glass tube fuses
Old July 21st 20, 01:22 PM posted to rec.aviation.soaring
Roy B.
Default glass tube fuses
Does anybody know the correct nomenclature for the small size glass tube fuses that the manufacturers put in the panels of the newer gliders? I need to order a couple of 2A spare fuses and I am not sure what they call that physical size.
ROY
Old July 21st 20, 01:27 PM posted to rec.aviation.soaring
Tango Eight
ROY
There are a couple of different sizes in use, 3AG is most common. The fast way to replace is at the local auto parts store.
See also https://www.mcmaster.com/fuses
best,
T8
Old July 21st 20, 01:29 PM posted to rec.aviation.soaring
Tango Eight
ROY
best,
T8
Read that again... European manufacturer probably using Euro size, not 3AG. But in any case, McMaster Carr describes them all.
Old July 21st 20, 01:49 PM posted to rec.aviation.soaring
kinsell
ROY
best,
T8
Mine are 5 mm diameter, 20 mm length, smaller than 3AG.
Old July 21st 20, 03:14 PM posted to rec.aviation.soaring
okko kloosterman[_2_]
European small glass tube fuses (mostly used in electronics) are
measured 5mmØ x 20mm or 6.3mmØ x 32mm , the first size being the most
common.
Okko (Netherlands)
Op 21-7-2020 om 14:49 schreef kinsell:
gliders? I need to orderÂ* a couple of 2A spare fuses and I am not
ROY
There are a couple of different sizes in use, 3AG is most common.Â*
best,
T8
not 3AG.Â* But in any case, McMaster Carr describes them all.
Old July 21st 20, 03:40 PM posted to rec.aviation.soaring
kinsell
Yet the "European" fuses sold by McMaster are 10 x 38 mm. Sounds like
the OP would be well advised to actually measure what he has.
common.
Okko (Netherlands)
ROY
best,
T8
Old July 21st 20, 03:24 PM posted to rec.aviation.soaring
Andrzej Kobus
ROY
Schleicher uses 5x20. Also it is important if they are slow blow or fast blow. Make sure you read the fine print.
Old July 21st 20, 03:57 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Andrzej Kobus wrote on 7/21/2020 7:24 AM:
ROY
I know them as "DIN" fuses, but the package the 5 x 20 fuses came in says they are
"GMA type".
Fuses on the panel, or not SF Soaring 41 November 18th 16 09:41 PM
Searching for fuses [email protected] Soaring 14 August 26th 15 01:43 PM
Fuses in general Tuno Soaring 19 December 11th 08 06:45 PM
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
