https://en.wikipedia.org/wiki/Saab_32_Lansen
The Saab 32 Lansen (English: Lance) is a two-seat, transonic military aircraft designed and manufactured by Saab from 1955 to 1960 for the Swedish Air Force (Flygvapnet). Three principal variants of the Lansen were built for attack (A 32A), fighter (J 32B), and reconnaissance (S 32C). During its long operational life, the Saab 32 also served as an electronic warfare platform and target-tug aircraft. The Saab 32 Lansen had a simple general arrangement, being one of the first aircraft in the world to be specifically developed to fly attack missions. Its basic design features it was designed from came from Switzerland. It included drawings on Messerschmitts Messerschmitt P.1101, Messerschmitt P.1110, Messerschmitt P.1111 and Messerschmitt P.1112. SAAB's project manager Frid Wänström retrieved these secret papers from Switzerland to Sweden in 1945. The documents came from engineers from Messerschmitt who fled to Switzerland at the end of the Second World War. Among them were the engineer and aerodynamicist Hermann Behrbohm, who came to be part of Saab's core in the team around Saab 29 Tunnan and upcoming aircraft types like the The Saab 32 Lansen and Saab 35 Draken. From the outset, it was designed to provide good support for the installation of electronic warfare and weapons systems. The aircraft could be armed with a total of four 20 mm cannon, as well as wing pylons for various calibers of rockets and assorted bombs. The J 32 variant carried four 30 mm ADEN cannons while the A 32 ("A" stands for attack) had an armament of four 20 mm Bofors m/49 cannon hidden under flaps in the nose. The J 32 differed substantially from the other variant, Saab describing it as "to all intents a new aircraft", being fitted with a more powerful engine and newer armaments and different radar. The fuselage of the Lansen was produced with a sleek, streamlined airframe with clean lines. The Lansen was the first aircraft on which every mould line had been a result of mathematical calculation, made possible via an early application of computer technology. The wing had a 10 per cent laminar profile and a 35° sweep. hydraulically-boosted ailerons and large Fowler flaps on the wings comprised the main flight control surfaces, as did the hydraulically-assisted elevators of the powered tailplane; a total of four airbrakes were also present on the sides of the rear fuselage. The Lansen had a tricycle undercarriage with a single wheel on all of the landing gear. Other wing features include one-section stall fences on the outer-thirds of the wing, a pitot tube on the right wingtip, and three underwing hardpoints. To test the 35° sweepback design of the Lansen's wing, a half-scale wing was mounted on a Saab Safir, designated Saab 202 Safir. Role Attack aircraft, Fighter aircraft, Reconnaissance aircraft Manufacturer Saab First flight 3 November 1951 Introduction 1956 Retired 1997 Primary user Swedish Air Force Produced 1954–1960 Number built 450 On 25 October 1953, a SAAB 32 Lansen attained a Mach number of at least 1.12 while in a shallow dive, exceeding the sound barrier. In December 1955, deliveries of the A 32A attack variant formally commenced, allowing the swift retirement of the last piston-powered B 18 bomber from Swedish service shortly thereafter. According to Bill Gunston and Peter Gilchrist, the A 32A proved to be extremely effective, both in terms of serviceability and the accuracy of its armaments Between 1958 and 1960, a total of 54 S32 C reconnaissance aircraft were manufactured. The last Lansen to be built was delivered to the Flygvapnet on 2 May 1960. Accidents destroyed a third of all Lansens during 25 years of service, killing 100 crew along with 7 civilians in Vikbo. The accidents were due to a combination of technical faults, the aircraft not being ready for service, and training deficiencies in regards to flying at night and in adverse weather. In the 1960 Vikbo crash, pilot Uno Magnusson's A 32A suffered an engine outage, and ejected before crashing into a farmhouse, killing all seven civilian occupants. The crash was due to a known fault which occurred when a drop tank was fitted; the J32 B had been forbidden from using the drop tank. Replacement parts to correct the fault were available at the base but had not yet been fitted. The crash's causes were suppressed from the public by the Flygvapnet press office; as the victims were civilians, they were not included in official accident statistics. The A 32 Lansen was Sweden's last purpose-built attack aircraft. The replacement of the A 32A formally began in June 1971, the more advanced Saab 37 Viggen being slowly used to take over its attack responsibilities. As the type was gradually being replaced by more modern types, the Saab 32 continued to be operated into the late 1990s as target tugs and electronic warfare platforms, a total of 20 J 32Bs having been converted for these duties. By 2010, at least two Lansens were still operational, having the sole task of taking high altitude air samples for research purposes in collaboration with the Swedish Radiation Safety Authority; one of these collected volcanic ash samples in mid 2010. By 2012, a total of three Lansens reportedly remained in active service. Specifications (J 32B) General characteristics Crew: 1 Length: 14.94 m (49 ft 0 in) Wingspan: 13 m (42 ft 8 in) Height: 4.65 m (15 ft 3 in) Wing area: 37.4 m2 (403 sq ft) Airfoil: NACA 64A010 Empty weight: 7,500 kg (16,535 lb) Max takeoff weight: 13,500 kg (29,762 lb) Powerplant: 1 × Svenska Flygmotor RM6A afterburning turbojet engine, 47 kN (11,000 lbf) thrust dry, 65.3 kN (14,700 lbf) with afterburner Performance Maximum speed: 1,200 km/h (750 mph, 650 kn) Range: 2,000 km (1,200 mi, 1,100 nmi) Service ceiling: 15,000 m (49,000 ft) Rate of climb: 100 m/s (20,000 ft/min) Armament Guns: 4 × 30 mm ADEN cannons 90 rounds each Rockets: 4 × 75 mm air-to-air rocket pods Missiles: 4 × Rb 24 air-to-air missiles * |
Eh...repost of the Saab pics 2 [5/6] - The Saab B 18B at the Swedish Air Force Museum (2012).jpg (1/1) | Miloch | Aviation Photos | 0 | January 25th 19 03:13 PM |
MAE : SAAB Lansen | jmp | Aviation Photos | 0 | February 25th 08 09:20 PM |
MAE : SAAB Lansen | jmp | Aviation Photos | 0 | February 25th 08 09:19 PM |
MAE : SAAB Lansen | jmp | Aviation Photos | 0 | February 25th 08 09:18 PM |
