Mountain flying knowledge required?
Old April 23rd 05, 07:57 PM
Peter R.
Default Mountain flying knowledge required?
In late May I am planning to fly across the US, from NY to southern
California, with a return stop in Denver, CO. This will be done in a
single-engine, turbo-normalized Bonanza with on-board O2, and this is
the first time I have done this. My plan is to fly the majority of it
under IFR flight rules and at altitudes in the mid-to-upper teens (westerly
wind-depending).
When planning my flight from Palm Springs, CA, to Denver, I have decided to
avoid the high peaks in which a direct flight would result and instead
planned a flight east to Albuquerque, NM, then northeast/north to Denver
across the flat lands of Colorado, east of the mountains.
Disregarding the concept of density altitude as I am already familiar with
its affect on aircraft performance, would it still be advisable for me to
seek out some mountain flying instruction? My intention for this flight
is not to get too near the higher peaks of the Rockies, with the exception
of overflying the southern range in New Mexico.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old April 23rd 05, 08:41 PM
mindenpilot
"Peter R." wrote in message
(westerly
wind-depending).
to
Peter
There's really no substitute for actually flying in a rotor or mountain
wave.
But, I'm sure you could do some reading online to brush up on the various
phenomena associated with mountain flying.
The two I've listed are the ones I deal with most regularly.
You can expect LARGE updrafts and downdrafts.
It is important to know where they may occur in relation to the mountain
ridge.
Like I said, if you actually fly in it a couple times, it becomes a little
more obvious.
But if you are well informed, you should be able to recognize the conditions
around you...
Adam
N7966L
Beech Super III
Old April 25th 05, 06:33 AM
Chris W
ridge.
more obvious.
Is there an altitude above the ridge line at which the "mountain wave"
effect isn't significant?
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
Old April 25th 05, 07:32 AM
Peter Duniho
"Chris W" wrote in message
news:gj%ae.640$zv1.481@lakeread07...
Probably would be pretty negligible at 23,000 miles. For example.
Seriously though, yes...you can sometimes fly high enough to avoid the wave.
But that depends on the height of the terrain, the strength of the wind, and
of course the type of aircraft. There is no reliable way to know ahead of
time how high you need to fly to avoid it.
That said, there's being high enough to get all the way out of any
noticeable effects of the wave, and then there's being high enough to avoid
the wave forcing you too close to the terrain. The former may be
impossible, depending on the situation. The latter is usually possible. I
have rarely experienced altitude excursions of greater than 2000-3000 feet
as a result of mountain wave, so that's a pretty reliable margin for
crossing ridges.
Of course, there is the question of whether mountain wave can actually push
you into the ground. I've never actually heard of that happening, and for
it to do so, the part of the air mass you're flying in would have to hit the
ground as well. That happens in microbursts, or under virga, for example,
but you'd have to be pretty darn close to the ground in the first place for
a mountain wave to push you into it.
From a practical perspective, a couple of things to consider: higher up may
provide less turbulence (though, don't try to fly through a rotor cloud).
Also, if you want to most efficiently use the mountain wave to your
advantage, pitch up and slow down while it's making you go up, and pitch
down and speed up while it's making you go down. This will increase the
magnitude of your altitude changes, but you'll be spending less time during
the "bad" down areas and more time during the "good" up areas. Fighting the
mountain wave is just that: fighting. And no one wins a fight with Mother
Nature.
Of course, in practice you may have upper and lower limits to acceptable
altitudes, and those need to be taken into account. But inasmuch as you can
allow your altitude to vary with the wave, let it.
Pete
Old April 25th 05, 08:46 AM
Stefan
There's no reason to be afraid of wave. Wave isn't turbulent at all,
just think of it as a region with strong up or down draft. Stron means
just that: strong. You'll see 20 fpm and more.
No way to fight a downdraft of 20 fpm. So don't fight it, rather fly
perpendicularly to the ridge until you leave that region. Chances are,
you'll find a region with the same amount of updraft there. Throttle
back and enjoy.
Rotors are a completely different story, but you won't encounter them
above the peaks. Of course you may hit some other turbulence, so stay
below the yellow arc.
Stefan
Old April 25th 05, 06:18 PM
Peter Duniho
"Stefan" wrote in message
Can you please not screw up the quote attributions? You left my name on an
attribution from which you trimmed everything I wrote.
Old April 25th 05, 05:51 PM
Dylan Smith
Wave won't push you into the ground, however, if you're approaching a
ridge from the downwind side and the wind's up, the 'curlover' on the
downwind side may well cause you to impact the ridge. This is why it's
advisable to approach ridges at a 45 deg. angle and with altitude to
spare so you can turn away if there's trouble.
Wave can be a factor way up above FL350 - gliders from Minden regularly
get up in the FL300+ range. Even our little 2000' mountain, Snaefell,
generates wave which reaches over 10,000 ft.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old April 25th 05, 06:27 PM
Mike Rapoport
wave. But that depends on the height of the terrain, the strength of the
wind, and of course the type of aircraft. There is no reliable way to
know ahead of time how high you need to fly to avoid it.
avoid the wave forcing you too close to the terrain. The former may be
I have rarely experienced altitude excursions of greater than 2000-3000
feet as a result of mountain wave, so that's a pretty reliable margin for
crossing ridges.
push you into the ground. I've never actually heard of that happening,
and for it to do so, the part of the air mass you're flying in would have
to hit the ground as well. That happens in microbursts, or under virga,
for example, but you'd have to be pretty darn close to the ground in the
first place for a mountain wave to push you into it.
may provide less turbulence (though, don't try to fly through a rotor
cloud). Also, if you want to most efficiently use the mountain wave to
your advantage, pitch up and slow down while it's making you go up, and
pitch down and speed up while it's making you go down. This will increase
the magnitude of your altitude changes, but you'll be spending less time
during the "bad" down areas and more time during the "good" up areas.
Fighting the mountain wave is just that: fighting. And no one wins a
fight with Mother Nature.
can allow your altitude to vary with the wave, let it.
Pete
Mountain wave systems extend to and often into the stratosphere so it is
unlikely that you can fly above them unless you have a new airplane that we
haven't been told about :-).
Mike
MU-2
Old April 25th 05, 01:52 PM
Newps
mountain ridge.
little more obvious.
Not for your plane. Airlines will reroute around these areas to avoid
mountain wave.
Mike Rapoport
"Newps" wrote in message
ridge.
mountain wave.
But they do it because the wave system often gets turbulent up by the
tropopause where they are flying. In the mid altitudes the wave is smooth.
Mike
MU-2
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
TSA rule 49 CFR Part 1552 (or its misinterpretation) is already preventing people from flying (even renters) (long) Bay Aviator Piloting 15 October 21st 04 10:29 PM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
Copyright Š2004-2025 AviationBanter.
