![]() https://en.wikipedia.org/wiki/Vicker...imy_Commercial The Vickers Vimy was a British heavy bomber aircraft developed and manufactured by Vickers Limited. Developed during the latter stages of the First World War to equip the Royal Flying Corps (RFC), the Vimy was designed by Reginald Kirshaw "Rex" Pierson, Vickers' chief designer. Only a handful of aircraft had entered service by the time the Armistice of 11 November 1918 came into effect, so the type was not used in active combat operations during the war, but the Vimy became the core of the RAF's heavy bomber force throughout the 1920s. The Vimy achieved success as both a military and civil aircraft, the latter using the Vimy Commercial variant. A dedicated transport derivative of the Vimy, the Vickers Vernon, became the first troop transport aircraft operated by the RAF. During the interwar period the Vimy set several records for long-distance flights, the most celebrated and significant of these being the first non-stop crossing of the Atlantic Ocean, performed by John Alcock and Arthur Brown in June 1919. Other record-breaking flights were made from the United Kingdom to destinations such as South Africa and Australia. The Vimy continued to be operated until the 1930s in both military and civil capacities. Design and developement The Vickers F.B.27 Vimy is an equal-span twin-engine four-bay biplane, with balanced ailerons on both upper and lower wings. The engine nacelles were positioned mid-gap and contained the fuel tanks. It had a biplane empennage with elevators on both upper and lower surfaces and twin rudders. The main undercarriage consisted of two pairs of wheels, each pair carried on a pair of tubular steel V-struts. There was a tail-skid and an additional skid mounted below the nose of the fuselage to prevent nose-overs. The aircraft was designed to accommodate a three-man crew and a payload of 12 bombs. In addition to the pilot's cockpit, which was positioned just ahead of the wings, there were two positions for gunners, one behind the wings and the other in the nose, each with a pair of Scarff ring-mounted Lewis guns; the rear cockpit mounting was commonly not fitted during the interwar period. Provision for a maximum of four spare drums of ammunition were present in the nose position, while up to six drums could be carried in the rear position. The majority of the Vimy's payload of 250 lb bombs were stowed vertically inside the fuselage, between the spars of the lower-centre section; a typical load consisted of 12 bombs. In some variants further bombs could be stowed externally for a total of 18 bombs, depending on the particular engine used to provide enough power. For anti-surface warfare in the maritime environment, the Vimy could also be armed with a pair of torpedoes. To improve bombing accuracy, the Vimy was equipped with the High Altitude Drift Mk.1a bombsight. Standard equipment also included two Michelin-built Mk.1 flare carriers. The Vimy was powered by a range of different engines. Owing to engine supply difficulties, the prototype Vimys were tested with a number of different engine types, including Sunbeam Maoris, Salmson 9Zm water-cooled radials, and Fiat A.12bis engines, before production orders were placed for aircraft powered by the 230 hp (170 kW) BHP Puma, 400 hp (300 kW) Fiat, 400 hp (300 kW) Liberty L-12 and the 360 hp (270 kW) Rolls-Royce Eagle VIII engines, with a total of 776 ordered before the end of the First World War. Of these, only aircraft powered by the Eagle engine, known as the Vimy IV, were delivered to the RAF. Due to the diverse number of engines used, there are multiple conflicting official reports on the production numbers of each sub-variant of the Vimy. Design and production of the prototypes was extremely rapid; the detailed design phase of what had become internally designated as the Vickers F.B.27 and the manufacture of the three prototypes was completed within four months. Role Heavy bomber Manufacturer Vickers Limited Designer Reginald Kirshaw Pierson First flight 30 November 1917 Introduction 1919 Retired 1933 Primary user Royal Air Force Variants Vickers Vernon RAF service On 12 June 1918, according to aviation publication Flight International, the Air Board were to initially deploy the first production Vimy units as maritime patrol aircraft, equipped for anti-submarine warfare, and once this requirement had been satisfied, subsequent aircraft would be allocated to performing nighttime bombing missions from bases in France. This had been due to a recently introduced policy under which the number of land-based aircraft allocated to anti-submarine patrols was to be vastly expanded, from 66 landplanes in November 1917 to a projected force of 726 landplanes, in which the newly-available Vimy would be a key aircraft due to its long range capabilities. During August 1918, the application of floats to the Vimy was studied, but it is not known if any aircraft were ever so fitted. Throughout the 1920s, the Vimy formed the main heavy bomber force of the RAF; for some years, it was the only twin-engine bomber to be stationed at bases in Britain. On 1 April 1924, No. 9 Squadron and No. 58 Squadron, equipped with the Vimy, stood up, tripling the home-based heavy bomber force. On 1 July 1923, a newly formed Night Flying Flight, based at RAF Biggin Hill, equipped with the Vimy, was formed; during the general strike of 1926, this unit performed aerial deliveries of the British Gazette newspaper throughout the country.[18] Between 1921 and 1926, the type formed the backbone of the airmail service between Cairo and Baghdad. The Vimy served as a front line bomber in the Middle East and in the United Kingdom from 1919 until 1925, by which point it had been replaced by the newer Vickers Virginia. Despite the emergence of the Virginia, which numerous Vimy squadrons were soon re-equipped with, the Vimy continued to equip a Special Reserve bomber squadron, 502 Squadron, stationed at Aldergrove in Northern Ireland until 1929. The Vimy continued to be used in secondary roles, such as its use as a training aircraft; many were re-engined with Bristol Jupiter or Armstrong Siddeley Jaguar radial engines. The final Vimys, used as target aircraft for searchlight crews, remained in use until 1938. Vimy Commercial The Vimy Commercial was a civilian version with a larger-diameter fuselage (largely of spruce plywood), which was developed at and first flew from the Joyce Green airfield in Kent on 13 April 1919. Initially, it bore the interim civil registration K-107, later being re-registered as G-EAAV. The prototype entered the 1920 race to Cape Town; it left Brooklands on 24 January 1920 but crashed at Tabora, Tanganyika on 27 February. A Chinese order for 100 is particularly noteworthy; forty of the forty-three built were delivered to China, but most remained in their crates unused; only seven were put into civilian use. Fifty-five military transport versions of the Vimy Commercial were built for the RAF as the Vickers Vernon Specifications General characteristics Crew: 3 Length: 43 ft 7 in (13.28 m) Wingspan: 68 ft 1 in (20.75 m) Height: 15 ft 8 in (4.78 m) Wing area: 1,330 sq ft (124 m2) Empty weight: 7,104 lb (3,222 kg) Max takeoff weight: 10,884 lb (4,937 kg) Powerplant: 2 × Rolls-Royce Eagle VIII water-cooled V12 engines, 360 hp (270 kW) each Performance Maximum speed: 100 mph (160 km/h, 87 kn) Range: 900 mi (1,400 km, 780 nmi) Service ceiling: 7,000 ft (2,100 m) Armament Guns: 1 × .303 in (7.7 mm) Lewis Gun in Scarff ring in nose and 1 × in Scarff ring in mid-fuselage Bombs: 2,476 lb (1,123 kg) of bombs * |
Vickers Vimy pics 3 [2/9] - Vickers Vimy, Capt John Alcock & Lt Arthur Whitten Brown, Lester's Field, June 1919.png (1/1) | Miloch | Aviation Photos | 0 | November 6th 18 04:08 PM |
Vickers Vimy pics 2 [1/8] - Ross & Keith Smith Vickers Vimy & the 1919 England to Australia Air Race.jpg (1/1) | Miloch | Aviation Photos | 0 | November 6th 18 04:06 PM |
Vickers Vimy pics [1/8] - (L-R) Lt Col van Ryneveld with First Lt Quintin Brand, February 1920, in front of Vickers Vimy Silver Queen, before their England to South Africa flight.jpg (1/1) | Miloch | Aviation Photos | 0 | November 6th 18 04:04 PM |
