engine, probably a sum
of the total vibration would be best.
If you're trying to test something, two meters would be better than one (either summed or
switched). Frankly I kindof detest switched meters. I replaced that kludge in the navion
with individual fuel gauges.
Seems like the hifi apps should have some stereo vu-meters available, I know you used to be
able to get a stereo bar graph led display at RadioSnack a few years back.
Old September 29th 04, 09:31 PM
Ben Jackson
If you really wanted to try to diagnose problems with it you should try
to couple it to RPM. Then you could measure vibration in terms of the
order relative to the moving parts. If you could include the phase of the
crankshaft you could probably spit out enough information to do a dynamic
prop balance on a serial port.
Alternatively you might be able to infer RPM by doing an FFT on the raw
data. That would be a neat party trick.
As far as mounting it seems like getting it as far forward as possible
(where you should see the largest magnitudes) would be good. And if you
only get 2 axes then I'd go with your idea and ignore push/pull and keep
side/side and up/down.
Ben Jackson
http://www.ben.com/
Old September 29th 04, 10:31 PM
Jim Weir
I don't think serial ports need dynamic prop balancing.
You guys sure know how to complex up a bonehead simple idea, don'cha?
(Ben Jackson)
-crankshaft you could probably spit out enough information to do a dynamic
-prop balance on a serial port.
Old September 30th 04, 03:42 AM
john smith
Forgot to add that
- the detection boxes were single channel
- the transducers were moved to each axis and the data collected
- the detection boxes had a built in strobe circuit to independently
measure RPM
Old September 30th 04, 06:14 AM
Jerry J. Wass
john smith wrote:
Forgot to add that
measure RPM
Weeel--kinda depends on whether you got a heavy metal prop, or a piece'o tree
mounted in the prop flange---the gyroscopic inertia of that 40# hunka 'luminum
kinda resists vibrating--I think the assend of the engine would kinda describe a
jitterbug motion around the nose of the crank.--If the prop is balanced, then a
"new" vibration introduced into the system would probably be detected easier
with a rear mounted pickup...'Course a wood prop & a front cylinder goin bad
might change the scenario somewhat. Y'all run a test & let me know!!
Old September 29th 04, 10:36 PM
G.R. Patterson III
My take is that summing the two axes would be perfectly acceptable. I agree that
fore-and-aft is unlikely to produce any interesting results. In fact, I'd bet that
any mechanical problem would show up as an increase in lateral vibration. Vertical
vibration would tend to occur only just before things come apart, IMO.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old September 29th 04, 10:50 PM
UltraJohn
Jim if the sensors are that cheap why not just use two mounted 90 degrees
apart. If its analog output you could just sum the two together to get
~total vibration or convert to digital feed a cheap microprocessor chip
and display all three. Logging all three channels would let you post
process the data all you want and would not be all that difficult.
John
convert
Pilot log book and taxi testing Bob Olds Home Built 1 February 11th 04 03:32 PM
Pressure testing gone bad Mark Hickey Home Built 17 November 25th 03 02:29 AM
Looking for out of service main rotor blades for testing newro... James Lloyd Home Built 0 July 28th 03 10:27 PM
Looking for out of service main rotor blades for testing new rotor Wright1902Glider Home Built 9 July 28th 03 06:06 AM
Torsional Vibration Testing B2431 Home Built 8 July 25th 03 07:15 AM
